Aber somit geht's jetzt.
subprocess.call("sudo shutdown -hP -t 5 now", shell=True)
VG!!
subprocess.call([I]args[/I], [I]*[/I], [I]stdin=None[/I], [I]stdout=None[/I], [I]stderr=None[/I], [I]shell=False[/I])
[COLOR=#C65D09][B]>>> [/B][/COLOR]subprocess[COLOR=#666666].[/COLOR]call([[COLOR=#4070A0]"ls"[/COLOR], [COLOR=#4070A0]"-l"[/COLOR]]) [COLOR=#303030]0[/COLOR] [COLOR=#C65D09][B]>>> [/B][/COLOR]subprocess[COLOR=#666666].[/COLOR]call([COLOR=#4070A0]"exit 1"[/COLOR], shell[COLOR=#666666]=[/COLOR][COLOR=#007020][B]True[/B][/COLOR]) [COLOR=#303030]1[/COLOR]
[shutdown]
filename = shutdown.py
watch_item = zentral.shutdown # monitor for changes
# /usr/local/smarthome/items/zentral.conf
[zentral]
name = Zentral
[[shutdown]]
type=bool
knx_dpt=1
knx_listen=7/0/0
#!/usr/bin/python3.2
# logics/smarthome.py
# Logik zum Herunterfahren vom Smarthome.py
# 2015-04-01 Version 1.0
# shell Kommando: sudo shutdown -hP -t 5 now
import time
logger.info('Das System wird in 10 Sekunden heruntergefahren.')
time.sleep(10) # delays for 10 seconds
subprocess.call(["/usr/smarthome/bin/smarthome.py --stop"])
subprocess.call(["sudo shutdown -hP -t 5 now"])
2015-04-01 21:43:40,725 DEBUG Main Item zentral.shutdown = True via KNX 0.0.0 7/0/0 -- item.py:__update:363
2015-04-01 21:43:40,733 DEBUG Main Triggering shutdown - by: Item source: zentral.shutdown dest: None value: True -- scheduler.py:trigger:162
2015-04-01 21:43:40,739 INFO shutdown Das System wird in 10 Sekunden heruntergefahren. -- shutdown.py:<module>:13
2015-04-01 21:43:40,749 INFO Main knx: 1.1.254 set 7/0/0 to True -- __init__.py:parse_telegram:190
2015-04-01 21:43:50,791 ERROR shutdown Logic: shutdown, File: /usr/lib/python3.2/subprocess.py, Line: 1371, Method: _execute_child, Exception: [Errno 2] No such file or directory: '/usr/smarthome/bin/smarthome.py --stop' -- scheduler.py:_task:334
Traceback (most recent call last):
File "/usr/smarthome/lib/scheduler.py", line 327, in _task
exec(obj.bytecode)
File "/usr/smarthome/logics/shutdown.py", line 20, in <module>
File "/usr/lib/python3.2/subprocess.py", line 471, in call
return Popen(*popenargs, **kwargs).wait()
File "/usr/lib/python3.2/subprocess.py", line 745, in __init__
restore_signals, start_new_session)
File "/usr/lib/python3.2/subprocess.py", line 1371, in _execute_child
raise child_exception_type(errno_num, err_msg)
OSError: [Errno 2] No such file or directory: '/usr/smarthome/bin/smarthome.py --stop'
