Hi Michael,
welchen Browser verwendest Du? Inkl. Versionsnummer.
Bis bald
Marcus
Bis bald
Marcus
root@smarthome:/usr/local/smarthome/items# cat heizung.conf
[Heizung]
name = Heizung
[[FBH]]
name = FBH
visu_opt = Heizung.FBH.VL, Heizung.FBH.RL
visu = rrd
[[[VL]]]
name = FBH-VL
type = num
rrd = yes
visu = yes
knx_dpt = 9
knx_listen = 1/4/6
knx_init = 1/4/6
[[[RL]]]
name = FBH-RL
type = num
rrd = yes
visu = yes
knx_dpt = 9
knx_listen = 1/4/7
knx_init = 1/4/7
[[Speicher]]
name = Speicher
type = num
visu_opt = Heizung.Speicher.Oben, Heizung.Speicher.Mitte, Heizung.Speicher.Unten
visu = rrd
[[[Oben]]]
name = SpeicherOben
type = num
rrd = yes
visu = yes
knx_dpt = 9
knx_listen = 1/4/0
knx_init = 1/4/0
[[[Mitte]]]
name = SpeicherMitte
type = num
rrd = yes
visu = yes
knx_dpt = 9
knx_listen = 1/4/1
knx_init = 1/4/1
[[[Unten]]]
name = SpeicherUnten
type = num
rrd = yes
visu = yes
knx_dpt = 9
knx_listen = 1/4/10
knx_init = 1/4/10
