- √ - knx plugin unicode Problem
    2013-10-27 20:22:55,640 SmartHome.py DEBUG knx: 0.0.0 set 10/0/0 to Z�nden -- __init__.pyarse_telegram:189
    error: uncaptured python exception, closing channel <plugins.knx.KNX connected 192.168.179.12:6720 at 0x6187b0> (<type 'exceptions.UnicodeDecodeError'>:'ascii' codec can't decode byte 0xfc in position 1: ordinal not in range(128) [/usr/lib/python2.7/asyncore.py|read|83] [/usr/lib/python2.7/asyncore.py|handle_read_event|449] [/usr/lib/python2.7/asynchat.py|handle_read|140] [/usr/local/smarthome/plugins/knx/__init__.py|found_terminator|131] [/usr/local/smarthome/plugins/knx/__init__.py|parse_telegram|196] [/usr/local/smarthome/lib/item.py|__call__|205] [/usr/local/smarthome/lib/item.py|_update|219])
    2013-10-27 20:22:55,646 SmartHome.py INFO KNX: connection to 192.168.179.12:6720 closed -- my_asynchat.py:handle_close:103
    ggf. aber auch schon in develop gefixt? Ich häng hier noch auf dem last stable...
    Baublog im Profil.
    sehr wahrscheinlich.
    Bis bald
    Marcus
