group(s)write
    group(s)write
    Guten tag,
    ich kann in der Kommandozeile:
    groupswrite ip:127.0.0.1 0/2/1 1
    und
    in logic/*.py
    sh.knx.groupswrite('0/2/1',1,'1')
    Dies ist kein Problem und arbeitet ok
    jetzt mein problem!
    wie kann ich dies tun in meinem eigenen Skript Zufalls
    Entschuldigungen für meine wunderbare Deutsch
    Vielen Dank im Voraus,
    jonas
    Please try in English - don't get what you want
    Gesendet von meinem GT-I9100 mit Tapatalk
      In english
      i'm trying to create a random script where i can do a groups-read or -write to a specific groups address.
      But when i do this in my script "groupswrite" or "sh.knx.groupwrite" i get a syntax error or invallid command.
      in de logics/*.py , sh.knx.groupwrite works becauze is it loaded from smarthome. And groupswrite works only in command line :s.
      I've a project running next to "smarthome.py" where i want use these command in a script, so i can import this script in my project and read/write to the knx.
      Thx
        ok, and your script is written in which language? Shell/Bash, Batch, Python,...?
        You have an example or a part of your script which fail?
          Its writen in python ( and no errors ), just as smarhome.py.
          It's based on the plugins/knx/__init__.py , there is the groups-read and write defined.
          I've also imported some libs just as smarthome did.
          I don't even know if this is possible but i tought i went close.
          Despite i've no errors, it does nothing when i run it
            this is part of my script:
            #!/usr/bin/env python
            import signal
            import sys
            import os
            import subprocess
            import asyncore
            import dpts
            from configobj import ConfigObj
            import lib.my_asynchat
            KNXREAD = 0x00
            KNXRESP = 0x40
            KNXWRITE = 0x80
            class KnxReadWrite(lib.my_asynchat.AsynChat):
            _plugin_conf = BASE + '/etc/plugin.conf'
            socket_map = {}
            def __init__(self, host='127.0.0.1', port=6720):
            lib.my_asynchat.AsynChat.__init__(self, self, host, port)
            #lib.my_knxchat.AsynChat.__init__(self, self, host, port)
            self.gal = {}
            self.gar = {}
            self._init_ga = []
            self.alive = True
            while self.alive:
            if self.socket_map != {}:
            asyncore.loop(timeout=1, count=1, map=self.socket_map)
            else:
            time.sleep(2)
            def _send(self, data):
            def groupwrite(self, ga, payload, dpt, flag='write'):
            def groupread(self, ga):
            def encode(self, data, dpt):
            def decode(self, data, dpt):
            def main(self,argv):
            if argv == '-r':
            print('lets read')
            self.groupread('3/3/20')
            elif argv == '-won':
            print('lets make some light')
            self.groupwrite('3/3/20',1,'1')
            elif argv == '-woff':
            print('lets put off the light')
            self.groupwrite('3/3/20',0,'1')
            elif argv == 'test':
            print('works so far')
            else:
            print '*'
            print 'usage: licht.py -r <read> | -won <write_on> | -woff <write_off>'
            print '*'
            if __name__ == "__main__":
            objName = KnxReadWrite()
            if len(sys.argv) == 1:
            sys.exit("usage: licht.py -r <read> | -won <write_on> | -woff <write_off>")
            else:
            objName.main(sys.argv[1])
              Hi Jonas,
              puhh, sorry there are to many mistakes to help you in my limited time.
              Why don't you use the shell command groupwrite(s) from the eibd?
              Or SH.py with the network plugin, or....
              Good luck.
              so long
              Marcus
                hi,
                thanks u still had some time to read my post
                i managed to write a message with:
                from subprocess import call
                call(["groupswrite","ip:127.0.0.1","3/3/20","1"])
                but how can i read one ?
                because "groupsread" doesn't return a value?
                thx
                  hi,
                  I'm still struggling here.
                  I need the value of a groupsadres in my "random.py" script.
                  ( this is to make control in my own websocket server. My Raspberry is the client and here i need the value to send it to my server)
                  But groupsread doesn't return a value, only triggers a read request.
                  And will be received by smarthome.py en send by the VISU websocket plugin ( if i'm right ).
                  Gruss,
                  jonas
                    To get the answer you have to type "groupsreadresponse".
                    Baustelle 2.0 !
                      thx very much "groupreadresponse" gave actual a response.
                      but when i do:
                      var = call(["groupreadresponse","ip:127.0.0.1","4/2/0"])
                      print(var)
                      it's always "0"
                      I probably have to struct.unpack () this:
                      Response from 3.1.3: 42 15 0A 3D
                      print(struct.unpack('>l',var))
                      struct.error: unpack requires a string argument of length 4
                      Response from 3.0.1: 01
                      print(struct.unpack('>c',var))
                      struct.error: unpack requires a string argument of length 1
                        I'll make a new post for it,
                        i guess it would be easier.
                        https://knx-user-forum.de/smarthome-...tml#post359827
