Running out of worker threads
    ich lasse nun seit einiger Zeit dmarthome.py laufen, und habe zum zweiten mal einen Fehler bekommen, nachdem dann keine weiteren Einträge der Temperaturen vorgenommen werden. Hier mal das entsprechende logfile von dem Tag. an dem der Fehler auftraht (Auszug):
    2013-09-28 04:52:19 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
    2013-09-28 04:52:22 sh.con INFO KNX: connected to 127.0.0.1:6720
    2013-09-28 04:52:25 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
    2013-09-28 04:52:32 sh.con INFO KNX: connected to 127.0.0.1:6720
    2013-09-28 04:53:22 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
    2013-09-28 04:53:22 sh.con ERROR KNX: could not connect to 127.0.0.1:6720: deque index out of range
    2013-09-28 05:13:08 Scheduler INFO Adding worker thread. Total: 6
    2013-09-28 05:13:08 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, sh.con, Thread-6
    2013-09-28 05:18:12 Scheduler INFO Adding worker thread. Total: 7
    2013-09-28 05:18:12 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, sh.con, Thread-7
    2013-09-28 05:23:18 Scheduler INFO Adding worker thread. Total: 8
    2013-09-28 05:23:18 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, sh.con, Thread-8
    2013-09-28 05:28:22 Scheduler INFO Adding worker thread. Total: 9
    2013-09-28 05:28:22 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, sh.con, Thread-9
    2013-09-28 05:33:28 Scheduler INFO Adding worker thread. Total: 10
    2013-09-28 05:33:28 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, sh.con, Thread-10
    2013-09-28 05:38:32 Scheduler INFO Adding worker thread. Total: 11
    2013-09-28 05:38:32 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, sh.con, Thread-11
    2013-09-28 05:43:38 Scheduler INFO Adding worker thread. Total: 12
    2013-09-28 05:43:38 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, Thread-12
    2013-09-28 05:48:42 Scheduler INFO Adding worker thread. Total: 13
    2013-09-28 05:48:42 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, Thread-13
    2013-09-28 05:53:48 Scheduler INFO Adding worker thread. Total: 14
    2013-09-28 05:53:48 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, Thread-14
    2013-09-28 05:58:52 Scheduler INFO Adding worker thread. Total: 15
    2013-09-28 05:58:52 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, Thread-15
    2013-09-28 06:03:58 Scheduler INFO Adding worker thread. Total: 16
    2013-09-28 06:03:58 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, Thread-16
    2013-09-28 06:09:02 Scheduler INFO Adding worker thread. Total: 17
    2013-09-28 06:09:02 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, Thread-17
    2013-09-28 06:14:08 Scheduler INFO Adding worker thread. Total: 18
    2013-09-28 06:14:08 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, Thread-18
    2013-09-28 06:19:12 Scheduler INFO Adding worker thread. Total: 19
    2013-09-28 06:19:12 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, Thread-19
    2013-09-28 06:24:18 Scheduler INFO Adding worker thread. Total: 20
    2013-09-28 06:24:18 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, Thread-20
    2013-09-28 06:29:21 Scheduler INFO Adding worker thread. Total: 21
    2013-09-28 06:29:21 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-21
    2013-09-28 06:34:22 Scheduler INFO Adding worker thread. Total: 22
    2013-09-28 06:34:22 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-22
    2013-09-28 06:39:28 Scheduler INFO Adding worker thread. Total: 23
    2013-09-28 06:39:28 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-23
    2013-09-28 06:44:32 Scheduler INFO Adding worker thread. Total: 24
    2013-09-28 06:44:32 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-24
    2013-09-28 06:49:38 Scheduler INFO Adding worker thread. Total: 25
    2013-09-28 06:49:38 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-25
    2013-09-28 06:54:42 Scheduler INFO Adding worker thread. Total: 26
    2013-09-28 06:54:42 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-26
    2013-09-28 06:59:48 Scheduler INFO Adding worker thread. Total: 27
    2013-09-28 06:59:48 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-27
    2013-09-28 07:04:52 Scheduler INFO Adding worker thread. Total: 28
    2013-09-28 07:04:52 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-28
    2013-09-28 07:09:58 Scheduler INFO Adding worker thread. Total: 29
    2013-09-28 07:09:58 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-29
    2013-09-28 07:15:02 Scheduler INFO Adding worker thread. Total: 30
    2013-09-28 07:15:02 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-30
    2013-09-28 07:20:08 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
    2013-09-28 07:20:08 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 29
    2013-09-28 07:20:08 Scheduler INFO Adding worker thread. Total: 31
    2013-09-28 07:20:08 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-31
    2013-09-28 07:25:12 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
    2013-09-28 07:25:12 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 30
    2013-09-28 07:25:12 Scheduler INFO Adding worker thread. Total: 32
    2013-09-28 07:25:12 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-32
    2013-09-28 07:30:18 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
    2013-09-28 07:30:18 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 31
    2013-09-28 07:30:18 Scheduler INFO Adding worker thread. Total: 33
    2013-09-28 07:30:18 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-33
    2013-09-28 07:35:22 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
    2013-09-28 07:35:22 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 32
    2013-09-28 07:35:22 Scheduler INFO Adding worker thread. Total: 34
    Nach einem Neustart ist wieder alled ok bis ein paar Tage später es wieder passiert (Hatte dieses Problem nun zum 2.mal.
    Hier noch das log-file nach dem neu-start (..und update)
    2013-09-30 08:11:05 SmartHome.py INFO Start SmartHome.py 0.9-20-g35ccac6
    2013-09-30 08:11:05 SmartHome.py INFO Init Scheduler
    2013-09-30 08:11:05 SmartHome.py INFO Init Plugins
    2013-09-30 08:11:05 SmartHome.py INFO Onewire: connected to 127.0.0.1:4304
    2013-09-30 08:11:05 SmartHome.py INFO Init Items
    2013-09-30 08:11:08 SmartHome.py INFO Start Plugins
    2013-09-30 08:11:08 SmartHome.py INFO Start Logics
    2013-09-30 08:11:09 sh.con INFO KNX: connected to 127.0.0.1:6720
    2013-09-30 08:11:10 1w-disc INFO 1-Wire: 28.442EC0040000 with sensors: T11, T10, T, T12, T9
    2013-09-30 08:11:10 1w-disc INFO 1-Wire: 28.442FC0040000 with sensors: T11, T10, T, T12, T9
    2013-09-30 08:11:10 1w-disc INFO 1-Wire: 28.E263BF040000 with sensors: T11, T10, T, T12, T9
    2013-09-30 08:11:10 1w-disc INFO 1-Wire: 28.8A47BF040000 with sensors: T11, T10, T, T12, T9
    2013-09-30 08:11:10 1w-disc INFO 1-Wire: 28.B6FFCD040000 with sensors: T11, T10, T, T12, T9
    2013-09-30 08:11:10 1w-disc INFO 1-Wire: 28.59A9BF040000 with sensors: T11, T10, T, T12, T9
    2013-09-30 08:11:10 1w-disc INFO 1-Wire: 28.39E1BF040000 with sensors: T11, T10, T, T12, T9
    2013-09-30 08:11:10 1w-disc INFO 1-Wire: 28.35D4E0040000 with sensors: T11, T10, T, T12, T9
    2013-09-30 08:11:11 1w-disc INFO 1-Wire: 28.33E8BF040000 with sensors: T11, T10, T, T12, T9
    2013-09-30 08:11:11 1w-disc INFO 1-Wire: 28.3369E0040000 with sensors: T11, T10, T, T12, T9
    2013-09-30 08:11:11 1w-disc INFO 1-Wire: 28.AB51C0040000 with sensors: T11, T10, T, T12, T9
    2013-09-30 08:11:11 1w-disc INFO 1-Wire: 28.DBC2E0040000 with sensors: T11, T10, T, T12, T9
    2013-09-30 08:11:11 1w-disc INFO 1-Wire: 28.AFADE0040000 with sensors: T11, T10, T, T12, T9
    2013-09-30 08:11:11 1w-disc INFO 1-Wire: 28.FFF2BF040000 with sensors: T11, T10, T, T12, T9
    2013-09-30 08:11:11 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
    2013-09-30 08:11:12 hello INFO Hello World!
    2013-09-30 08:11:19 sh.con INFO KNX: connected to 127.0.0.1:6720
    2013-09-30 08:11:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
    2013-09-30 08:11:39 sh.con INFO KNX: connected to 127.0.0.1:6720
    2013-09-30 08:12:10 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
    2013-09-30 08:12:15 SmartHome.py INFO WebSocket: incoming connection from 192.168.2.45:58365
    2013-09-30 08:12:19 sh.con INFO KNX: connected to 127.0.0.1:6720
    2013-09-30 08:12:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
    2013-09-30 08:12:39 sh.con INFO KNX: connected to 127.0.0.1:6720
    2013-09-30 08:13:10 SmartHome.py INFO Client 192.168.2.45:58365 requested invalid item: Keller.Heizung.Temperatur-KWL.temperatur_ALHaus.min.1d.0
    2013-09-30 08:13:10 SmartHome.py INFO Client 192.168.2.45:58365 requested invalid item: Keller.Heizung.Temperatur-KWL.temperatur_ZLAussen.min.1d.0
    2013-09-30 08:13:10 SmartHome.py INFO Client 192.168.2.45:58365 requested invalid item: Keller.Heizung.Wasser.temperatur-PufferUnten.min.1w.0
    2013-09-30 08:13:10 SmartHome.py INFO Client 192.168.2.45:58365 requested invalid item: Keller.Heizung.Temperatur-Heizkreis.temperatur-FBVorlauf.min.1d.0
    2013-09-30 08:13:10 SmartHome.py INFO Client 192.168.2.45:58365 requested invalid item: Keller.Heizung.Temperatur-Heizkreis.temperatur-FBRuecklauf.min.1d.0
    2013-09-30 08:13:10 SmartHome.py INFO Client 192.168.2.45:58365 requested invalid item: Keller.Heizung.Sole.temperatur-SoleVorlauf.min.1w.0
    2013-09-30 08:13:10 SmartHome.py INFO Client 192.168.2.45:58365 requested invalid item: Keller.Heizung.Wasser.temperatur-Pufferoben.min.1d.0
    2013-09-30 08:13:10 SmartHome.py INFO Client 192.168.2.45:58365 requested invalid item: Keller.Heizung.Wasser.temperatur-Warmwasser.min.1w.0
    2013-09-30 08:13:10 SmartHome.py INFO Client 192.168.2.45:58365 requested invalid item: Keller.Weinkeller.Temperatur.night
    2013-09-30 08:13:10 SmartHome.py INFO Client 192.168.2.45:58365 requested invalid item: Keller.Heizung.Temperatur-KWL.temperatur_AL.min.1d.0
    2013-09-30 08:13:10 SmartHome.py INFO Client 192.168.2.45:58365 requested invalid item: Keller.AZ.Temperatur.state.avg.1d.0
    2013-09-30 08:13:10 SmartHome.py INFO Client 192.168.2.45:58365 requested invalid item: Keller.Weinkeller.Temperatur.state.avg.1d.0
    2013-09-30 08:13:10 SmartHome.py INFO Client 192.168.2.45:58365 requested invalid item: Keller.Heizung.Wasser.temperatur-PufferMitte.min.1d.0
    2013-09-30 08:13:10 SmartHome.py INFO Client 192.168.2.45:58365 requested invalid item: Keller.Heizung.Temperatur-Heizkreis.temperatur-FBRuecklauf.min.1w.0
    2013-09-30 08:13:10 SmartHome.py INFO Client 192.168.2.45:58365 requested invalid item: Keller.Heizung.Temperatur-WP.temperatur-WPRuecklauf.min.1d.0
    2013-09-30 08:13:10 SmartHome.py INFO Client 192.168.2.45:58365 requested invalid item: Keller.Heizung.Wasser.temperatur-Warmwasser.min.1d.0
    2013-09-30 08:13:10 SmartHome.py INFO Client 192.168.2.45:58365 requested invalid item: Keller.Heizung.Temperatur-KWL.temperatur_ZLAussen.min.1w.0
    2013-09-30 08:13:10 SmartHome.py INFO Client 192.168.2.45:58365 requested invalid item: Keller.AZ.Temperatur.set.avg.1d.0
    2013-09-30 08:13:10 SmartHome.py INFO Client 192.168.2.45:58365 requested invalid item: Keller.Heizung.Temperatur-KWL.temperatur_AL.min.1w.0
    2013-09-30 08:13:10 SmartHome.py INFO Client 192.168.2.45:58365 requested invalid item: Keller.Heizung.Temperatur-KWL.temperatur_ZL.min.1w.0
    2013-09-30 08:13:10 SmartHome.py INFO Client 192.168.2.45:58365 requested invalid item: Keller.Server.Temperatur.Temperatur Raspberry.pi.min.1w.0
    2013-09-30 08:13:10 SmartHome.py INFO Client 192.168.2.45:58365 requested invalid item: Keller.AZ.Temperatur.avg.1d.0
    2013-09-30 08:13:10 SmartHome.py INFO Client 192.168.2.45:58365 requested invalid item: Keller.Weinkeller.Temperatur.avg.1d.0
    2013-09-30 08:13:10 SmartHome.py INFO Client 192.168.2.45:58365 requested invalid item: Keller.Heizung.Wasser.temperatur-Pufferoben.min.1w.0
    2013-09-30 08:13:10 SmartHome.py INFO Client 192.168.2.45:58365 requested invalid item: Keller.AZ.Temperatur.max.6h.0
    2013-09-30 08:13:10 SmartHome.py INFO Client 192.168.2.45:58365 requested invalid item: Keller.AZ.Temperatur.min.6h.0
    2013-09-30 08:13:10 SmartHome.py INFO Client 192.168.2.45:58365 requested invalid item: Keller.Weinkeller.Temperatur.mode
    2013-09-30 08:13:10 SmartHome.py INFO Client 192.168.2.45:58365 requested invalid item: Keller.Weinkeller.Temperatur.avg.6h.0
    2013-09-30 08:13:10 SmartHome.py INFO Client 192.168.2.45:58365 requested invalid item: Keller.Heizung.Sole.temperatur-SoleVorlauf.min.1d.0
    2013-09-30 08:13:10 SmartHome.py INFO Client 192.168.2.45:58365 requested invalid item: Keller.Heizung.Temperatur-KWL.temperatur_ALHaus.min.1w.0
    2013-09-30 08:13:10 SmartHome.py INFO Client 192.168.2.45:58365 requested invalid item: Keller.Weinkeller.Temperatur.set.avg.1d.0
    2013-09-30 08:13:10 SmartHome.py INFO Client 192.168.2.45:58365 requested invalid item: Keller.AZ.Temperatur.avg.6h.0
    2013-09-30 08:13:10 SmartHome.py INFO Client 192.168.2.45:58365 requested invalid item: Keller.Weinkeller.Temperatur.max.6h.0
    2013-09-30 08:13:10 SmartHome.py INFO Client 192.168.2.45:58365 requested invalid item: Keller.Server.Temperatur.Temperatur Raspberry.pi.min.1d.0
    2013-09-30 08:13:10 SmartHome.py INFO Client 192.168.2.45:58365 requested invalid item: Keller.Weinkeller.Temperatur.min.6h.0
    2013-09-30 08:13:11 SmartHome.py INFO Client 192.168.2.45:58365 requested invalid item: Keller.Heizung.Temperatur-Heizkreis.temperatur-FBVorlauf.min.1w.0
    2013-09-30 08:13:11 SmartHome.py INFO Client 192.168.2.45:58365 requested invalid item: Keller.Heizung.Sole.temperatur-SoleRuecklauf.min.1w.0
    2013-09-30 08:13:11 SmartHome.py INFO Client 192.168.2.45:58365 requested invalid item: Keller.AZ.Fenster
    2013-09-30 08:13:11 SmartHome.py INFO Client 192.168.2.45:58365 requested invalid item: Keller.Weinkeller.Temperatur.frost
    2013-09-30 08:13:11 SmartHome.py INFO Client 192.168.2.45:58365 requested invalid item: Keller.Heizung.Temperatur-WP.temperatur-WPVorlauf.min.1w.0
    2013-09-30 08:13:11 SmartHome.py INFO Client 192.168.2.45:58365 requested invalid item: Keller.Heizung.Wasser.temperatur-PufferMitte.min.1w.0
    2013-09-30 08:13:11 SmartHome.py INFO Client 192.168.2.45:58365 requested invalid item: Keller.Heizung.Temperatur-WP.temperatur-WPRuecklauf.min.1w.0
    2013-09-30 08:13:11 SmartHome.py INFO Client 192.168.2.45:58365 requested invalid item: Keller.Weinkeller.Temperatur.set
    2013-09-30 08:13:11 SmartHome.py INFO Client 192.168.2.45:58365 requested invalid item: Keller.Heizung.Temperatur-WP.temperatur-WPVorlauf.min.1d.0
    2013-09-30 08:13:11 SmartHome.py INFO Client 192.168.2.45:58365 requested invalid item: Keller.Heizung.Temperatur-KWL.temperatur_ZL.min.1d.0
    2013-09-30 08:13:11 SmartHome.py INFO Client 192.168.2.45:58365 requested invalid item: Keller.Heizung.Wasser.temperatur-PufferUnten.min.1d.0
    2013-09-30 08:13:11 SmartHome.py INFO Client 192.168.2.45:58365 requested invalid item: Keller.Heizung.Sole.temperatur-SoleRuecklauf.min.1d.0
    2013-09-30 08:13:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
    2013-09-30 08:13:39 sh.con INFO KNX: connected to 127.0.0.1:6720
    2013-09-30 08:14:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
    2013-09-30 08:14:39 sh.con INFO KNX: connected to 127.0.0.1:6720
    2013-09-30 08:14:57 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
    2013-09-30 08:14:59 sh.con INFO KNX: connected to 127.0.0.1:6720
    2013-09-30 08:15:04 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
    2013-09-30 08:15:09 sh.con INFO KNX: connected to 127.0.0.1:6720
    2013-09-30 08:15:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
    2013-09-30 08:15:39 sh.con INFO KNX: connected to 127.0.0.1:6720
    2013-09-30 08:16:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
    2013-09-30 08:16:39 sh.con INFO KNX: connected to 127.0.0.1:6720
    2013-09-30 08:17:18 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
    2013-09-30 08:17:19 sh.con INFO KNX: connected to 127.0.0.1:6720
    2013-09-30 08:17:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
    2013-09-30 08:17:39 sh.con INFO KNX: connected to 127.0.0.1:6720
    2013-09-30 08:18:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
    2013-09-30 08:18:39 sh.con INFO KNX: connected to 127.0.0.1:6720
    2013-09-30 08:19:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
    2013-09-30 08:19:39 sh.con INFO KNX: connected to 127.0.0.1:6720
    2013-09-30 08:20:05 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
    2013-09-30 08:20:09 sh.con INFO KNX: connected to 127.0.0.1:6720
    2013-09-30 08:20:12 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
    2013-09-30 08:20:19 sh.con INFO KNX: connected to 127.0.0.1:6720
    2013-09-30 08:20:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
    2013-09-30 08:20:39 sh.con INFO KNX: connected to 127.0.0.1:6720
    2013-09-30 08:21:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
    2013-09-30 08:21:39 sh.con INFO KNX: connected to 127.0.0.1:6720
    2013-09-30 08:22:26 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
    2013-09-30 08:22:29 sh.con INFO KNX: connected to 127.0.0.1:6720
    2013-09-30 08:22:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
    2013-09-30 08:22:39 sh.con INFO KNX: connected to 127.0.0.1:6720
    2013-09-30 08:23:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
    2013-09-30 08:23:39 sh.con INFO KNX: connected to 127.0.0.1:6720
    2013-09-30 08:23:45 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
    2013-09-30 08:23:49 sh.con INFO KNX: connected to 127.0.0.1:6720
    2013-09-30 08:24:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
    2013-09-30 08:24:39 sh.con INFO KNX: connected to 127.0.0.1:6720
    2013-09-30 08:25:13 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
    2013-09-30 08:25:19 sh.con INFO KNX: connected to 127.0.0.1:6720
    2013-09-30 08:25:19 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
    2013-09-30 08:25:29 sh.con INFO KNX: connected to 127.0.0.1:6720
    2013-09-30 08:25:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
    2013-09-30 08:25:39 sh.con INFO KNX: connected to 127.0.0.1:6720
    2013-09-30 08:26:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
    2013-09-30 08:26:39 sh.con INFO KNX: connected to 127.0.0.1:6720
    2013-09-30 08:27:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
    2013-09-30 08:27:39 sh.con INFO KNX: connected to 127.0.0.1:6720
    2013-09-30 08:28:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
    2013-09-30 08:28:39 sh.con INFO KNX: connected to 127.0.0.1:6720
    2013-09-30 08:28:53 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
    2013-09-30 08:28:59 sh.con INFO KNX: connected to 127.0.0.1:6720
    2013-09-30 08:29:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
    2013-09-30 08:29:39 sh.con INFO KNX: connected to 127.0.0.1:6720
    2013-09-30 08:30:21 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
    2013-09-30 08:30:29 sh.con INFO KNX: connected to 127.0.0.1:6720
    2013-09-30 08:30:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
    2013-09-30 08:30:39 sh.con INFO KNX: connected to 127.0.0.1:6720
    2013-09-30 08:31:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
    2013-09-30 08:31:39 sh.con INFO KNX: connected to 127.0.0.1:6720
    Lasse das System wieder laufen um den Fehler ggf. zu reproduzieren.
    Georg
    Kenne ich 1:1. Schau mal hier:
    https://knx-user-forum.de/smarthome-...tuerzt-ab.html
      Hallo Georg,
      danke für den Bugreport. Welche Version setzt Du denn ein?
      Am besten die erste Zeile beim Start von SH.py angeben.
      Was bedeutet Neustart? Rebootest Du den Pi? Oder startest Du nur SH.py neu?
      Es sieht so aus, als ob der eibd nicht verfügbar ist und bei dem ersten Mal hat sich das KNX-Plugin anscheinend daran aufgehangen und den Bus blockiert. Das 1-Wire Plugin wurde davon blockiert und es wurden immer neue Threads verbraucht.
      Woran sich das KNX-Plugin gestört hat, kann ich noch nicht sagen.
      Ab 1.0 kann ich den Fehlerfall aber besser handhaben, da Python 3.2 mir neue Möglichkeiten bietet.
      Berichte bitte weiter hier.
      Danke
      Marcus
        Zitat von mknx Beitrag anzeigen
        Hallo Georg,
        Danke
        Marcus
        Hallo Marcus,
        dismal ging es etwas schneller, vorher lief der SH.PY über Tage stabil.
        Version: aktuellste Version, habe heute vor dem re-start ein update gemacht.
        zur weiteren Eingrenzung bin dann Schrittweise vorgegangen:
        1. Verschte lampe aus Visu zu schalten, keine Reaktion
        2. eibd neu gestartet. Keine Veränderung
        3. Smarthome.py neu gestartet. Alles funktionert wieder.
        Für mich sieht das so aus, als ob irgendein counter überläuft ("deque index out of range")
        Hier das komplette Log-File
        2013-09-30 08:32:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 08:32:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 08:32:41 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 08:32:49 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 08:33:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 08:33:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 08:34:01 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 08:34:09 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 08:34:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 08:34:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 08:35:28 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 08:35:29 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 08:35:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 08:35:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 08:36:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 08:36:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 08:37:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 08:37:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 08:37:49 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 08:37:59 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 08:38:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 08:38:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 08:39:09 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 08:39:19 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 08:39:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 08:39:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 08:40:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 08:40:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 08:40:43 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 08:40:49 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 08:41:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 08:41:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 08:42:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 08:42:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 08:42:57 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 08:42:59 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 08:43:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 08:43:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 08:44:17 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 08:44:19 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 08:44:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 08:44:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 08:45:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 08:45:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 08:45:44 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 08:45:49 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 08:45:50 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 08:45:59 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 08:46:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 08:46:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 08:47:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 08:47:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 08:48:04 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 08:48:09 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 08:48:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 08:48:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 08:49:25 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 08:49:29 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 08:49:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 08:49:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 08:50:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 08:50:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 08:50:52 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 08:50:59 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 08:51:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 08:51:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 08:52:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 08:52:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 08:53:12 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 08:53:19 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 08:53:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 08:53:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 08:54:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 08:54:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 08:55:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 08:55:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 08:55:59 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 08:56:09 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 08:56:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 08:56:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 08:57:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 08:57:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 08:58:20 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 08:58:29 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 08:58:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 08:58:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 08:59:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 08:59:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 08:59:41 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 08:59:49 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:00:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:00:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:01:07 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:01:09 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:01:14 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:01:19 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:01:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:01:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:02:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:02:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:03:28 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:03:29 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:03:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:03:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:04:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:04:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:04:49 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:04:59 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:05:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:05:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:06:15 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:06:19 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:06:21 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:06:29 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:06:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:06:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:07:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:07:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:08:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:08:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:09:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:09:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:09:57 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:09:59 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:10:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:10:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:11:23 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:11:29 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:11:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:11:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:12:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:12:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:13:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:13:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:13:43 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:13:49 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:14:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:14:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:15:04 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:15:09 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:15:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:15:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:16:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:16:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:17:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:17:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:18:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:18:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:18:51 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:18:59 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:19:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:19:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:20:12 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:20:19 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:20:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:20:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:21:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:21:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:21:45 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:21:49 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:22:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:22:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:23:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:23:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:23:59 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:24:09 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:24:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:24:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:25:20 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:25:29 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:25:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:25:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:26:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:26:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:26:46 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:26:49 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:26:52 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:26:59 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:27:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:27:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:28:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:28:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:29:07 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:29:09 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:29:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:29:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:30:28 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:30:29 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:30:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:30:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:31:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:31:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:31:54 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:31:59 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:32:00 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:32:09 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:32:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:32:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:33:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:33:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:34:14 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:34:19 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:34:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:34:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:35:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:35:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:36:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:36:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:37:01 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:37:09 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:37:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:37:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:38:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:38:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:39:22 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:39:29 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:39:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:39:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:40:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:40:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:40:44 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:40:49 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:41:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:41:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:41:42 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:41:49 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:42:09 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:42:19 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:42:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:42:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:43:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:43:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:44:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:44:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:45:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:45:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:45:52 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:45:59 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:46:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:46:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:47:17 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:47:19 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:47:23 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:47:29 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:47:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:47:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:48:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:48:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:49:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:49:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:50:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:50:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:51:00 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:51:09 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:51:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:51:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:52:25 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:52:29 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:52:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:52:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:53:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:53:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:54:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:54:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:54:45 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:54:49 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:55:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:55:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:56:08 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:56:09 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:56:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:56:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:57:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:57:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:57:40 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:57:49 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:58:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:58:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:59:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:59:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 09:59:53 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 09:59:59 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:00:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:00:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:01:16 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:01:19 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:01:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:01:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:02:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:02:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:02:40 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:02:49 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:03:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:03:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:04:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:04:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:05:01 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:05:09 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:05:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:05:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:06:24 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:06:29 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:06:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:06:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:07:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:07:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:07:48 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:07:49 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:07:55 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:07:59 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:08:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:08:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:09:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:09:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:10:09 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:10:19 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:10:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:10:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:11:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:11:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:12:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:12:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:12:56 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:12:59 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:13:02 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:13:09 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:13:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:13:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:14:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:14:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:15:17 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:15:19 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:15:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:15:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:16:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:16:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:16:40 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:16:49 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:17:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:17:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:18:03 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:18:09 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:18:10 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:18:19 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:18:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:18:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:19:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:19:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:20:24 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:20:29 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:20:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:20:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:21:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:21:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:21:47 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:21:49 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:22:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:22:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:23:11 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:23:19 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:23:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:23:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:24:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:24:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:25:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:25:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:26:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:26:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:26:55 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:26:59 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:27:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:27:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:28:19 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:28:29 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:28:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:28:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:29:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:29:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:30:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:30:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:30:40 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:30:49 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:31:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:31:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:32:03 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:32:09 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:32:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:32:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:33:27 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:33:29 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:33:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:33:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:34:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:34:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:35:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:35:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:35:48 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:35:49 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:36:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:36:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:37:11 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:37:19 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:37:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:37:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:38:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:38:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:38:41 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:38:49 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:39:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:39:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:40:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:40:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:40:55 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:40:59 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:41:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:41:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:42:19 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:42:29 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:42:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:42:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:43:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:43:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:43:42 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:43:49 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:43:49 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:43:59 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:44:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:44:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:45:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:45:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:46:03 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:46:09 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:46:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:46:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:47:27 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:47:29 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:47:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:47:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:48:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:48:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:48:50 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:48:59 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:49:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:49:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:50:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:50:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:51:11 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:51:19 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:51:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:51:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:52:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:52:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:53:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:53:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:53:58 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:53:59 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:54:04 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:54:09 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:54:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:54:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:55:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:55:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:56:19 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:56:29 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:56:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:56:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:57:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:57:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:57:43 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:57:49 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:58:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:58:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:59:05 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:59:09 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:59:12 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:59:19 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 10:59:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 10:59:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 11:00:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 11:00:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 11:00:58 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 11:00:59 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 11:01:27 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 11:01:29 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 11:01:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 11:01:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 11:02:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 11:02:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 11:02:51 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 11:02:59 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 11:03:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 11:03:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 11:04:13 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 11:04:19 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 11:04:20 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 11:04:29 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 11:04:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 11:04:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 11:05:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 11:05:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 11:06:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 11:06:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 11:07:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 11:07:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 11:07:59 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 11:08:09 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 11:08:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 11:08:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 11:09:21 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 11:09:29 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 11:09:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 11:09:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 11:10:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 11:10:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 11:11:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 11:11:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 11:11:42 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 11:11:49 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 11:12:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 11:12:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 11:13:07 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 11:13:09 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 11:13:30 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 11:13:39 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 11:14:29 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 11:14:29 sh.con ERROR KNX: could not connect to 127.0.0.1:6720: deque index out of range
        2013-09-30 11:31:38 Scheduler INFO Adding worker thread. Total: 6
        2013-09-30 11:31:38 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, Scheduler, sh.con, 1w-sen, Thread-6
        2013-09-30 11:36:39 Scheduler INFO Adding worker thread. Total: 7
        2013-09-30 11:36:39 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, Scheduler, sh.con, 1w-sen, 1w-sen, Thread-7
        2013-09-30 11:41:48 Scheduler INFO Adding worker thread. Total: 8
        2013-09-30 11:41:48 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, sh.con, 1w-sen, 1w-sen, Thread-8
        2013-09-30 11:46:49 Scheduler INFO Adding worker thread. Total: 9
        2013-09-30 11:46:49 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, sh.con, 1w-sen, 1w-sen, Thread-9
        2013-09-30 11:51:58 Scheduler INFO Adding worker thread. Total: 10
        2013-09-30 11:51:58 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, sh.con, 1w-sen, 1w-sen, Thread-10
        2013-09-30 11:56:59 Scheduler INFO Adding worker thread. Total: 11
        2013-09-30 11:56:59 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, Thread-11
        2013-09-30 12:02:08 Scheduler INFO Adding worker thread. Total: 12
        2013-09-30 12:02:08 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-12
        2013-09-30 12:07:09 Scheduler INFO Adding worker thread. Total: 13
        2013-09-30 12:07:09 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-13
        2013-09-30 12:12:18 Scheduler INFO Adding worker thread. Total: 14
        2013-09-30 12:12:18 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-14
        2013-09-30 12:17:19 Scheduler INFO Adding worker thread. Total: 15
        2013-09-30 12:17:19 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-15
        2013-09-30 12:22:28 Scheduler INFO Adding worker thread. Total: 16
        2013-09-30 12:22:28 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-16
        2013-09-30 12:27:29 Scheduler INFO Adding worker thread. Total: 17
        2013-09-30 12:27:29 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-17
        2013-09-30 12:32:38 Scheduler INFO Adding worker thread. Total: 18
        2013-09-30 12:32:38 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-18
        2013-09-30 12:37:39 Scheduler INFO Adding worker thread. Total: 19
        2013-09-30 12:37:39 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-19
        2013-09-30 12:42:48 Scheduler INFO Adding worker thread. Total: 20
        2013-09-30 12:42:48 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-20
        2013-09-30 12:47:48 Scheduler INFO Adding worker thread. Total: 21
        2013-09-30 12:47:48 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-21
        2013-09-30 12:52:49 Scheduler INFO Adding worker thread. Total: 22
        2013-09-30 12:52:49 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-22
        2013-09-30 12:57:58 Scheduler INFO Adding worker thread. Total: 23
        2013-09-30 12:57:58 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-23
        2013-09-30 13:02:59 Scheduler INFO Adding worker thread. Total: 24
        2013-09-30 13:02:59 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-24
        2013-09-30 13:08:08 Scheduler INFO Adding worker thread. Total: 25
        2013-09-30 13:08:08 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-25
        2013-09-30 13:13:09 Scheduler INFO Adding worker thread. Total: 26
        2013-09-30 13:13:09 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-26
        2013-09-30 13:18:18 Scheduler INFO Adding worker thread. Total: 27
        2013-09-30 13:18:18 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-27
        2013-09-30 13:23:19 Scheduler INFO Adding worker thread. Total: 28
        2013-09-30 13:23:19 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-28
        2013-09-30 13:28:28 Scheduler INFO Adding worker thread. Total: 29
        2013-09-30 13:28:28 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-29
        2013-09-30 13:33:29 Scheduler INFO Adding worker thread. Total: 30
        2013-09-30 13:33:29 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-30
        2013-09-30 13:38:38 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 13:38:38 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 29
        2013-09-30 13:38:38 Scheduler INFO Adding worker thread. Total: 31
        2013-09-30 13:38:38 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-31
        2013-09-30 13:43:39 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 13:43:39 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 30
        2013-09-30 13:43:39 Scheduler INFO Adding worker thread. Total: 32
        2013-09-30 13:43:39 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-32
        2013-09-30 13:48:48 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 13:48:48 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 31
        2013-09-30 13:48:48 Scheduler INFO Adding worker thread. Total: 33
        2013-09-30 13:48:48 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-33
        2013-09-30 13:53:49 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 13:53:49 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 32
        2013-09-30 13:53:49 Scheduler INFO Adding worker thread. Total: 34
        2013-09-30 13:53:49 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-34
        2013-09-30 13:58:58 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 13:58:58 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 33
        2013-09-30 13:58:58 Scheduler INFO Adding worker thread. Total: 35
        2013-09-30 13:58:58 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-35
        2013-09-30 14:03:59 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 14:03:59 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 34
        2013-09-30 14:03:59 Scheduler INFO Adding worker thread. Total: 36
        2013-09-30 14:03:59 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-36
        2013-09-30 14:09:08 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 14:09:08 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 35
        2013-09-30 14:09:08 Scheduler INFO Adding worker thread. Total: 37
        2013-09-30 14:09:08 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-37
        2013-09-30 14:14:09 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 14:14:09 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 36
        2013-09-30 14:14:09 Scheduler INFO Adding worker thread. Total: 38
        2013-09-30 14:14:09 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-38
        2013-09-30 14:19:18 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 14:19:18 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 37
        2013-09-30 14:19:18 Scheduler INFO Adding worker thread. Total: 39
        2013-09-30 14:19:18 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-39
        2013-09-30 14:24:19 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 14:24:19 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 38
        2013-09-30 14:24:19 Scheduler INFO Adding worker thread. Total: 40
        2013-09-30 14:24:19 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-40
        2013-09-30 14:29:28 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 14:29:28 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 39
        2013-09-30 14:29:28 Scheduler INFO Adding worker thread. Total: 41
        2013-09-30 14:29:28 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-41
        2013-09-30 14:34:29 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 14:34:29 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 40
        2013-09-30 14:34:29 Scheduler INFO Adding worker thread. Total: 42
        2013-09-30 14:34:29 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-42
        2013-09-30 14:39:38 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 14:39:38 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 41
        2013-09-30 14:39:38 Scheduler INFO Adding worker thread. Total: 43
        2013-09-30 14:39:38 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-43
        2013-09-30 14:44:39 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 14:44:39 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 42
        2013-09-30 14:44:39 Scheduler INFO Adding worker thread. Total: 44
        2013-09-30 14:44:39 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-44
        2013-09-30 14:49:48 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 14:49:48 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 43
        2013-09-30 14:49:48 Scheduler INFO Adding worker thread. Total: 45
        2013-09-30 14:49:48 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-45
        2013-09-30 14:54:49 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 14:54:49 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 44
        2013-09-30 14:54:49 Scheduler INFO Adding worker thread. Total: 46
        2013-09-30 14:54:49 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-46
        2013-09-30 14:59:58 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 14:59:58 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 45
        2013-09-30 14:59:58 Scheduler INFO Adding worker thread. Total: 47
        2013-09-30 14:59:58 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-47
        2013-09-30 15:04:59 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 15:04:59 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 46
        2013-09-30 15:04:59 Scheduler INFO Adding worker thread. Total: 48
        2013-09-30 15:04:59 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-48
        2013-09-30 15:10:08 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 15:10:08 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 47
        2013-09-30 15:10:08 Scheduler INFO Adding worker thread. Total: 49
        2013-09-30 15:10:08 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-49
        2013-09-30 15:15:09 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 15:15:09 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 48
        2013-09-30 15:15:09 Scheduler INFO Adding worker thread. Total: 50
        2013-09-30 15:15:09 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-50
        2013-09-30 15:20:18 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 15:20:18 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 49
        2013-09-30 15:20:18 Scheduler INFO Adding worker thread. Total: 51
        2013-09-30 15:20:18 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-51
        2013-09-30 15:25:19 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 15:25:19 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 50
        2013-09-30 15:25:19 Scheduler INFO Adding worker thread. Total: 52
        2013-09-30 15:25:19 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-52
        2013-09-30 15:30:28 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 15:30:28 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 51
        2013-09-30 15:30:28 Scheduler INFO Adding worker thread. Total: 53
        2013-09-30 15:30:28 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-53
        2013-09-30 15:35:29 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 15:35:29 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 52
        2013-09-30 15:35:29 Scheduler INFO Adding worker thread. Total: 54
        2013-09-30 15:35:29 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-54
        2013-09-30 15:40:38 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 15:40:38 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 53
        2013-09-30 15:40:38 Scheduler INFO Adding worker thread. Total: 55
        2013-09-30 15:40:38 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-55
        2013-09-30 15:45:39 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 15:45:39 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 54
        2013-09-30 15:45:39 Scheduler INFO Adding worker thread. Total: 56
        2013-09-30 15:45:39 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-56
        2013-09-30 15:50:48 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 15:50:48 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 55
        2013-09-30 15:50:48 Scheduler INFO Adding worker thread. Total: 57
        2013-09-30 15:50:48 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-57
        2013-09-30 15:55:49 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 15:55:49 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 56
        2013-09-30 15:55:49 Scheduler INFO Adding worker thread. Total: 58
        2013-09-30 15:55:49 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-58
        2013-09-30 16:00:58 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 16:00:58 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 57
        2013-09-30 16:00:58 Scheduler INFO Adding worker thread. Total: 59
        2013-09-30 16:00:58 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-59
        2013-09-30 16:05:59 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 16:05:59 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 58
        2013-09-30 16:05:59 Scheduler INFO Adding worker thread. Total: 60
        2013-09-30 16:05:59 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-60
        2013-09-30 16:11:08 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 16:11:08 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 59
        2013-09-30 16:11:08 Scheduler INFO Adding worker thread. Total: 61
        2013-09-30 16:11:08 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-61
        2013-09-30 16:16:09 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 16:16:09 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 60
        2013-09-30 16:16:09 Scheduler INFO Adding worker thread. Total: 62
        2013-09-30 16:16:09 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-62
        2013-09-30 16:21:09 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 16:21:09 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 61
        2013-09-30 16:21:09 Scheduler INFO Adding worker thread. Total: 63
        2013-09-30 16:21:09 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-63
        2013-09-30 16:26:14 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 16:26:14 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 62
        2013-09-30 16:26:14 Scheduler INFO Adding worker thread. Total: 64
        2013-09-30 16:26:14 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-64
        2013-09-30 16:28:58 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 16:28:58 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 63
        2013-09-30 16:28:58 Scheduler INFO Adding worker thread. Total: 65
        2013-09-30 16:28:58 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-65
        2013-09-30 16:36:19 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 16:36:19 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 64
        2013-09-30 16:36:19 Scheduler INFO Adding worker thread. Total: 66
        2013-09-30 16:36:19 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-66
        2013-09-30 16:39:09 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 16:39:09 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 65
        2013-09-30 16:39:09 Scheduler INFO Adding worker thread. Total: 67
        2013-09-30 16:39:09 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-67
        2013-09-30 16:46:29 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 16:46:29 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 66
        2013-09-30 16:46:29 Scheduler INFO Adding worker thread. Total: 68
        2013-09-30 16:46:29 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-68
        2013-09-30 16:49:28 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 16:49:28 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 67
        2013-09-30 16:49:28 Scheduler INFO Adding worker thread. Total: 69
        2013-09-30 16:49:28 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-69
        2013-09-30 16:56:39 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 16:56:39 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 68
        2013-09-30 16:56:39 Scheduler INFO Adding worker thread. Total: 70
        2013-09-30 16:56:39 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-70
        2013-09-30 16:59:39 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 16:59:39 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 69
        2013-09-30 16:59:39 Scheduler INFO Adding worker thread. Total: 71
        2013-09-30 16:59:39 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-71
        2013-09-30 17:06:49 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 17:06:49 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 70
        2013-09-30 17:06:49 Scheduler INFO Adding worker thread. Total: 72
        2013-09-30 17:06:49 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-72
        2013-09-30 17:09:58 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 17:09:58 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 71
        2013-09-30 17:09:58 Scheduler INFO Adding worker thread. Total: 73
        2013-09-30 17:09:58 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-73
        2013-09-30 17:16:59 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 17:16:59 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 72
        2013-09-30 17:16:59 Scheduler INFO Adding worker thread. Total: 74
        2013-09-30 17:16:59 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-74
        2013-09-30 17:20:09 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 17:20:09 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 73
        2013-09-30 17:20:09 Scheduler INFO Adding worker thread. Total: 75
        2013-09-30 17:20:09 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-75
        2013-09-30 17:27:09 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 17:27:09 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 74
        2013-09-30 17:27:09 Scheduler INFO Adding worker thread. Total: 76
        2013-09-30 17:27:09 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-76
        2013-09-30 17:30:28 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 17:30:28 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 75
        2013-09-30 17:30:28 Scheduler INFO Adding worker thread. Total: 77
        2013-09-30 17:30:28 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-77
        2013-09-30 17:37:19 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 17:37:19 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 76
        2013-09-30 17:37:19 Scheduler INFO Adding worker thread. Total: 78
        2013-09-30 17:37:19 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-78
        2013-09-30 17:40:39 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 17:40:39 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 77
        2013-09-30 17:40:39 Scheduler INFO Adding worker thread. Total: 79
        2013-09-30 17:40:39 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-79
        2013-09-30 17:47:29 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 17:47:29 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 78
        2013-09-30 17:47:29 Scheduler INFO Adding worker thread. Total: 80
        2013-09-30 17:47:29 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-80
        2013-09-30 17:50:58 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 17:50:58 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 79
        2013-09-30 17:50:58 Scheduler INFO Adding worker thread. Total: 81
        2013-09-30 17:50:58 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-81
        2013-09-30 17:57:39 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 17:57:39 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 80
        2013-09-30 17:57:39 Scheduler INFO Adding worker thread. Total: 82
        2013-09-30 17:57:39 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-82
        2013-09-30 18:01:08 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 18:01:08 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 81
        2013-09-30 18:01:08 Scheduler INFO Adding worker thread. Total: 83
        2013-09-30 18:01:08 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-83
        2013-09-30 18:07:48 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 18:07:48 Scheduler INFO Threads: SmartHome.py: 1, Scheduler: 1, sh.con: 1, 1w-sen: 82
        2013-09-30 18:07:48 Scheduler INFO Adding worker thread. Total: 84
        2013-09-30 18:07:48 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-84
        2013-09-30 18:11:11 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 18:11:11 Scheduler INFO Threads: SmartHome.py: 1, sh.con: 1, Scheduler: 1, 1w-sen: 83
        2013-09-30 18:11:11 Scheduler INFO Adding worker thread. Total: 85
        2013-09-30 18:11:11 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-85
        2013-09-30 18:12:59 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 18:12:59 Scheduler INFO Threads: SmartHome.py: 1, sh.con: 1, Scheduler: 1, 1w-sen: 84
        2013-09-30 18:12:59 Scheduler INFO Adding worker thread. Total: 86
        2013-09-30 18:12:59 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-86
        2013-09-30 18:22:58 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 18:22:58 Scheduler INFO Threads: SmartHome.py: 1, sh.con: 1, Scheduler: 1, 1w-sen: 85
        2013-09-30 18:22:58 Scheduler INFO Adding worker thread. Total: 87
        2013-09-30 18:22:58 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-87
        2013-09-30 18:26:38 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 18:26:38 Scheduler INFO Threads: SmartHome.py: 1, sh.con: 1, Scheduler: 1, 1w-sen: 86
        2013-09-30 18:26:38 Scheduler INFO Adding worker thread. Total: 88
        2013-09-30 18:26:38 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-88
        2013-09-30 18:28:29 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 18:28:29 Scheduler INFO Threads: SmartHome.py: 1, sh.con: 1, Scheduler: 1, 1w-sen: 87
        2013-09-30 18:28:29 Scheduler INFO Adding worker thread. Total: 89
        2013-09-30 18:28:29 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-89
        2013-09-30 18:38:18 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 18:38:18 Scheduler INFO Threads: SmartHome.py: 1, sh.con: 1, Scheduler: 1, 1w-sen: 88
        2013-09-30 18:38:18 Scheduler INFO Adding worker thread. Total: 90
        2013-09-30 18:38:18 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-90
        2013-09-30 18:41:49 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 18:41:49 Scheduler INFO Threads: SmartHome.py: 1, sh.con: 1, Scheduler: 1, 1w-sen: 89
        2013-09-30 18:41:49 Scheduler INFO Adding worker thread. Total: 91
        2013-09-30 18:41:49 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-91
        2013-09-30 18:43:58 Scheduler ERROR Needing more worker threads than the specified maximum of 30!
        2013-09-30 18:43:58 Scheduler INFO Threads: SmartHome.py: 1, sh.con: 1, Scheduler: 1, 1w-sen: 90
        2013-09-30 18:43:58 Scheduler INFO Adding worker thread. Total: 92
        2013-09-30 18:43:58 Scheduler INFO Current Threads: SmartHome.py, 1w-sen, 1w-sen, 1w-sen, Scheduler, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, sh.con, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, 1w-sen, Thread-92
        2013-09-30 18:49:28 SmartHome.py INFO Start SmartHome.py 0.9-20-g35ccac6
        2013-09-30 18:49:28 SmartHome.py INFO Init Scheduler
        2013-09-30 18:49:28 SmartHome.py INFO Init Plugins
        2013-09-30 18:49:28 SmartHome.py INFO Onewire: connected to 127.0.0.1:4304
        2013-09-30 18:49:29 SmartHome.py INFO Init Items
        2013-09-30 18:49:30 SmartHome.py INFO Start Plugins
        2013-09-30 18:49:30 SmartHome.py INFO Start Logics
        2013-09-30 18:49:30 sh.con INFO KNX: connected to 127.0.0.1:6720
        2013-09-30 18:49:32 1w-disc INFO 1-Wire: 28.442EC0040000 with sensors: T11, T10, T, T12, T9
        2013-09-30 18:49:32 1w-disc INFO 1-Wire: 28.442FC0040000 with sensors: T11, T10, T, T12, T9
        2013-09-30 18:49:32 1w-disc INFO 1-Wire: 28.E263BF040000 with sensors: T11, T10, T, T12, T9
        2013-09-30 18:49:32 1w-disc INFO 1-Wire: 28.8A47BF040000 with sensors: T11, T10, T, T12, T9
        2013-09-30 18:49:32 1w-disc INFO 1-Wire: 28.B6FFCD040000 with sensors: T11, T10, T, T12, T9
        2013-09-30 18:49:32 1w-disc INFO 1-Wire: 28.59A9BF040000 with sensors: T11, T10, T, T12, T9
        2013-09-30 18:49:32 1w-disc INFO 1-Wire: 28.39E1BF040000 with sensors: T11, T10, T, T12, T9
        2013-09-30 18:49:32 1w-disc INFO 1-Wire: 28.35D4E0040000 with sensors: T11, T10, T, T12, T9
        2013-09-30 18:49:32 1w-disc INFO 1-Wire: 28.33E8BF040000 with sensors: T11, T10, T, T12, T9
        2013-09-30 18:49:32 1w-disc INFO 1-Wire: 28.3369E0040000 with sensors: T11, T10, T, T12, T9
        2013-09-30 18:49:32 1w-disc INFO 1-Wire: 28.AB51C0040000 with sensors: T11, T10, T, T12, T9
        2013-09-30 18:49:32 1w-disc INFO 1-Wire: 28.DBC2E0040000 with sensors: T11, T10, T, T12, T9
        2013-09-30 18:49:32 1w-disc INFO 1-Wire: 28.AFADE0040000 with sensors: T11, T10, T, T12, T9
        2013-09-30 18:49:32 1w-disc INFO 1-Wire: 28.FFF2BF040000 with sensors: T11, T10, T, T12, T9
        2013-09-30 18:49:32 SmartHome.py INFO KNX: connection to 127.0.0.1:6720 closed
        2013-09-30 18:49:34 hello INFO Hello World!
        Habe mal im debug-Modus gestartet und werde mal sehen, wann er sich wieder hinlegt.....
        P.S.: Ich habe momentan noch ein paar dummy items konfiguriert, die nehme ich auch mal aus der item.conf raus.
        Georg
          Hi Georg,
          ich bin mir relativ sicher das das KNX Plugin in ein Deadlock gelaufen ist, das auch die Ausführung des 1-Wire Plugins behindert.
          Das kann ich leider erst ab Py3.2 besser handeln.
          Ich habe den Bug auf meine Liste geschrieben. Momentan hänge ich noch an einem anderen Bug...
          Bis bald
          Marcus
            Zitat von mknx Beitrag anzeigen
            Hi Georg,
            Bis bald
            Marcus
            Hallo Marcus,
            Danke, dann warten wir eben....
            Georg
