- √ - requested invalid item
    Hi
    vielleicht kann jemand sehen was ich in der config verkehrt mache.
    bei manchen items kommt "requested invalid item"
    *.config Datei
    [OG]
        [[Flur]]
            name = Flur OG
            sv_page = room
            [[[licht_Decke]]]
                name = Deckenlicht
                type = bool
                visu = yes
                sv_widget = "{{ device.dimmer('item', 'item.name', 'item', 'item.dimmen') }}"
                knx_dpt = 1
                knx_cache = 2/0/115
                knx_send = 2/1/115
                [[[[dimmen]]]]
                    type = num
                    visu = yes
                    knx_dpt = 5
                    knx_cache = 2/4/115
                    knx_send = 2/2/115
            [[[licht_Aussen]]]
                name = Aussenlicht
                type = bool
                visu = yes
                sv_widget = "{{ basic.switch('item', 'item.name',icon1~'light_light.png',icon0~'light_light.png' ) }} Aussenlicht 1"
                knx_dpt = 1
                knx_cache = 2/0/116
                knx_send = 2/1/116
            [[[SD]]]
                name = Aussensteckdosen
                type = bool
                visu = yes
                sv_widget = "{{ basic.switch('item', 'item.name',icon1~'light_light.png',icon0~'light_light.png' ) }} Aussensteckdosen"
                knx_dpt = 1
                knx_cache = 2/0/119
                knx_send = 2/1/119
            [[[raffstore1]]]
                    name = Raffstore
                    sv_widget = "{{ device.blind('item', 'item.name', 'item.move', 'item.stop', 'item.position') }}"
                    [[[[move]]]]
                    type = bool
                    knx_dpt = 1
                    knx_send = 3/1/4
                    knx_cache = 3/0/4
                    visu = yes
                    [[[[stop]]]]
                    type = bool
                    knx_dpt = 1
                    knx_send = 3/2/4
                    knx_cache = 3/0/4
                    visu = yes
                    [[[[position]]]]
                    type = num
                    knx_dpt = 5
                    knx_send = 3/3/4
                    knx_cache = 3/4/4
                    visu = yes
            [[[temperature]]]
                name = Raumtemperatur
                type = num
                visu = yes
                knx_dpt = 9
                knx_cache = 7/0/21
                sv_widget = "{{ device.rtr('item', 'item.name', 'item', 'item.set', 'item.mode', 'item.night', 'item.frost', 'item.state') }}"
                sqlite = yes
                [[[[set]]]]
                    type = num
                    visu = yes
                [[[[mode]]]]
                            type = num
                            visu = yes
                         [[[[night]]]]
                            type = num
                            visu = yes
                         [[[[frost]]]]
                            type = num
                            visu = yes
                         [[[[state]]]]
                            type = num
                            visu = yes
                            history = true
                 [[[Temp_plot]]]
                    type = num
                    visu = yes
                    sv_widget = "{{ plot.period('item', 'OG.Flur.temperature', 'avg', '24h') }}"
    logfile beim seitenaufruf
    [CODE]
    2013-09-21 18:28:55,266 Scheduler DEBUG series next time: 2013-09-21 18:29:05+02:00 -- scheduler.py:_next_time:238
    2013-09-21 18:29:04,913 SmartHome.py INFO WebSocket: incoming connection from 192.168.120.123:49502 -- __init__.py:handle_accept:115
    2013-09-21 18:29:05,034 SmartHome.py DEBUG 192.168.120.123:49502 sent '{"cmd":"proto","ver":2}' -- __init__.py:json_parse:257
    2013-09-21 18:29:05,044 SmartHome.py DEBUG 192.168.120.123:49502 sent '{"cmd":"monitor","items":["OG.Flur.licht_Decke","OG.Flur.licht_Decke.dimmen" ,"Aussenlicht","Aussensteckdosen","OG.Flur.raffsto re1.move","OG.Flur.raffstore1.position","OG.Flur.r affstore1.stop","OG.Flur.temperature","OG.Flur.tem perature.set","OG.Flur.temperature.mode","OG.Flur. temperature.night","OG.Flur.temperature.frost","OG .Flur.temperature.state","OG.Flur.temperature.avg. 24h.0"]}' -- __init__.py:json_parse:257
    2013-09-21 18:29:05,048 SmartHome.py INFO Client 192.168.120.123:49502 requested invalid item: Aussenlicht -- __init__.py:json_parse:281
    2013-09-21 18:29:05,058 SmartHome.py INFO Client 192.168.120.123:49502 requested invalid item: OG.Flur.temperature.avg.24h.0 -- __init__.py:json_parse:281
    2013-09-21 18:29:05,064 SmartHome.py INFO Client 192.168.120.123:49502 requested invalid item: Aussensteckdosen -- __init__.py:json_parse:281
    2013-09-21 18:29:05,073 SmartHome.py DEBUG 192.168.120.123:49502 sent '{"cmd":"series","item":"OG.Flur.temperature","ser ies":"avg","start":"24h"}' -- __init__.py:json_parse:257
    2013-09-21 18:29:05,362 Scheduler DEBUG series next time: 2013-09-21 18:29:15+02:00 -- scheduler.py:_next_time:238
    logfile Startup
      Start SmartHome.py 0.9-3-g3d90e39 -- smarthome.py:__init__:192
    2013-09-21 18:32:36,771 SmartHome.py DEBUG    Python 2.7.3 -- smarthome.py:__init__:193
    2013-09-21 18:32:36,776 SmartHome.py INFO     Init Scheduler -- scheduler.py:__init__:53
    2013-09-21 18:32:36,780 SmartHome.py INFO     Init Plugins -- smarthome.py:__init__:208
    2013-09-21 18:32:36,785 Scheduler    DEBUG    creating 5 workers -- scheduler.py:run:59
    2013-09-21 18:32:36,799 SmartHome.py DEBUG    Plugin: knx -- plugin.py:__init__:42
    2013-09-21 18:32:36,835 SmartHome.py DEBUG    Plugin: cli -- plugin.py:__init__:42
    2013-09-21 18:32:36,855 SmartHome.py DEBUG    Plugin: visu -- plugin.py:__init__:42
    2013-09-21 18:32:36,938 SmartHome.py DEBUG    Plugin: sql -- plugin.py:__init__:42
    2013-09-21 18:32:36,963 SmartHome.py DEBUG    SQLite 3.7.13 -- __init__.py:__init__:60
    2013-09-21 18:32:36,989 SmartHome.py DEBUG    sqlite next time: 2013-09-22 03:02:00+02:00 -- scheduler.py:_next_time:238
    2013-09-21 18:32:36,993 SmartHome.py DEBUG    Plugin: rrd -- plugin.py:__init__:42
    2013-09-21 18:32:37,088 SmartHome.py INFO     Init Items -- smarthome.py:__init__:210
    2013-09-21 18:32:37,141 SmartHome.py DEBUG    knx: OG.Flur.licht_Decke.dimmen listen on and init with cache 2/4/115 -- __init__.py:parse_item:249
    2013-09-21 18:32:37,145 SmartHome.py DEBUG    knx: Deckenlicht listen on and init with cache 2/0/115 -- __init__.py:parse_item:249
    2013-09-21 18:32:37,151 SmartHome.py DEBUG    knx: Aussenlicht listen on and init with cache 2/0/116 -- __init__.py:parse_item:249
    2013-09-21 18:32:37,158 SmartHome.py DEBUG    knx: Aussensteckdosen listen on and init with cache 2/0/119 -- __init__.py:parse_item:249
    2013-09-21 18:32:37,167 SmartHome.py DEBUG    knx: OG.Flur.raffstore1.move listen on and init with cache 3/0/4 -- __init__.py:parse_item:249
    2013-09-21 18:32:37,173 SmartHome.py DEBUG    knx: OG.Flur.raffstore1.stop listen on and init with cache 3/0/4 -- __init__.py:parse_item:249
    2013-09-21 18:32:37,179 SmartHome.py DEBUG    knx: OG.Flur.raffstore1.position listen on and init with cache 3/4/4 -- __init__.py:parse_item:249
    2013-09-21 18:32:37,202 SmartHome.py DEBUG    knx: Raumtemperatur listen on and init with cache 7/0/21 -- __init__.py:parse_item:249
    2013-09-21 18:32:37,211 SmartHome.py INFO     Start Plugins -- plugin.py:start:63
    2013-09-21 18:32:37,237 SmartHome.py INFO     Start Logics -- logic.py:__init__:32
    2013-09-21 18:32:37,239 SmartHome.py DEBUG    reading logics from /usr/smarthome/etc/logic.conf -- logic.py:__init__:38
    2013-09-21 18:32:37,247 rrd          DEBUG    rrd next time: 2013-09-21 18:34:17+02:00 -- scheduler.py:_next_time:238
    2013-09-21 18:32:37,265 visu         DEBUG    series next time: 2013-09-21 18:32:44+02:00 -- scheduler.py:_next_time:238
    2013-09-21 18:32:37,342 sh.con       DEBUG    knx: read cache -- __init__.py:handle_connect:106
    2013-09-21 18:32:37,340 sh.gc        DEBUG    Garbage collector: collected 74 objects. -- smarthome.py:_garbage_collection:345
    2013-09-21 18:32:37,366 sh.con       DEBUG    knx: enable group monitor -- __init__.py:handle_connect:110
    2013-09-21 18:32:37,370 sh.con       INFO     KNX: connected to 127.0.0.1:6720 -- my_asynchat.py:connect:69
    2013-09-21 18:32:37,509 Scheduler    DEBUG    sh.gc next time: 2013-09-22 02:04:00+02:00 -- scheduler.py:_next_time:238
    Bei basic.switch ist der zweite Parameter das Item... du gibst dort aber statt 'item' 'item.name' an. Daher wird das Item 'Aussenlicht' angefragt, dass es so nicht gibt. Schau dir die smartVISU Doku zum basic.switch nochmal an und alles wird gut werden
    Mit freundlichen Grüßen
    Niko Will
      Danke
      wer lesen ist klar im Vorteil. Hatte copy paste gemacht.
      Grüße Stromie
        Im Übrigen kam der Fehler "requested invalid item" auch bei den Plots, ist mit 2.7 behoben.
        Join smartVISU on facebook. Web: smartvisu.de.
        Dir gefällt smartVISU? Bitte spenden für die Weiterentwicklung.
