fritz@home2:~$ telnet localhost 2323 Trying 127.0.0.1... Connected to localhost. Escape character is '^]'.
[cli] class_name = CLI class_path = plugins.cli update = true
2013-02-26 16:57:24,230 SmartHome.py INFO Init SmartHome.py v0.8-62-g4816628 -- smarthome.py:__init__:190 2013-02-26 16:57:24,230 SmartHome.py INFO No latitude/longitude specified => you could not use the sun and moon object. -- smarth ome.py:__init__:200 2013-02-26 16:57:24,231 SmartHome.py INFO Init Scheduler -- scheduler.py:__init__:52 2013-02-26 16:57:24,231 Scheduler DEBUG creating 5 workers -- scheduler.py:run:58 2013-02-26 16:57:24,232 SmartHome.py INFO Init Plugins -- smarthome.py:__init__:205 2013-02-26 16:57:24,235 SmartHome.py DEBUG Plugin: ow -- plugin.py:__init__:43 2013-02-26 16:57:24,238 SmartHome.py INFO Onewire: connected to 192.168.179.12:4304 -- __init__.py:connect:67 2013-02-26 16:57:24,242 SmartHome.py DEBUG Plugin: cli -- plugin.py:__init__:43 2013-02-26 16:57:24,244 SmartHome.py INFO Init Items -- smarthome.py:__init__:207 2013-02-26 16:57:24,248 SmartHome.py INFO Start Plugins -- plugin.py:start:64 2013-02-26 16:57:24,249 ow DEBUG 1w-disc next time: 2013-02-26 16:57:24+00:00 -- scheduler.py:_next_time:223 2013-02-26 16:57:24,250 SmartHome.py INFO Start Logics -- logic.py:__init__:33
2013-02-26 20:38:38,722 SmartHome.py CRITICAL Config file not found: "/usr/local/smarthome/etc/logic.conf". -- logic.py:__init__:43
[test1w]
[[h]]
name = humidity
type = num
ow_addr = 26.403311010000
ow_sensor = H
[test1wkueche]
[[h]]
name = humidity
type = num
ow_addr = 26.DC3611010000
ow_sensor = H
[test_io_1]
name = Input
type = bool
ow_addr = 12.12F86C000000
# could be IA, IB
ow_sensor = IA
[test_io_2]
name = Input
type = bool
# could be IA, IB
ow_sensor = IB
