EIBD und MDT USB-Schnittstelle
    der EIBD verträgt sich nicht mit meiner USB Schnittstelle.
    root@smarthome:/etc/default# findknxusb
    Possible addresses for KNX USB devices:
    device: 1:5:1:0:0 (MDT Technologies GmbH:KNX-USB Inteface)
    root@smarthome:/etc/default# eibd -t65535 -D -S -T -i usb:1:5:1:0:0
    Layer 7(00000000,51450012) EIBD should not run as root
    W00000001: EIBD should not run as root
    Layer 10(01863020,51450012) USBLoop-Create
    Layer 1(01883F98,51450012) Detect
    Layer 1(01883F98,51450012) Using 1:5:1:0:0 (1:130)
    Layer 1(01883F98,51450012) Open
    Layer 1(01883F98,51450012) Claimed
    Layer 1(01883F98,51450012) Opened
    Layer 1(01883F98,51450012) Send(064): 01 13 09 00 08 00 01 0F 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    Layer 10(01863020,51450012) LoopStart
    Layer 10(01863020,51450012) LoopBegin
    Layer 10(01863020,51450012) LoopWait
    Layer 0(01883F98,51450012) StartRecv
    Layer 0(01883F98,51450012) Send(064): 01 13 09 00 08 00 01 0F 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    Layer 0(01883F98,51450012) StartSend
    Layer 10(01863020,51450012) LoopProcess
    Layer 10(01863020,51450012) LoopEnd
    Layer 0(01883F98,51450012) SendComplete 64
    Layer 0(01883F98,51450012) RecvComplete 64
    Layer 0(01883F98,51450012) RecvUSB(064): 01 13 0B 00 08 00 03 0F 02 00 00 01 00 04 E0 11 26 1A 03 03 00 80 07 D7 6D 54 67 82 F8 49 3A E9 6F 20 73 15 DE ED EA 73 E6 6A 16 2F 52 D1 FB A3 69 7E 4D 7D CB BF 9F 7B 83 2B 52 B6 58 25 6E 61
    Layer 1(01883F98,51450012) Recv(064): 01 13 0B 00 08 00 03 0F 02 00 00 01 00 04 E0 11 26 1A 03 03 00 80 07 D7 6D 54 67 82 F8 49 3A E9 6F 20 73 15 DE ED EA 73 E6 6A 16 2F 52 D1 FB A3 69 7E 4D 7D CB BF 9F 7B 83 2B 52 B6 58 25 6E 61
    Layer 1(01883F98,51450012) Send(064): 01 13 0A 00 08 00 02 0F 03 00 00 05 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    Layer 0(01883F98,51450012) Send(064): 01 13 0A 00 08 00 02 0F 03 00 00 05 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    Layer 1(01884820,51450012) CEMI
    Layer 2(01873AE0,51450012) Unsupported EMI
    Layer 1(01883F98,51450012) Close
    Layer 1(01883F98,51450012) Release
    initialisation of the backend failed
    Woran kann das liegen? Funktioniert die Schnittstelle tatsächlich nicht??
    Da stehts: EIBD
    "KNX on USB (only EMI1 and EMI2 are supported; CEMI is not really supported by current USB interfaces)"
    Die MDT-Schnittstelle spricht soweit ich weiß cEMI, praktisch alle anderen dagegen EMI2. Deshalb funktioniert die MDT nicht mit eibd und auch nicht mit dem Gira HS beispielsweise.
    Marcus
      Oh, schade. Und das RPI KNX Interface ist auch erst wieder in einem Monat verfügbar...
