- √ - Problem with logic
    In the beginning I have to apologize that I am writing in english. I am using smartVISU and smarthome.py to control my home. It is working very well. Now I would like to write some logics. Here is one sample that I made, but I get errors from the logic file.
    Here are the config files:
    /items/knx.conf (part of it):
    [1-ker]
        [[tv-huone]]
           [[[wc-kattovalo]]]
                type = bool
                visu = yes
                knx_dpt = 1
                knx_listen = 0/6/1
                knx_send = 0/6/0
           [[[wc-seina]]]
                type = bool
                visu = yes
                knx_dpt = 1
                knx_listen = 0/6/3
                knx_send = 0/6/2
    /etc/logic.conf:
    [autotallin_ovi]
        filename = autotallix.py
        watch_item = 1-ker.tv-huone.wc-seina # monitor for changes
    /logics/autotallix.py:
    #!/usr/bin/env python
    if not sh.1-ker.tv-huone.wc-seina():
        sh.1-ker.tv-huone.wc-kattovalo('on')
    This is what i get from SH.py log:
    2013-07-09 08:28:07,899 SmartHome.py DEBUG    reading logics from /usr/local/smarthome/etc/logic.conf -- logic.py:__init__:38
    2013-07-09 08:28:07,900 SmartHome.py DEBUG    Logic: autotallin_ovi -- logic.py:__init__:45
    2013-07-09 08:28:07,905 SmartHome.py WARNING  Exception: invalid syntax (autotallix.py, line 2) -- logic.py:generate_bytecode:111
    If I use this kind of logic file. Everything works.
    for item in sh:
        print item
        for child_item in item:
            print child_item
    What I have made wrong?
    Maybe the parser has problems with the minus sign in your item names. Can you try to replace them with underscores and test again?
    Mit freundlichen Grüßen
    Niko Will
      I changed all the items to underscored, but same error occurred. I also tried other items without underscored. It gave me also same error.
        guess it's the digit in the name "1-ker"...
          Thank you for your help. Digit in the name "1-ker" was reason for the error.
