Ich hoffe dass ich das richtig eingefügt habe.
2013-08-17 11:06:07,761 SmartHome.py INFO Start SmartHome.py 0.9-3-g3d90e39+ -- smarthome.py:__init__:192 2013-08-17 11:06:07,766 SmartHome.py DEBUG Python 2.7.3 -- smarthome.py:__init__:193 2013-08-17 11:06:07,772 SmartHome.py INFO Init Scheduler -- scheduler.py:__init__:53 2013-08-17 11:06:07,778 SmartHome.py INFO Init Plugins -- smarthome.py:__init__:208 2013-08-17 11:06:07,787 Scheduler DEBUG creating 5 workers -- scheduler.py:run:59 2013-08-17 11:06:07,800 SmartHome.py DEBUG Plugin: knx -- plugin.py:__init__:42 2013-08-17 11:06:07,840 SmartHome.py DEBUG Plugin: ow -- plugin.py:__init__:42 2013-08-17 11:06:07,858 SmartHome.py INFO Onewire: connected to 127.0.0.1:4304 -- __init__.py:connect:67 2013-08-17 11:06:07,865 SmartHome.py DEBUG Plugin: cli -- plugin.py:__init__:42 2013-08-17 11:06:07,878 SmartHome.py DEBUG Plugin: visu -- plugin.py:__init__:42 2013-08-17 11:06:07,959 SmartHome.py DEBUG Plugin: sql -- plugin.py:__init__:42 2013-08-17 11:06:07,985 SmartHome.py DEBUG SQLite 3.7.13 -- __init__.py:__init__:60 2013-08-17 11:06:08,012 SmartHome.py DEBUG sqlite next time: 2013-08-18 03:02:00+02:00 -- scheduler.py:_next_time:238 2013-08-17 11:06:08,016 SmartHome.py DEBUG Plugin: rrd -- plugin.py:__init__:42 2013-08-17 11:06:08,114 SmartHome.py INFO Init Items -- smarthome.py:__init__:210 2013-08-17 11:06:08,140 SmartHome.py INFO Start Plugins -- plugin.py:start:63 2013-08-17 11:06:08,150 ow DEBUG 1w-disc next time: 2013-08-17 11:06:08+02:00 -- scheduler.py:_next_time:238 2013-08-17 11:06:08,177 SmartHome.py INFO Start Logics -- logic.py:__init__:32 2013-08-17 11:06:08,185 SmartHome.py DEBUG reading logics from /usr/smarthome/etc/logic.conf -- logic.py:__init__:38 2013-08-17 11:06:08,182 rrd DEBUG rrd next time: 2013-08-17 11:07:48+02:00 -- scheduler.py:_next_time:238 2013-08-17 11:06:08,201 SmartHome.py DEBUG Logic: hello -- logic.py:__init__:45 2013-08-17 11:06:08,206 visu DEBUG series next time: 2013-08-17 11:06:17+02:00 -- scheduler.py:_next_time:238 2013-08-17 11:06:08,253 SmartHome.py DEBUG Logic: dummy -- logic.py:__init__:45 2013-08-17 11:06:08,263 SmartHome.py DEBUG dummy next time: 2013-08-17 11:06:17+02:00 -- scheduler.py:_next_time:238 2013-08-17 11:06:08,334 sh.con DEBUG knx: enable group monitor -- __init__.py:handle_connect:110 2013-08-17 11:06:08,403 sh.con INFO KNX: connected to 127.0.0.1:6720 -- my_asynchat.py:connect:69 2013-08-17 11:06:08,398 sh.gc DEBUG Garbage collector: collected 87 objects. -- smarthome.py:_garbage_collection:345 2013-08-17 11:06:08,471 1w-disc INFO 1-Wire: 28.CD3AF8040000 with sensors: T11, T10, T, T12, T9 -- __init__.py:_discovery:390 2013-08-17 11:06:08,478 1w-disc INFO 1-Wire: 28.5FCCF8040000 with sensors: T11, T10, T, T12, T9 -- __init__.py:_discovery:390 2013-08-17 11:06:08,516 Scheduler DEBUG 1w-disc next time: 2013-08-17 11:16:08+02:00 -- scheduler.py:_next_time:238 2013-08-17 11:06:08,539 Scheduler DEBUG sh.gc next time: 2013-08-18 02:04:00+02:00 -- scheduler.py:_next_time:238 2013-08-17 11:06:08,660 ow DEBUG 1w-sen next time: 2013-08-17 11:06:08+02:00 -- scheduler.py:_next_time:238 2013-08-17 11:06:08,752 1w-sen DEBUG 1-Wire: no path found for marco.sensor2 -- __init__.py:_sensor_cycle:348 2013-08-17 11:06:08,756 1w-sen DEBUG 1-Wire: no path found for marco.sensor1 -- __init__.py:_sensor_cycle:348 2013-08-17 11:06:08,760 1w-sen DEBUG cycle takes 0.00837898254395 seconds -- __init__.py:_sensor_cycle:365 2013-08-17 11:06:08,949 Scheduler DEBUG 1w-sen next time: 2013-08-17 11:11:08+02:00 -- scheduler.py:_next_time:238 2013-08-17 11:06:12,184 hello INFO Hello World! -- hello.py:<module>:3 2013-08-17 11:06:17,036 dummy WARNING Logic: dummy, File: dummy_series.py, Line: 2, Method: <module>, Exception: SmartHome instance has no attribute 'first' -- scheduler.py:_task:281 2013-08-17 11:06:17,224 Scheduler DEBUG dummy next time: 2013-08-17 11:11:17+02:00 -- scheduler.py:_next_time:238 2013-08-17 11:06:17,231 Scheduler DEBUG series next time: 2013-08-17 11:06:27+02:00 -- scheduler.py:_next_time:238 2013-08-17 11:06:27,322 Scheduler DEBUG series next time: 2013-08-17 11:06:37+02:00 -- scheduler.py:_next_time:238 2013-08-17 11:06:37,211 Scheduler DEBUG series next time: 2013-08-17 11:06:47+02:00 -- scheduler.py:_next_time:238 2013-08-17 11:06:47,304 Scheduler DEBUG series next time: 2013-08-17 11:06:57+02:00 -- scheduler.py:_next_time:238 2013-08-17 11:06:57,397 Scheduler DEBUG series next time: 2013-08-17 11:07:07+02:00 -- scheduler.py:_next_time:238 2013-08-17 11:07:07,289 Scheduler DEBUG series next time: 2013-08-17 11:07:17+02:00 -- scheduler.py:_next_time:238 2013-08-17 11:07:17,383 Scheduler DEBUG series next time: 2013-08-17 11:07:27+02:00 -- scheduler.py:_next_time:238 2013-08-17 11:07:27,275 Scheduler DEBUG series next time: 2013-08-17 11:07:37+02:00 -- scheduler.py:_next_time:238 2013-08-17 11:07:37,368 Scheduler DEBUG series next time: 2013-08-17 11:07:47+02:00 -- scheduler.py:_next_time:238 2013-08-17 11:07:47,259 Scheduler DEBUG series next time: 2013-08-17 11:07:57+02:00 -- scheduler.py:_next_time:238 2013-08-17 11:07:48,274 Scheduler DEBUG rrd next time: 2013-08-17 11:12:48+02:00 -- scheduler.py:_next_time:238 2013-08-17 11:07:57,360 Scheduler DEBUG series next time: 2013-08-17 11:08:07+02:00 -- scheduler.py:_next_time:238 2013-08-17 11:08:07,251 Scheduler DEBUG series next time: 2013-08-17 11:08:17+02:00 -- scheduler.py:_next_time:238 2013-08-17 11:08:17,347 Scheduler DEBUG series next time: 2013-08-17 11:08:27+02:00 -- scheduler.py:_next_time:238 2013-08-17 11:08:27,238 Scheduler DEBUG series next time: 2013-08-17 11:08:37+02:00 -- scheduler.py:_next_time:238 2013-08-17 11:08:37,332 Scheduler DEBUG series next time: 2013-08-17 11:08:47+02:00 -- scheduler.py:_next_time:238 2013-08-17 11:08:47,225 Scheduler DEBUG series next time: 2013-08-17 11:08:57+02:00 -- scheduler.py:_next_time:238 2013-08-17 11:08:57,321 Scheduler DEBUG series next time: 2013-08-17 11:09:07+02:00 -- scheduler.py:_next_time:238 2013-08-17 11:09:07,212 Scheduler DEBUG series next time: 2013-08-17 11:09:17+02:00 -- scheduler.py:_next_time:238 2013-08-17 11:09:17,304 Scheduler DEBUG series next time: 2013-08-17 11:09:27+02:00 -- scheduler.py:_next_time:238 ^C2013-08-17 11:09:24,668 SmartHome.py INFO Number of Threads: 7 -- smarthome.py:stop:318 2013-08-17 11:09:24,675 SmartHome.py INFO Stop Plugins -- plugin.py:stop:68 2013-08-17 11:09:24,679 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed -- my_asynchat.py:handle_close:103 2013-08-17 11:09:24,683 SmartHome.py DEBUG Closing listen -- __init__.py:stop:147 2013-08-17 11:09:25,188 SmartHome.py INFO SmartHome.py stopped -- smarthome.py:stop:339
