Hier das neue DebugLog File:
2013-08-12 22:14:34,192 SmartHome.py INFO Start SmartHome.py 0.9-10-g63eb637+ -- smarthome.py:__init__:192
2013-08-12 22:14:34,197 SmartHome.py DEBUG Python 2.7.3 -- smarthome.py:__init__:193
2013-08-12 22:14:34,203 SmartHome.py INFO Init Scheduler -- scheduler.py:__init__:53
2013-08-12 22:14:34,209 SmartHome.py INFO Init Plugins -- smarthome.py:__init__:208
2013-08-12 22:14:34,217 Scheduler DEBUG creating 5 workers -- scheduler.py:run:59
2013-08-12 22:14:34,232 SmartHome.py DEBUG Plugin: knx -- plugin.py:__init__:42
2013-08-12 22:14:34,276 SmartHome.py DEBUG Plugin: ow -- plugin.py:__init__:42
2013-08-12 22:14:34,291 SmartHome.py ERROR Onewire: could not connect to 127.0.0.1:4304: [Errno 111] Connection refused -- __init__.py:connect:62
2013-08-12 22:14:34,297 SmartHome.py DEBUG Plugin: cli -- plugin.py:__init__:42
2013-08-12 22:14:34,310 SmartHome.py DEBUG Plugin: visu -- plugin.py:__init__:42
2013-08-12 22:14:34,391 SmartHome.py DEBUG Plugin: sql -- plugin.py:__init__:42
2013-08-12 22:14:34,418 SmartHome.py DEBUG SQLite 3.7.13 -- __init__.py:__init__:60
2013-08-12 22:14:34,445 SmartHome.py DEBUG sqlite next time: 2013-08-13 03:02:00+02:00 -- scheduler.py:_next_time:238
2013-08-12 22:14:34,449 SmartHome.py DEBUG Plugin: rrd -- plugin.py:__init__:42
2013-08-12 22:14:34,550 SmartHome.py INFO Init Items -- smarthome.py:__init__:210
2013-08-12 22:14:34,735 SmartHome.py DEBUG knx: second.sleeping.light.level listen on 3/2/14 -- __init__.py:parse_item:243
2013-08-12 22:14:35,225 SmartHome.py DEBUG knx: Light listen on 3/2/12 -- __init__.py:parse_item:243
2013-08-12 22:14:35,345 SmartHome.py DEBUG knx: room1.bel1 listen on and init with 13/3/17 -- __init__.py:parse_item:252
2013-08-12 22:14:35,355 SmartHome.py DEBUG knx: room1.bel2 listen on and init with 13/3/18 -- __init__.py:parse_item:252
2013-08-12 22:14:35,363 SmartHome.py DEBUG knx: room1.bel3 listen on and init with 13/3/19 -- __init__.py:parse_item:252
2013-08-12 22:14:35,372 SmartHome.py DEBUG knx: room1.bel4 listen on and init with 13/3/20 -- __init__.py:parse_item:252
2013-08-12 22:14:35,494 SmartHome.py INFO Start Plugins -- plugin.py:start:63
2013-08-12 22:14:35,504 ow DEBUG 1w-disc next time: 2013-08-12 22:14:35+02:00 -- scheduler.py:_next_time:238
2013-08-12 22:14:35,524 SmartHome.py INFO Start Logics -- logic.py:__init__:32
2013-08-12 22:14:35,528 SmartHome.py DEBUG reading logics from /usr/smarthome/etc/logic.conf -- logic.py:__init__:38
2013-08-12 22:14:35,533 rrd DEBUG rrd next time: 2013-08-12 22:16:15+02:00 -- scheduler.py:_next_time:238
2013-08-12 22:14:35,545 SmartHome.py DEBUG Logic: hello -- logic.py:__init__:45
2013-08-12 22:14:35,591 SmartHome.py DEBUG Logic: dummy -- logic.py:__init__:45
2013-08-12 22:14:35,601 SmartHome.py DEBUG dummy next time: 2013-08-12 22:14:44+02:00 -- scheduler.py:_next_time:238
2013-08-12 22:14:35,652 sh.con DEBUG knx: enable group monitor -- __init__.py:handle_connect:119
2013-08-12 22:14:35,666 sh.con DEBUG knx: init read -- __init__.py:handle_connect:125
2013-08-12 22:14:35,714 sh.con INFO KNX: connected to 127.0.0.1:6720 -- my_asynchat.py:connect:69
2013-08-12 22:14:35,791 Scheduler DEBUG 1w-disc next time: 2013-08-12 22:24:35+02:00 -- scheduler.py:_next_time:238
2013-08-12 22:14:35,862 sh.gc DEBUG Garbage collector: collected 903 objects. -- smarthome.py:_garbage_collection:345
2013-08-12 22:14:36,016 Scheduler DEBUG sh.gc next time: 2013-08-13 02:04:00+02:00 -- scheduler.py:_next_time:238
2013-08-12 22:14:36,611 SmartHome.py DEBUG typ: 112, len: 2, telegram: 0 70 -- __init__.py:parse_telegram:166
2013-08-12 22:14:36,615 SmartHome.py DEBUG typ: 38, len: 2, telegram: 0 26 -- __init__.py:parse_telegram:166
2013-08-12 22:14:36,620 SmartHome.py DEBUG 0.0.0 read 13/3/17 -- __init__.py:parse_telegram:211
2013-08-12 22:14:36,624 SmartHome.py DEBUG 0.0.0 read 13/3/18 -- __init__.py:parse_telegram:211
2013-08-12 22:14:36,631 SmartHome.py DEBUG 0.0.0 read 13/3/19 -- __init__.py:parse_telegram:211
2013-08-12 22:14:36,636 SmartHome.py DEBUG 0.0.0 read 13/3/20 -- __init__.py:parse_telegram:211
2013-08-12 22:14:36,641 SmartHome.py DEBUG knx: 1.1.50 set 13/3/17 to True -- __init__.py:parse_telegram:198
2013-08-12 22:14:36,646 SmartHome.py DEBUG room1.bel1 = True via KNX 1.1.50 -- item.py:_update:219
2013-08-12 22:14:36,654 SmartHome.py DEBUG knx: 1.1.50 set 13/3/18 to True -- __init__.py:parse_telegram:198
2013-08-12 22:14:36,659 SmartHome.py DEBUG room1.bel2 = True via KNX 1.1.50 -- item.py:_update:219
2013-08-12 22:14:36,667 SmartHome.py DEBUG knx: 1.1.50 set 13/3/20 to True -- __init__.py:parse_telegram:198
2013-08-12 22:14:36,671 SmartHome.py DEBUG room1.bel4 = True via KNX 1.1.50 -- item.py:_update:219
2013-08-12 22:14:37,923 visu DEBUG series next time: 2013-08-12 22:14:43+02:00 -- scheduler.py:_next_time:238
2013-08-12 22:14:39,091 hello INFO Hello World! -- hello.py:<module>:3
2013-08-12 22:14:43,293 Scheduler DEBUG series next time: 2013-08-12 22:14:53+02:00 -- scheduler.py:_next_time:238
2013-08-12 22:14:44,128 dummy DEBUG first.living.temperature = 20 via Logic None -- item.py:_update:219
2013-08-12 22:14:44,319 Scheduler DEBUG dummy next time: 2013-08-12 22:19:44+02:00 -- scheduler.py:_next_time:238
2013-08-12 22:14:45,830 dummy DEBUG first.living.humidity = 47 via Logic None -- item.py:_update:219
2013-08-12 22:14:47,759 dummy DEBUG second.sleeping.temperature = 20 via Logic None -- item.py:_update:219
2013-08-12 22:14:50,668 dummy DEBUG second.bath.temperature = 23 via Logic None -- item.py:_update:219
2013-08-12 22:14:52,792 SmartHome.py INFO WebSocket: incoming connection from 192.168.1.32:56891 -- __init__.py:handle_accept:115
2013-08-12 22:14:53,090 SmartHome.py DEBUG 192.168.1.32:56891 sent '{"cmd":"proto","ver":2}' -- __init__.py:json_parse:257
2013-08-12 22:14:53,283 Scheduler DEBUG series next time: 2013-08-12 22:15:03+02:00 -- scheduler.py:_next_time:238
2013-08-12 22:14:56,508 SmartHome.py DEBUG 192.168.1.32:56891 sent '{"cmd":"monitor","items":["room1.bel1","room1.bel2","room1.bel3","room1.bel4"]}' -- __init__.py:json_parse:257
2013-08-12 22:15:03,388 Scheduler DEBUG series next time: 2013-08-12 22:15:13+02:00 -- scheduler.py:_next_time:238
2013-08-12 22:15:04,135 SmartHome.py DEBUG WebSocket: closing connection to 192.168.1.32:56891. -- __init__.py:rfc6455_parse:380
2013-08-12 22:15:13,289 Scheduler DEBUG series next time: 2013-08-12 22:15:23+02:00 -- scheduler.py:_next_time:238
