hier der Auzug von "ls -la /var/www"
ls -la /var/www total 20 drwxr-xr-x 4 admin admin 4096 Jun 22 06:18 . drwxr-xr-x 13 root root 4096 May 10 2013 .. -rw-r--r-- 1 root root 3585 Jun 21 12:42 index.lighttpd.html drwxr-xr-x 15 admin admin 4096 Nov 16 2013 smartvisu drwxrwxrwx 2 admin admin 4096 Jun 22 10:02 sonos
Im Logfile steht folgendes:
2016-06-26 23:03:19 ERROR Thread-13279 UPnP Error 701 received: Transition not available from 192.168.8.67
Traceback (most recent call last):
File "/usr/local/lib/python3.2/dist-packages/soco/services.py", line 398, in send_command
self.handle_upnp_error(response.text)
File "/usr/local/lib/python3.2/dist-packages/soco/services.py", line 459, in handle_upnp_error
error_xml=xml_error
soco.exceptions.SoCoUPnPException: UPnP Error 701 received: Transition not available from 192.168.8.67
2016-06-26 23:03:36 ERROR Thread-13293 UPnP Error 701 received: Transition not available from 192.168.8.67
error_xml=xml_error
2016-06-26 23:06:12 WARNING Thread-13431 FORCE_STREAM_MOD_OPTION for play_tts is deprecated and ignored.
2016-06-26 23:07:23 WARNING Thread-13505 FORCE_STREAM_MOD_OPTION for play_tts is deprecated and ignored.
