Bluetooth connection timeout
habe immer noch das Problem, das ich mehrmals täglich die Verbindung zum SMA verliere und dann spielen die Threads verrückt!
Hat jemand schon den Code auf Ethernet Connection umgeschrieben ?
Natürlich nutze ich bereits die DEVELOP Version vom Github, die PROD tut es gar nicht.
Auszug aus dem logfile:
Michael
2014-06-17 13:08:19 ERROR sma sma: rx: exception - [Errno 110] Connection timed out 2014-06-17 13:08:28 ERROR SMA Method SMA exception: [Errno 107] Transport endpoint is not connected Traceback (most recent call last): File "/usr/local/smarthome/lib/scheduler.py", line 344, in _task obj() File "/usr/local/smarthome/plugins/sma/__init__.py", line 210, in _update_values self._inv_send_request(request) File "/usr/local/smarthome/plugins/sma/__init__.py", line 610, in _inv_send_request self._send_msg(msg) File "/usr/local/smarthome/plugins/sma/__init__.py", line 479, in _send_msg self._btsocket.send(msg) OSError: [Errno 107] Transport endpoint is not connected 2014-06-17 13:11:11 INFO Main Caller: KNX, Source: 1.1.20, Dest: 1/4/16, Item: heizung.ww.booster.drive, Value: False 2014-06-17 13:11:11 INFO Main Update: Item heizung.ww.booster.drive, Param: Group="2" Drive="OFF" 2014-06-17 13:11:12 INFO Main Caller: KNX, Source: 1.1.20, Dest: 1/4/13, Item: heizung.fbh.booster.drive, Value: False 2014-06-17 13:11:12 INFO Main Update: Item heizung.fbh.booster.drive, Param: Group="1" Drive="OFF" 2014-06-17 13:12:58 INFO Scheduler Adding worker thread. Total: 6 2014-06-17 13:12:58 INFO Scheduler Threads: sma: 1, Main: 1, SMA: 4, zisterne: 1, Scheduler: 1, Thread-6: 1 2014-06-17 13:14:03 INFO Scheduler Adding worker thread. Total: 7 2014-06-17 13:14:03 INFO Scheduler Threads: Thread-7: 1, Main: 1, SMA: 5, zisterne: 1, Scheduler: 1, sma: 1 2014-06-17 13:15:04 INFO Scheduler Adding worker thread. Total: 8 2014-06-17 13:15:04 INFO Scheduler Threads: sma: 1, Thread-8: 1, Main: 1, SMA: 5, zisterne: 1, Scheduler: 1, SQLite dump: 1 2014-06-17 13:16:08 INFO Scheduler Adding worker thread. Total: 9 2014-06-17 13:16:08 INFO Scheduler Threads: Main: 1, Thread-9: 1, zisterne: 1, Scheduler: 1, SMA: 7, sma: 1 2014-06-17 13:16:11 INFO Main Caller: KNX, Source: 1.1.20, Dest: 1/4/16, Item: heizung.ww.booster.drive, Value: False 2014-06-17 13:16:11 INFO Main Update: Item heizung.ww.booster.drive, Param: Group="2" Drive="OFF"
Michael
