ich habe noch ein kleines Problem mit dem MPD Plugin. Ich habe mir Buttons gebaut um direkt einen Radiosender anwählen zu können.
items.conf
Fehler
Hat jemand eine Idee was ich falsch gemacht habe?
Gruß Felix
admin@smarthome:/usr/smarthome/bin$ ./smarthome.py -d -n
2013-07-30 21:11:55,499 SmartHome.py INFO Start SmartHome.py 0.9-7-g0d34a2e -- smarthome.py:__init__:192
2013-07-30 21:11:55,504 SmartHome.py DEBUG Python 2.7.3 -- smarthome.py:__init__:193
2013-07-30 21:11:55,510 SmartHome.py INFO Init Scheduler -- scheduler.py:__init__:53
2013-07-30 21:11:55,515 SmartHome.py INFO Init Plugins -- smarthome.py:__init__:208
2013-07-30 21:11:55,522 Scheduler DEBUG creating 5 workers -- scheduler.py:run:59
2013-07-30 21:11:55,551 SmartHome.py DEBUG Plugin: knx -- plugin.py:__init__:42
2013-07-30 21:11:55,582 SmartHome.py DEBUG Plugin: ow -- plugin.py:__init__:42
2013-07-30 21:11:55,597 SmartHome.py INFO Onewire: connected to 127.0.0.1:4304 -- __init__.py:connect:67
2013-07-30 21:11:55,604 SmartHome.py DEBUG Plugin: cli -- plugin.py:__init__:42
2013-07-30 21:11:55,617 SmartHome.py DEBUG Plugin: visu -- plugin.py:__init__:42
2013-07-30 21:11:55,699 SmartHome.py DEBUG Plugin: sql -- plugin.py:__init__:42
2013-07-30 21:11:55,726 SmartHome.py DEBUG SQLite 3.7.13 -- __init__.py:__init__:60
2013-07-30 21:11:55,753 SmartHome.py DEBUG sqlite next time: 2013-07-31 03:02:00+02:00 -- scheduler.py:_next_time:238
2013-07-30 21:11:55,757 SmartHome.py DEBUG Plugin: rrd -- plugin.py:__init__:42
2013-07-30 21:11:55,857 SmartHome.py DEBUG Plugin: mpd -- plugin.py:__init__:42
2013-07-30 21:11:55,867 SmartHome.py INFO Init Items -- smarthome.py:__init__:210
2013-07-30 21:11:56,004 SmartHome.py INFO Start Plugins -- plugin.py:start:63
2013-07-30 21:11:56,015 ow DEBUG 1w-disc next time: 2013-07-30 21:11:56+02:00 -- scheduler.py:_next_time:238
2013-07-30 21:11:56,043 rrd DEBUG rrd next time: 2013-07-30 21:13:36+02:00 -- scheduler.py:_next_time:238
2013-07-30 21:11:56,049 SmartHome.py INFO Start Logics -- logic.py:__init__:32
2013-07-30 21:11:56,060 SmartHome.py DEBUG reading logics from /usr/smarthome/etc/logic.conf -- logic.py:__init__:38
2013-07-30 21:11:56,081 sh.con DEBUG knx: enable group monitor -- __init__.py:handle_connect:110
2013-07-30 21:11:56,100 sh.con INFO KNX: connected to 127.0.0.1:6720 -- my_asynchat.py:connect:69
2013-07-30 21:11:56,102 SmartHome.py DEBUG Logic: hello -- logic.py:__init__:45
2013-07-30 21:11:56,191 sh.con INFO mpd: connected to hal9000:6600 -- my_asynchat.py:connect:69
2013-07-30 21:11:56,207 SmartHome.py DEBUG Logic: dummy -- logic.py:__init__:45
2013-07-30 21:11:56,272 SmartHome.py DEBUG dummy next time: 2013-07-30 21:12:02+02:00 -- scheduler.py:_next_time:238
2013-07-30 21:11:56,292 Scheduler DEBUG 1w-disc next time: 2013-07-30 21:21:56+02:00 -- scheduler.py:_next_time:238
2013-07-30 21:11:56,347 visu DEBUG series next time: 2013-07-30 21:12:04+02:00 -- scheduler.py:_next_time:238
2013-07-30 21:11:56,361 1w-disc INFO 1-Wire: 28.530988040000 with sensors: T11, T10, T, T12, T9 -- __init__.py:_discovery:390
2013-07-30 21:11:56,368 1w-disc INFO 1-Wire: 28.339F88040000 with sensors: T11, T10, T, T12, T9 -- __init__.py:_discovery:390
2013-07-30 21:11:56,523 ow DEBUG 1w-sen next time: 2013-07-30 21:11:56+02:00 -- scheduler.py:_next_time:238
2013-07-30 21:11:56,586 sh.gc DEBUG Garbage collector: collected 97 objects. -- smarthome.py:_garbage_collection:345
2013-07-30 21:11:56,731 Scheduler DEBUG sh.gc next time: 2013-07-31 02:04:00+02:00 -- scheduler.py:_next_time:238
2013-07-30 21:11:56,938 Scheduler DEBUG 1w-sen next time: 2013-07-30 21:16:56+02:00 -- scheduler.py:_next_time:238
2013-07-30 21:11:57,066 mpd DEBUG erdgeschoss.kueche.mpd_kueche.volume = 100 via MPD None -- item.py:_update:219
2013-07-30 21:11:57,074 mpd DEBUG erdgeschoss.kueche.mpd_kueche.play = True via MPD None -- item.py:_update:219
2013-07-30 21:11:57,486 1w-sen DEBUG erdgeschoss.schlafzimmer.temp = 23 via 1-Wire /bus.1/28.530988040000/temperature -- item.py:_update:219
2013-07-30 21:11:58,337 1w-sen DEBUG erdgeschoss.wohnzimmer.temp = 22 via 1-Wire /bus.1/28.339F88040000/temperature -- item.py:_update:219
2013-07-30 21:11:58,425 1w-sen DEBUG cycle takes 1.68701100349 seconds -- __init__.py:_sensor_cycle:365
2013-07-30 21:12:00,198 hello INFO Hello World! -- hello.py:<module>:3
2013-07-30 21:12:02,209 dummy WARNING Logic: dummy, File: dummy_series.py, Line: 2, Method: <module>, Exception: SmartHome instance has no attribute 'first' -- scheduler.py:_task:281
2013-07-30 21:12:02,391 Scheduler DEBUG dummy next time: 2013-07-30 21:17:02+02:00 -- scheduler.py:_next_time:238
2013-07-30 21:12:04,225 Scheduler DEBUG series next time: 2013-07-30 21:12:14+02:00 -- scheduler.py:_next_time:238
2013-07-30 21:12:12,849 SmartHome.py INFO WebSocket: incoming connection from 192.168.178.26:51312 -- __init__.py:handle_accept:115
2013-07-30 21:12:13,066 SmartHome.py DEBUG 192.168.178.26:51312 sent '{"cmd":"proto","ver":2}' -- __init__.py:json_parse:257
2013-07-30 21:12:13,077 SmartHome.py DEBUG 192.168.178.26:51312 sent '{"cmd":"monitor","items":["erdgeschoss.kueche.mpd_kueche.volume","erdgeschoss.kueche.mpd_kueche.artist","erdgeschoss.kueche.mpd_kueche.title","erdgeschoss.kueche.mpd_kueche.play","erdgeschoss.kueche.mpd_kueche.stop","erdgeschoss.kueche.mpd_kueche.ndr2","erdgeschoss.kueche.mpd_kueche.radio21","erdgeschoss.kueche.mpd_kueche.rockantenne"]}' -- __init__.py:json_parse:257
2013-07-30 21:12:14,365 Scheduler DEBUG series next time: 2013-07-30 21:12:24+02:00 -- scheduler.py:_next_time:238
2013-07-30 21:12:20,391 SmartHome.py DEBUG 192.168.178.26:51312 sent '{"cmd":"item","id":"erdgeschoss.kueche.mpd_kueche.radio21","val":"1"}' -- __init__.py:json_parse:257
2013-07-30 21:12:20,396 SmartHome.py DEBUG erdgeschoss.kueche.mpd_kueche.radio21 = True via Visu 192.168.178.26:51312 -- item.py:_update:219
2013-07-30 21:12:20,404 SmartHome.py ERROR Problem running <bound method mpd._play_file of <plugins.mpd.mpd connected hal9000:6600 at 0x239b698>>: 'mpd_file' -- item.py:_update:230
2013-07-30 21:12:22,512 SmartHome.py DEBUG 192.168.178.26:51312 sent '{"cmd":"item","id":"erdgeschoss.kueche.mpd_kueche.ndr2","val":"1"}' -- __init__.py:json_parse:257
2013-07-30 21:12:22,517 SmartHome.py DEBUG erdgeschoss.kueche.mpd_kueche.ndr2 = True via Visu 192.168.178.26:51312 -- item.py:_update:219
2013-07-30 21:12:22,525 SmartHome.py ERROR Problem running <bound method mpd._play_file of <plugins.mpd.mpd connected hal9000:6600 at 0x239b698>>: 'mpd_file' -- item.py:_update:230
2013-07-30 21:12:24,257 Scheduler DEBUG series next time: 2013-07-30 21:12:34+02:00 -- scheduler.py:_next_time:238
2013-07-30 21:12:34,352 Scheduler DEBUG series next time: 2013-07-30 21:12:44+02:00 -- scheduler.py:_next_time:238
^C2013-07-30 21:12:39,688 SmartHome.py INFO Number of Threads: 8 -- smarthome.py:stop:318
2013-07-30 21:12:39,696 SmartHome.py INFO Stop Plugins -- plugin.py:stop:68
2013-07-30 21:12:39,701 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed -- my_asynchat.py:handle_close:103
2013-07-30 21:12:39,706 SmartHome.py DEBUG Closing listen -- __init__.py:stop:147
2013-07-30 21:12:39,711 SmartHome.py INFO mpd: connection to hal9000:6600 closed -- my_asynchat.py:handle_close:103
2013-07-30 21:12:40,216 SmartHome.py INFO SmartHome.py stopped -- smarthome.py:stop:339
[erdgeschoss]
[[flur]]
name = Flur
sv_page = room
[[[licht]]]
name = Flurlicht
visu = yes
sv_widget = "{{ basic.dual('item', 'item', icon1~'message_presence.png', icon0~'message_presence_disabled.png') }} {{ device.dimmer('item', 'item.name', 'item.schalter', 'item.dimmer') }}"
[[[[schalter]]]]
[[[[dimmer]]]]
[[[[pm]]]]
[[wohnzimmer]]
name = Wohnzimmer
sv_page = room
[[[licht_decke]]]
name = Deckenbeleuchtung
visu = yes
[[[[schalter]]]]
[[[[dimmer]]]]
[[[[pm]]]]
[[[licht_stehlampe]]]
name = Stehlampe
[[[licht_kugel]]]
name = Kugellampe
[[[temp]]]
name = Temperatur
type = num
ow_addr = 28.339F88040000
ow_sensor = T
sqlite = yes
visu = yes
sv_widget = "{{ plot.period('item', 'item', 'avg', '48h') }}"
[[kueche]]
name = Küche
sv_page = room
[[[mpd_kueche]]]
name = Musikplayer
type = str
mpd_host = hal9000
mpd_port = 6600
visu = yes
sv_widget = "{% import "multimedia.html" as multimedia %}{{ multimedia.music(item, 'item.play', 'item.stop', '', '', '', 'item.volume', '', 'item.title', 'item.artist', '', '') }}{{ basic.button('item.ndr2', 'item.ndr2', 'NDR2', '', 1, '') }}{{ basic.button('item.radio21', 'item.radio21', 'Radio21', '', 1, '') }}{{ basic.button('item.rockantenne', 'item.rockantenne', 'Rock Antenne Alternative', '', 1, '') }}"
[[[[title]]]]
type = str
mpd_listen = title
visu = yes
[[[[artist]]]]
type = str
mpd_listen = artist
visu = yes
[[[[volume]]]]
type = num
mpd_listen = volume
mpd_send = volume
visu = yes
[[[[stop]]]]
type = bool
mpd_listen = stop
mpd_send = stop
visu = yes
[[[[play]]]]
type = bool
mpd_listen = play
mpd_send = play
visu = yes
[[[[ndr2]]]]
name = NDR2
type = bool
enforce_updates = yes
mpd_url = "http://ndrstream.ic.llnwd.net/stream/ndrstream_ndr2_hi_mp3"
visu = yes
[[[[radio21]]]]
name = Radio21
type = bool
mpd_url = "http://www.radio21.de/livestream/livestream.m3u"
visu = yes
[[[[rockantenne]]]]
name = Rock Antenne Alternative
type = bool
mpd_url = "http://www.rockantenne.de/webradio/channels/alternative.m3u"
visu = yes
[[hwr]]
name = HWR
sv_page = room
[[schlafzimmer]]
name = Schlafzimmer
sv_page = room
[[[temp]]]
name = Temperatur
type = num
ow_addr = 28.530988040000
ow_sensor = T
sqlite = yes
visu = yes
[[wc]]
name = WC
sv_page = room
[zentral]
name = Zentralfunktionen
sv_page = room
[[licht]]
name = Licht
sv_widget = "{{ basic.button('item', 'item.name.an', 'An', '', 1) }} {{ basic.button('item', 'item.name.aus', 'Aus', '', 0) }}"
Gruß Felix
