Logging-Filter richtig setzen
    wie ich in anderen Threads hier näher erläutert habe, schalte ich meinen Russound-Verstärker per Schaltaktor stromlos, wenn ich ihn nicht brauche. Dadurch bekomme ich im Log alle ca. 8 Sekunden folgende Meldungen:
    2023-06-03  21:29:42 WARNING  lib.network         (TCP_Client_192.168.1.107:9621) TCP connection failed 1/5 times, last error was: [Errno 113] No route to host
    2023-06-03  21:29:50 WARNING  lib.network         (TCP_Client_192.168.1.107:9621) TCP connection failed 2/5 times, last error was: [Errno 113] No route to host
    2023-06-03  21:29:58 WARNING  lib.network         (TCP_Client_192.168.1.107:9621) TCP connection failed 3/5 times, last error was: [Errno 113] No route to host
    2023-06-03  21:30:06 WARNING  lib.network         (TCP_Client_192.168.1.107:9621) TCP connection failed 4/5 times, last error was: [Errno 113] No route to host
    2023-06-03  21:30:14 WARNING  lib.network         (TCP_Client_192.168.1.107:9621) TCP connection failed 5/5 times, last error was: [Errno 113] No route to host
    Diese Meldungen möchte ich nun per Filter in der Logging.yaml ausblenden. Ich habe es so versucht:
    version: 1
    disable_existing_loggers: False
    formatters:
        shng_simple:
            format: '%(asctime)s %(levelname)-8s %(name)-19s %(message)s'
            datefmt: '%Y-%m-%d  %H:%M:%S'
        shng_detail:
            format: '%(asctime)s %(levelname)-8s %(module)-17s %(threadName)-12s %(message)s  --  (%(filename)s:%(funcName)s:%(lineno)d)'
            datefmt: '%Y-%m-%d %H:%M:%S %Z'
    filters:
        russoundfilter:
            (): lib.logutils.Filter
            msg: "(TCP_Client_192.168.1.107:9621) TCP connection failed 1/5 times, last error was: [Errno 113] No route to host"
    handlers:
        console:
            class: logging.StreamHandler
            formatter: shng_detail
            stream: ext://sys.stdout
        shng_warnings_file:
            (): lib.log.ShngTimedRotatingFileHandler
            formatter: shng_simple
            level: WARNING
            when: midnight
            backupCount: 7
            filename: ./var/log/smarthome-warnings.log
            encoding: utf8
            filters: [russoundfilter]
        shng_details_file:
            level: DEBUG
            when: midnight
            backupCount: 7
            filename: ./var/log/smarthome-details.log
            encoding: utf8
    loggers:
        __main__:
            level: WARNING
            handlers: [shng_details_file]
        plugins.knx:
            level: DEBUG
    #  lib.scheduler:
    #    level: DEBUG
    #  plugins.cli:
    #    level: DEBUG
    root:
        level: WARNING
        handlers: [shng_warnings_file]
    Das funktioniert allerdings nicht. Zwar bekomme ich auch keine Fehlermeldung, die unter "msg:" angegebene Meldung wird aber auch nicht ausgeblendet.
    Ich habe diesen Beitrag gelesen: https://smarthomeng.de/user/konfigur...practices.html
    Dort wird für einen Filter folgendes Format angegeben:
    filter:
        meinfilter:
            module: "[sS]tate[eE]ngineLogger"
            msg: "(.*)Item (.*) not found!"
            #invert: True
    Muss ich also einen "name" und ein "module" angeben? Name wäre bei mir dann wohl "__main__", aber was muss ich bei "module" angeben? Oder liegt es nicht daran?
    Ich verwende SHNG in der Version 1.9.3
    Danke!
    Cheers
    Art Mooney
    Ich denke, es sollte auch ohne Module und Name geben, auch wenn es nicht schadet, bei Module "lib.network" anzugeben. Denke ich Sonst mal ohne probieren.
    Das Problem liegt eher in der msg. Dort muss man valide regex angeben. Also zB Klammern "escapen". Ich empfehle, hier auf Python zu stellen und das dann manuell auszuprobieren: https://regex101.com/
    Auf die Schnelle sollte das hier klappen
    \(TCP_Client_192\.\168\.1\.107:9621\) TCP connection failed(.*)
    Hier steht im Übrigen, dass die msg eine regex sein muss https://smarthomeng.de/user/referenz...ng_filter.html
    In dem von dir verlinkten Dokument sollte ich das wohl noch mit rein nehmen..
    Zuletzt geändert von Onkelandy; 06.06.2023, 20:58.
      Danke! Es geht ohne module und name. Der Link war wahnsinnig hilfreich.
      Der folgende Ausdruck tut's:
      msg: ".TCP_Client_192.168.1.107:9621..TCP.connection.fa iled...5.times..last.error.was.."
      Cheers
      Art Mooney
        Morg
        das ist ein Grund für den Featurewunsch von mir das man Plugins auf Stop bzw. Pause setzen können sollte
        Zuletzt geändert von bmx; 09.06.2023, 07:38.
          Absolut richtig. Das feature hatte ich im develop auch getestet, aber leider nicht erfolgreich. "suspend()" ging zuverlässig, "activate()" aber nicht. Das hatte ich hier kurz rückgemeldet.
          Cheers
          Art Mooney
