Zitat von firefox
Bis bald
Marcus
method(self, caller, source, dest)
File "/usr/local/smarthome/plugins/knx/__init__.py", line 325, in update_item
self.groupwrite(ga, item(), item.conf['knx_dpt'])
File "/usr/local/smarthome/plugins/knx/__init__.py", line 69, in groupwrite
pkt.extend(self.encode(payload, dpt))
File "/usr/local/smarthome/plugins/knx/__init__.py", line 143, in encode
return dpts.encode[str(dpt)](data)
File "/usr/local/smarthome/plugins/knx/dpts.py", line 245, in en16001
enc.extend(value.encode('iso-8859-1')[:14])
UnicodeEncodeError: 'latin-1' codec can't encode character '\ufffd' in position 17: ordinal not in range(256)
2013-12-20 20:54:57 ERROR Main Item Squeezebox.Current_Title: problem running <bound method KNX.update_item of <plugins.knx.KNX object at 0x1cfd090>>: 'latin-1' codec can't encode character '\ufffd' in position 17: ordinal not in range(256)
Traceback (most recent call last):
File "/usr/local/smarthome/lib/item.py", line 369, in __update
Updating system... Please wait............................ [OK] Updating SmartHome.py HEAD is now at bdb136a knx status/send fix Already up-to-date. Restarting SmartHome.py smarthome.py Updating smartVISU Reverted 'temp/offline_fleischer.var' Reverted 'temp/offline_alber.eibd.var' Reverted 'temp/offline_meister.var' Reverted 'temp/offline_gleiss.linknx.var' Reverted 'temp/offline_otterstaetter.var' Reverted 'temp/offline_docu.var' Reverted 'temp/offline_alber.smarthome.py.var' Reverted 'temp/offline_gleiss.smarthome.py.var' Reverted 'temp/offline_berlenz.var' Updating '.': Fetching external item into 'vendor/Twig': External at revision 2499. Fetching external item into 'vendor/jquery.cycle2': External at revision 97. Fetching external item into 'vendor/google.prettify/src': External at revision 304. Fetching external item into 'vendor/google.prettify/styles': External at revision 304. At revision 537. [OK] Updating SmartHome.py HEAD is now at bdb136a knx status/send fix Already up-to-date. Restarting SmartHome.py smarthome.py Updating smartVISU Reverted 'temp/offline_fleischer.var' Reverted 'temp/offline_alber.eibd.var' Reverted 'temp/offline_meister.var' Reverted 'temp/offline_gleiss.linknx.var' Reverted 'temp/offline_otterstaetter.var' Reverted 'temp/offline_docu.var' Reverted 'temp/offline_alber.smarthome.py.var' Reverted 'temp/offline_gleiss.smarthome.py.var' Reverted 'temp/offline_berlenz.var' Updating '.': Fetching external item into 'vendor/Twig': External at revision 2499. Fetching external item into 'vendor/jquery.cycle2': External at revision 97. Fetching external item into 'vendor/google.prettify/src': External at revision 304. Fetching external item into 'vendor/google.prettify/styles': External at revision 304. At revision 537.
2013-12-22 16:13:33,915 INFO Main Start SmartHome.py 1.0-18-gbdb136a -- smarthome.py:__init__:231
2013-12-22 16:13:33,920 DEBUG Main Python 3.2.3 -- smarthome.py:__init__:232
2013-12-22 16:13:33,926 INFO Main Init Scheduler -- scheduler.py:__init__:86
2013-12-22 16:13:33,933 INFO Main Init Plugins -- smarthome.py:start:274
2013-12-22 16:13:33,945 DEBUG Scheduler creating 5 workers -- scheduler.py:run:93
2013-12-22 16:13:33,954 DEBUG Main Plugin: knx -- plugin.py:__init__:43
2013-12-22 16:13:33,984 DEBUG Main Plugin: visu -- plugin.py:__init__:43
2013-12-22 16:13:34,073 DEBUG Main Plugin: cli -- plugin.py:__init__:43
2013-12-22 16:13:34,085 DEBUG Main Plugin: sql -- plugin.py:__init__:43
2013-12-22 16:13:34,118 DEBUG Main SQLite 3.7.13 -- __init__.py:__init__:62
2013-12-22 16:13:35,406 DEBUG Main SQLite: database integrity ok -- __init__.py:__init__:78
2013-12-22 16:13:35,433 DEBUG Main SQLite pack next time: 2013-12-23 03:02:00+01:00 -- scheduler.py:_next_time:289
2013-12-22 16:13:35,439 INFO Main Init Items -- smarthome.py:start:280
2013-12-22 16:13:35,794 DEBUG Main Item env.core.memory = 18067435.041258212 via SQLite None None -- item.py:set:457
2013-12-22 16:13:35,936 DEBUG Main Item env.core.threads = 7.0 via SQLite None None -- item.py:set:457
2013-12-22 16:13:36,075 DEBUG Main Item env.core.garbage = 0.0 via SQLite None None -- item.py:set:457
2013-12-22 16:13:36,081 DEBUG Main Item env.core: no type specified. -- item.py:__init__:242
2013-12-22 16:13:36,121 DEBUG Main Item env.location: no type specified. -- item.py:__init__:242
2013-12-22 16:13:36,260 DEBUG Main Item env.system.load = 0.15 via SQLite None None -- item.py:set:457
2013-12-22 16:13:36,270 DEBUG Main Item env.system: no type specified. -- item.py:__init__:242
2013-12-22 16:13:36,275 DEBUG Main Item env: no type specified. -- item.py:__init__:242
2013-12-22 16:13:36,291 DEBUG Main KNX: EG.Buero.Decke listen on 1/2/33 -- __init__.py:parse_item:235
2013-12-22 16:13:36,296 DEBUG Main KNX: EG.Buero.Decke listen on and init with 1/2/33 -- __init__.py:parse_item:244
2013-12-22 16:13:36,311 DEBUG Main KNX: EG.Buero.Temperatur.ist listen on 5/2/4 -- __init__.py:parse_item:235
2013-12-22 16:13:36,322 DEBUG Main KNX: EG.Buero.Temperatur.soll listen on and init with 5/2/24 -- __init__.py:parse_item:244
2013-12-22 16:13:36,337 DEBUG Main KNX: EG.Buero.Temperatur.stellwert listen on and init with 5/2/84 -- __init__.py:parse_item:244
2013-12-22 16:13:36,348 DEBUG Main KNX: EG.Buero.Temperatur.modus listen on and init with 5/2/64 -- __init__.py:parse_item:244
2013-12-22 16:13:36,392 WARNING Main Item EG.Buero.Temperatur.sperren: problem reading cache: [Errno 2] No such file or directory: '/usr/smarthome/var/cache/EG.Buero.Temperatur.sperren' -- item.py:__init__:236
2013-12-22 16:13:36,397 DEBUG Main KNX: EG.Buero.Temperatur.sperren listen on and init with 5/2/74 -- __init__.py:parse_item:244
2013-12-22 16:13:36,402 DEBUG Main Item EG.Buero.Temperatur: no type specified. -- item.py:__init__:242
2013-12-22 16:13:36,411 DEBUG Main KNX: EG.Buero.FensterLinks listen on 4/2/9 -- __init__.py:parse_item:235
2013-12-22 16:13:36,415 DEBUG Main KNX: EG.Buero.FensterLinks listen on and init with 4/2/9 -- __init__.py:parse_item:244
2013-12-22 16:13:36,424 DEBUG Main KNX: EG.Buero.FensterRechts listen on 4/2/10 -- __init__.py:parse_item:235
2013-12-22 16:13:36,427 DEBUG Main KNX: EG.Buero.FensterRechts listen on and init with 4/2/10 -- __init__.py:parse_item:244
2013-12-22 16:13:36,449 DEBUG Main KNX: EG.Buero.Rollo.pos listen on 3/2/98 -- __init__.py:parse_item:235
2013-12-22 16:13:36,453 DEBUG Main KNX: EG.Buero.Rollo.pos listen on and init with 3/2/98 -- __init__.py:parse_item:244
2013-12-22 16:13:36,461 DEBUG Main KNX: EG.Buero.Rollo.shade listen on 3/2/128 -- __init__.py:parse_item:235
2013-12-22 16:13:36,470 DEBUG Main KNX: EG.Buero.Rollo.night listen on 3/2/158 -- __init__.py:parse_item:235
2013-12-22 16:13:36,478 WARNING Main Item EG.Buero.Rollo.auto_down: problem reading cache: [Errno 2] No such file or directory: '/usr/smarthome/var/cache/EG.Buero.Rollo.auto_down' -- item.py:__init__:236
2013-12-22 16:13:36,489 WARNING Main Item EG.Buero.Rollo.auto_up: problem reading cache: [Errno 2] No such file or directory: '/usr/smarthome/var/cache/EG.Buero.Rollo.auto_up' -- item.py:__init__:236
2013-12-22 16:13:36,501 WARNING Main Item EG.Buero.Rollo.auto_shade: problem reading cache: [Errno 2] No such file or directory: '/usr/smarthome/var/cache/EG.Buero.Rollo.auto_shade' -- item.py:__init__:236
2013-12-22 16:13:36,507 DEBUG Main Item EG.Buero.Rollo: no type specified. -- item.py:__init__:242
2013-12-22 16:13:36,517 DEBUG Main KNX: EG.Buero.Praesenz listen on 6/2/2 -- __init__.py:parse_item:235
2013-12-22 16:13:36,522 DEBUG Main Item EG.Buero: no type specified. -- item.py:__init__:242
2013-12-22 16:13:36,535 DEBUG Main KNX: EG.Schlafen.Decke listen on 1/2/35 -- __init__.py:parse_item:235
2013-12-22 16:13:36,539 DEBUG Main KNX: EG.Schlafen.Decke listen on and init with 1/2/35 -- __init__.py:parse_item:244
2013-12-22 16:13:36,553 DEBUG Main KNX: EG.Schlafen.Downlights.dimmen listen on 1/2/120 -- __init__.py:parse_item:235
2013-12-22 16:13:36,557 DEBUG Main KNX: EG.Schlafen.Downlights.dimmen listen on and init with 1/2/120 -- __init__.py:parse_item:244
2013-12-22 16:13:36,563 DEBUG Main KNX: EG.Schlafen.Downlights listen on 1/2/36 -- __init__.py:parse_item:235
2013-12-22 16:13:36,567 DEBUG Main KNX: EG.Schlafen.Downlights listen on and init with 1/2/36 -- __init__.py:parse_item:244
2013-12-22 16:13:36,582 DEBUG Main KNX: EG.Schlafen.Temperatur.ist listen on 5/2/5 -- __init__.py:parse_item:235
2013-12-22 16:13:36,593 DEBUG Main KNX: EG.Schlafen.Temperatur.soll listen on and init with 5/2/25 -- __init__.py:parse_item:244
2013-12-22 16:13:36,609 DEBUG Main KNX: EG.Schlafen.Temperatur.stellwert listen on and init with 5/2/85 -- __init__.py:parse_item:244
2013-12-22 16:13:36,621 DEBUG Main KNX: EG.Schlafen.Temperatur.modus listen on and init with 5/2/65 -- __init__.py:parse_item:244
2013-12-22 16:13:36,664 DEBUG Main KNX: EG.Schlafen.Temperatur.sperren listen on and init with 5/2/75 -- __init__.py:parse_item:244
2013-12-22 16:13:36,669 DEBUG Main Item EG.Schlafen.Temperatur: no type specified. -- item.py:__init__:242
2013-12-22 16:13:36,678 DEBUG Main KNX: EG.Schlafen.FensterLinks listen on 4/2/6 -- __init__.py:parse_item:235
2013-12-22 16:13:36,682 DEBUG Main KNX: EG.Schlafen.FensterLinks listen on and init with 4/2/6 -- __init__.py:parse_item:244
2013-12-22 16:13:36,691 DEBUG Main KNX: EG.Schlafen.FensterRechts listen on 4/2/7 -- __init__.py:parse_item:235
2013-12-22 16:13:36,695 DEBUG Main KNX: EG.Schlafen.FensterRechts listen on and init with 4/2/7 -- __init__.py:parse_item:244
2013-12-22 16:13:36,718 DEBUG Main KNX: EG.Schlafen.Rollo.pos listen on 3/2/96 -- __init__.py:parse_item:235
2013-12-22 16:13:36,723 DEBUG Main KNX: EG.Schlafen.Rollo.pos listen on and init with 3/2/96 -- __init__.py:parse_item:244
2013-12-22 16:13:36,732 DEBUG Main KNX: EG.Schlafen.Rollo.shade listen on 3/2/126 -- __init__.py:parse_item:235
2013-12-22 16:13:36,741 DEBUG Main KNX: EG.Schlafen.Rollo.night listen on 3/2/156 -- __init__.py:parse_item:235
2013-12-22 16:13:36,750 WARNING Main Item EG.Schlafen.Rollo.auto_down: problem reading cache: [Errno 2] No such file or directory: '/usr/smarthome/var/cache/EG.Schlafen.Rollo.auto_down' -- item.py:__init__:236
2013-12-22 16:13:36,761 WARNING Main Item EG.Schlafen.Rollo.auto_up: problem reading cache: [Errno 2] No such file or directory: '/usr/smarthome/var/cache/EG.Schlafen.Rollo.auto_up' -- item.py:__init__:236
2013-12-22 16:13:36,772 WARNING Main Item EG.Schlafen.Rollo.auto_shade: problem reading cache: [Errno 2] No such file or directory: '/usr/smarthome/var/cache/EG.Schlafen.Rollo.auto_shade' -- item.py:__init__:236
2013-12-22 16:13:36,778 DEBUG Main Item EG.Schlafen.Rollo: no type specified. -- item.py:__init__:242
2013-12-22 16:13:36,787 DEBUG Main KNX: EG.Schlafen.Praesenz listen on 6/2/3 -- __init__.py:parse_item:235
2013-12-22 16:13:36,792 DEBUG Main Item EG.Schlafen: no type specified. -- item.py:__init__:242
2013-12-22 16:13:36,804 DEBUG Main Item EG.Zentral: no type specified. -- item.py:__init__:242
2013-12-22 16:13:36,809 DEBUG Main Item EG: no type specified. -- item.py:__init__:242
2013-12-22 16:13:36,854 DEBUG Main Triggering EG.Buero.Temperatur.komfort - by: Init source: None dest: None value: {'caller': 'Init'} -- scheduler.py:trigger:162
2013-12-22 16:13:36,859 DEBUG Main Triggering EG.Buero.Temperatur.standby - by: Init source: None dest: None value: {'caller': 'Init'} -- scheduler.py:trigger:162
2013-12-22 16:13:36,862 WARNING EG.Buero.Temperatur.komfort Item EG.Buero.Temperatur.komfort: problem evaluating value if value < 2 else (sh.EG.Buero.Temperatur.modus() & 0x01): unorderable types: NoneType() < int() -- item.py:__run_eval:331
2013-12-22 16:13:36,867 DEBUG Main Triggering EG.Buero.Temperatur.nacht - by: Init source: None dest: None value: {'caller': 'Init'} -- scheduler.py:trigger:162
2013-12-22 16:13:36,870 WARNING EG.Buero.Temperatur.standby Item EG.Buero.Temperatur.standby: problem evaluating value if value < 2 else ((sh.EG.Buero.Temperatur.modus() & 0x02) >> 1): unorderable types: NoneType() < int() -- item.py:__run_eval:331
2013-12-22 16:13:36,883 WARNING EG.Buero.Temperatur.nacht Item EG.Buero.Temperatur.nacht: problem evaluating value if value < 2 else ((sh.EG.Buero.Temperatur.modus() & 0x04) >> 2): unorderable types: NoneType() < int() -- item.py:__run_eval:331
2013-12-22 16:13:36,880 DEBUG Main Triggering EG.Buero.Temperatur.frostschutz - by: Init source: None dest: None value: {'caller': 'Init'} -- scheduler.py:trigger:162
2013-12-22 16:13:36,898 DEBUG Main Triggering EG.Buero.Temperatur.frostalarm - by: Init source: None dest: None value: {'caller': 'Init'} -- scheduler.py:trigger:162
2013-12-22 16:13:36,903 WARNING EG.Buero.Temperatur.frostschutz Item EG.Buero.Temperatur.frostschutz: problem evaluating value if value < 2 else ((sh.EG.Buero.Temperatur.modus() & 0x08) >> 3): unorderable types: NoneType() < int() -- item.py:__run_eval:331
2013-12-22 16:13:36,908 DEBUG Main Triggering EG.Buero.Temperatur.heizen - by: Init source: None dest: None value: {'caller': 'Init'} -- scheduler.py:trigger:162
2013-12-22 16:13:36,921 DEBUG Main Triggering EG.Schlafen.Temperatur.komfort - by: Init source: None dest: None value: {'caller': 'Init'} -- scheduler.py:trigger:162
2013-12-22 16:13:36,926 DEBUG EG.Buero.Temperatur.heizen Item EG.Buero.Temperatur.heizen = True via Init None None -- item.py:__update:363
2013-12-22 16:13:36,933 WARNING EG.Schlafen.Temperatur.komfort Item EG.Schlafen.Temperatur.komfort: problem evaluating value if value < 2 else (sh.EG.Schlafen.Temperatur.modus() & 0x01): unorderable types: NoneType() < int() -- item.py:__run_eval:331
2013-12-22 16:13:36,931 DEBUG Main Triggering EG.Schlafen.Temperatur.standby - by: Init source: None dest: None value: {'caller': 'Init'} -- scheduler.py:trigger:162
2013-12-22 16:13:36,950 DEBUG Main Triggering EG.Schlafen.Temperatur.nacht - by: Init source: None dest: None value: {'caller': 'Init'} -- scheduler.py:trigger:162
2013-12-22 16:13:36,954 WARNING EG.Schlafen.Temperatur.standby Item EG.Schlafen.Temperatur.standby: problem evaluating value if value < 2 else ((sh.EG.Schlafen.Temperatur.modus() & 0x02) >> 1): unorderable types: NoneType() < int() -- item.py:__run_eval:331
2013-12-22 16:13:36,961 WARNING EG.Schlafen.Temperatur.nacht Item EG.Schlafen.Temperatur.nacht: problem evaluating value if value < 2 else ((sh.EG.Schlafen.Temperatur.modus() & 0x04) >> 2): unorderable types: NoneType() < int() -- item.py:__run_eval:331
2013-12-22 16:13:36,958 DEBUG Main Triggering EG.Schlafen.Temperatur.frostschutz - by: Init source: None dest: None value: {'caller': 'Init'} -- scheduler.py:trigger:162
2013-12-22 16:13:36,977 DEBUG Main Triggering EG.Schlafen.Temperatur.frostalarm - by: Init source: None dest: None value: {'caller': 'Init'} -- scheduler.py:trigger:162
2013-12-22 16:13:36,980 WARNING EG.Schlafen.Temperatur.frostschutz Item EG.Schlafen.Temperatur.frostschutz: problem evaluating value if value < 2 else ((sh.EG.Schlafen.Temperatur.modus() & 0x08) >> 3): unorderable types: NoneType() < int() -- item.py:__run_eval:331
2013-12-22 16:13:36,985 DEBUG Main Triggering EG.Schlafen.Temperatur.heizen - by: Init source: None dest: None value: {'caller': 'Init'} -- scheduler.py:trigger:162
2013-12-22 16:13:37,001 DEBUG EG.Schlafen.Temperatur.heizen Item EG.Schlafen.Temperatur.heizen = True via Init None None -- item.py:__update:363
2013-12-22 16:13:37,005 INFO Main Start Plugins -- plugin.py:start:65
2013-12-22 16:13:37,066 INFO Main Start Logics -- logic.py:__init__:33
2013-12-22 16:13:37,071 DEBUG Main Reading Logics from /usr/smarthome/lib/env/logic_conf -- logic.py:_read_logics:64
2013-12-22 16:13:37,106 DEBUG Main Reading Logics from /usr/smarthome/etc/logic.conf -- logic.py:_read_logics:64
2013-12-22 16:13:37,137 DEBUG Main Logic: rtr_message_EG_Kueche -- logic.py:__init__:44
2013-12-22 16:13:37,240 DEBUG Connections KNX: connected to 192.168.2.100:6720 -- connection.py:connect:386
2013-12-22 16:13:37,266 DEBUG Connections KNX: enable group monitor -- __init__.py:handle_connect:117
2013-12-22 16:13:37,274 DEBUG Connections KNX: init read -- __init__.py:handle_connect:123
2013-12-22 16:13:37,270 DEBUG Main Logic: env_loc -- logic.py:__init__:44
2013-12-22 16:13:37,302 DEBUG Main Logic: logic_sunrise -- logic.py:__init__:44
2013-12-22 16:13:37,320 DEBUG Connections WebSocket: binding to 0.0.0.0:2424 (TCP) -- connection.py:connect:161
2013-12-22 16:13:37,364 DEBUG Connections CLI: binding to 0.0.0.0:2323 (TCP) -- connection.py:connect:161
2013-12-22 16:13:37,381 DEBUG Main logic_sunrise next time: 2013-12-23 07:20:13.707703+00:00 -- scheduler.py:_next_time:289
2013-12-22 16:13:37,392 DEBUG Main Logic: env_stat -- logic.py:__init__:44
2013-12-22 16:13:37,414 DEBUG Main env_stat next time: 2013-12-22 16:13:48+01:00 -- scheduler.py:_next_time:289
2013-12-22 16:13:37,423 DEBUG Main Logic: rtr_message_EG_Schlafen -- logic.py:__init__:44
2013-12-22 16:13:37,456 DEBUG Main Logic: rtr_message_EG_Bad -- logic.py:__init__:44
2013-12-22 16:13:37,485 DEBUG Main Logic: rtr_message_EG_Buero -- logic.py:__init__:44
2013-12-22 16:13:37,507 DEBUG Main Logic: rtr_message_EG_Wohnen -- logic.py:__init__:44
2013-12-22 16:13:37,533 DEBUG Main Logic: logic_sunset -- logic.py:__init__:44
2013-12-22 16:13:37,556 DEBUG Main logic_sunset next time: 2013-12-22 16:01:03.739699+00:00 -- scheduler.py:_next_time:289
2013-12-22 16:13:37,561 DEBUG Main Logic: hello -- logic.py:__init__:44
2013-12-22 16:13:37,570 DEBUG Main Logic: env_init -- logic.py:__init__:44
2013-12-22 16:13:37,600 DEBUG Main KNX: 1.2.15 read 1/2/33 -- __init__.py:parse_telegram:203
2013-12-22 16:13:37,616 DEBUG Main KNX: 1.2.15 read 5/2/24 -- __init__.py:parse_telegram:203
2013-12-22 16:13:37,624 DEBUG Main KNX: 1.2.15 read 5/2/84 -- __init__.py:parse_telegram:203
2013-12-22 16:13:37,632 DEBUG Main KNX: 1.2.15 read 5/2/64 -- __init__.py:parse_telegram:203
2013-12-22 16:13:37,639 DEBUG Main KNX: 1.2.15 read 5/2/74 -- __init__.py:parse_telegram:203
2013-12-22 16:13:37,648 DEBUG Main KNX: 1.2.15 read 4/2/9 -- __init__.py:parse_telegram:203
2013-12-22 16:13:37,655 DEBUG Main KNX: 1.2.15 read 4/2/10 -- __init__.py:parse_telegram:203
2013-12-22 16:13:37,663 DEBUG Main KNX: 1.2.15 read 3/2/98 -- __init__.py:parse_telegram:203
2013-12-22 16:13:37,672 DEBUG Main KNX: 1.2.15 read 1/2/35 -- __init__.py:parse_telegram:203
2013-12-22 16:13:37,679 DEBUG Main KNX: 1.2.15 read 1/2/120 -- __init__.py:parse_telegram:203
2013-12-22 16:13:37,685 DEBUG Main KNX: 1.2.15 read 1/2/36 -- __init__.py:parse_telegram:203
2013-12-22 16:13:37,692 DEBUG Main KNX: 1.2.15 read 5/2/25 -- __init__.py:parse_telegram:203
2013-12-22 16:13:37,698 DEBUG Main KNX: 1.2.15 read 5/2/85 -- __init__.py:parse_telegram:203
2013-12-22 16:13:37,703 DEBUG Main KNX: 1.2.15 read 5/2/65 -- __init__.py:parse_telegram:203
2013-12-22 16:13:37,709 DEBUG Main KNX: 1.2.15 read 5/2/75 -- __init__.py:parse_telegram:203
2013-12-22 16:13:37,714 DEBUG Main KNX: 1.2.15 read 4/2/6 -- __init__.py:parse_telegram:203
2013-12-22 16:13:37,719 DEBUG Main knx: 1.2.2 set 1/2/33 to False -- __init__.py:parse_telegram:190
2013-12-22 16:13:37,724 DEBUG Main KNX: 1.2.15 read 4/2/7 -- __init__.py:parse_telegram:203
2013-12-22 16:13:37,729 DEBUG Main KNX: 1.2.15 read 3/2/96 -- __init__.py:parse_telegram:203
2013-12-22 16:13:37,736 DEBUG Main knx: 1.2.5 set 5/2/24 to 20.0 -- __init__.py:parse_telegram:190
2013-12-22 16:13:37,742 DEBUG Main Item EG.Buero.Temperatur.soll = 20.0 via KNX 1.2.5 5/2/24 -- item.py:__update:363
2013-12-22 16:13:37,751 DEBUG Main knx: 1.2.5 set 5/2/84 to 100.0 -- __init__.py:parse_telegram:190
2013-12-22 16:13:37,756 DEBUG Main Item EG.Buero.Temperatur.stellwert = 100.0 via KNX 1.2.5 5/2/84 -- item.py:__update:363
2013-12-22 16:13:37,764 DEBUG Main Triggering EG.Buero.Temperatur.heizen - by: KNX source: 1.2.5 dest: 5/2/84 value: {'source': 'EG.Buero.Temperatur.stellwer -- scheduler.py:trigger:162
2013-12-22 16:13:37,780 DEBUG Main knx: 1.2.5 set 5/2/64 to 33 -- __init__.py:parse_telegram:190
2013-12-22 16:13:37,786 DEBUG Main Item EG.Buero.Temperatur.modus = 33 via KNX 1.2.5 5/2/64 -- item.py:__update:363
2013-12-22 16:13:37,792 DEBUG Main Triggering EG.Buero.Temperatur.komfort - by: KNX source: 1.2.5 dest: 5/2/64 value: {'source': 'EG.Buero.Temperatur.modus', -- scheduler.py:trigger:162
2013-12-22 16:13:37,796 DEBUG Main Triggering EG.Buero.Temperatur.standby - by: KNX source: 1.2.5 dest: 5/2/64 value: {'source': 'EG.Buero.Temperatur.modus', -- scheduler.py:trigger:162
2013-12-22 16:13:37,801 DEBUG EG.Buero.Temperatur.komfort Item EG.Buero.Temperatur.komfort = True via Eval EG.Buero.Temperatur.modus None -- item.py:__update:363
2013-12-22 16:13:37,805 DEBUG Main Triggering EG.Buero.Temperatur.nacht - by: KNX source: 1.2.5 dest: 5/2/64 value: {'source': 'EG.Buero.Temperatur.modus', -- scheduler.py:trigger:162
2013-12-22 16:13:37,819 DEBUG Main Triggering EG.Buero.Temperatur.frostschutz - by: KNX source: 1.2.5 dest: 5/2/64 value: {'source': 'EG.Buero.Temperatur.modus', -- scheduler.py:trigger:162
2013-12-22 16:13:37,827 DEBUG Main Triggering EG.Buero.Temperatur.frostalarm - by: KNX source: 1.2.5 dest: 5/2/64 value: {'source': 'EG.Buero.Temperatur.modus', -- scheduler.py:trigger:162
2013-12-22 16:13:37,837 DEBUG Main knx: 1.2.5 set 5/2/74 to False -- __init__.py:parse_telegram:190
2013-12-22 16:13:37,849 DEBUG Main knx: 1.2.15 set 5/2/34 to 01 -- __init__.py:parse_telegram:181
2013-12-22 16:13:37,905 DEBUG Main knx: 1.2.6 set 3/2/98 to 0 -- __init__.py:parse_telegram:190
2013-12-22 16:13:37,993 DEBUG Main knx: 1.2.2 set 1/2/35 to False -- __init__.py:parse_telegram:190
2013-12-22 16:13:38,017 DEBUG Main knx: 1.2.5 set 5/2/25 to 19.0 -- __init__.py:parse_telegram:190
2013-12-22 16:13:38,023 DEBUG Main Item EG.Schlafen.Temperatur.soll = 19.0 via KNX 1.2.5 5/2/25 -- item.py:__update:363
2013-12-22 16:13:38,036 DEBUG Main knx: 1.2.3 set 1/2/120 to 0 -- __init__.py:parse_telegram:190
2013-12-22 16:13:38,092 DEBUG Main knx: 1.2.5 set 5/2/85 to 0.0 -- __init__.py:parse_telegram:190
2013-12-22 16:13:38,100 DEBUG Main Triggering EG.Schlafen.Temperatur.heizen - by: KNX source: 1.2.5 dest: 5/2/85 value: {'source': 'EG.Schlafen.Temperatur.stell -- scheduler.py:trigger:162
2013-12-22 16:13:38,107 DEBUG EG.Schlafen.Temperatur.heizen Item EG.Schlafen.Temperatur.heizen = False via Eval EG.Schlafen.Temperatur.stellwert None -- item.py:__update:363
2013-12-22 16:13:38,134 DEBUG Main knx: 1.2.5 set 5/2/65 to 33 -- __init__.py:parse_telegram:190
2013-12-22 16:13:38,140 DEBUG Main Item EG.Schlafen.Temperatur.modus = 33 via KNX 1.2.5 5/2/65 -- item.py:__update:363
2013-12-22 16:13:38,146 DEBUG Main Triggering EG.Schlafen.Temperatur.komfort - by: KNX source: 1.2.5 dest: 5/2/65 value: {'source': 'EG.Schlafen.Temperatur.modus -- scheduler.py:trigger:162
2013-12-22 16:13:38,152 DEBUG Main Triggering EG.Schlafen.Temperatur.standby - by: KNX source: 1.2.5 dest: 5/2/65 value: {'source': 'EG.Schlafen.Temperatur.modus -- scheduler.py:trigger:162
2013-12-22 16:13:38,157 DEBUG EG.Schlafen.Temperatur.komfort Item EG.Schlafen.Temperatur.komfort = True via Eval EG.Schlafen.Temperatur.modus None -- item.py:__update:363
2013-12-22 16:13:38,161 DEBUG Main Triggering EG.Schlafen.Temperatur.nacht - by: KNX source: 1.2.5 dest: 5/2/65 value: {'source': 'EG.Schlafen.Temperatur.modus -- scheduler.py:trigger:162
2013-12-22 16:13:38,174 DEBUG Main Triggering EG.Schlafen.Temperatur.frostschutz - by: KNX source: 1.2.5 dest: 5/2/65 value: {'source': 'EG.Schlafen.Temperatur.modus -- scheduler.py:trigger:162
2013-12-22 16:13:38,182 DEBUG Main Triggering EG.Schlafen.Temperatur.frostalarm - by: KNX source: 1.2.5 dest: 5/2/65 value: {'source': 'EG.Schlafen.Temperatur.modus -- scheduler.py:trigger:162
2013-12-22 16:13:38,193 DEBUG Main knx: 1.2.3 set 1/2/36 to False -- __init__.py:parse_telegram:190
2013-12-22 16:13:38,201 DEBUG Main knx: 1.2.5 set 5/2/75 to False -- __init__.py:parse_telegram:190
2013-12-22 16:13:38,208 DEBUG Main knx: 1.2.15 set 5/2/35 to 01 -- __init__.py:parse_telegram:181
2013-12-22 16:13:38,299 DEBUG Main knx: 1.2.6 set 3/2/96 to 0 -- __init__.py:parse_telegram:190
2013-12-22 16:13:42,583 DEBUG env_loc Item env.location.sunrise = 2013-12-23 08:20:13.707703+01:00 via Logic None None -- item.py:__update:363
2013-12-22 16:13:42,604 DEBUG env_loc Item env.location.sunset = 2013-12-22 16:13:54.897584+01:00 via Logic None None -- item.py:__update:363
2013-12-22 16:13:42,636 DEBUG env_loc Item env.location.moonrise = 2013-12-22 21:42:06.251985+01:00 via Logic None None -- item.py:__update:363
2013-12-22 16:13:42,673 DEBUG env_loc Item env.location.moonset = 2013-12-23 11:03:02.770689+01:00 via Logic None None -- item.py:__update:363
2013-12-22 16:13:42,691 DEBUG env_loc Item env.location.moonphase = 5 via Logic None None -- item.py:__update:363
2013-12-22 16:13:42,725 DEBUG env_loc Item env.location.day = True via Logic None None -- item.py:__update:363
2013-12-22 16:13:43,132 DEBUG Scheduler env_loc next time: 2013-12-22 15:14:54.897583+00:00 -- scheduler.py:_next_time:289
2013-12-22 16:13:43,139 INFO hello Hello World! -- hello.py:<module>:3
2013-12-22 16:13:43,211 DEBUG env_init Item env.core.version = 1.0-18-gbdb136a via Logic None None -- item.py:__update:363
2013-12-22 16:13:43,214 DEBUG sh.gc Garbage collector: collected 0 objects. -- smarthome.py:_garbage_collection:498
2013-12-22 16:13:43,222 DEBUG env_init Item env.core.start = 2013-12-22 16:13:43.218917+01:00 via Logic None None -- item.py:__update:363
2013-12-22 16:13:43,243 DEBUG env_init Item env.system.name = smarthome.local via Logic None None -- item.py:__update:363
2013-12-22 16:13:43,289 DEBUG env_init Item env.system.start = 2013-12-01 22:51:31.286020+01:00 via Logic None None -- item.py:__update:363
2013-12-22 16:13:43,399 DEBUG sh.gc Object references: 9535 -- smarthome.py:_maintenance:490
2013-12-22 16:13:43,729 DEBUG Scheduler sh.gc next time: 2013-12-23 02:04:00+01:00 -- scheduler.py:_next_time:289
2013-12-22 16:13:48,341 DEBUG env_stat Item env.core.memory = 15659008 via Logic None None -- item.py:__update:363
2013-12-22 16:13:48,350 DEBUG env_stat Item env.system.load = 0.22 via Logic None None -- item.py:__update:363
2013-12-22 16:13:48,358 DEBUG env_stat Item env.location.moonlight = 77 via Logic None None -- item.py:__update:363
2013-12-22 16:13:48,784 DEBUG Scheduler env_stat next time: 2013-12-22 16:18:48+01:00 -- scheduler.py:_next_time:289
2013-12-22 16:14:00,496 DEBUG Main WebSocket: incoming connection from 192.168.2.31:55856 to 0.0.0.0:2424 -- connection.py:accept:188
2013-12-22 16:14:00,878 DEBUG Main 192.168.2.31:55856 sent '{"cmd":"proto","ver":3}' -- __init__.py:json_parse:270
2013-12-22 16:14:00,893 DEBUG Main 192.168.2.31:55856 sent '{"cmd":"monitor","items":["EG.Wohnen.Temperatur.ist","EG.Wohnen.Praesenz","EG.Wohnen.FensterSuedLinks","EG.Essen.Fenster","EG.Wohnen.Tuer","EG.Wohnen.Couch","EG.Wohnen.Lesen","EG.Essen.Tisch","EG.Wohnen.Temperatur.heizen","EG.Essen.Temperatur.heizen","EG.Schlafen.Temperatur.ist","EG.Schlafen.Praesenz","EG.Schlafen.FensterLinks","EG.Schlafen.FensterRechts","EG.Schlafen.Decke","EG.Schlafen.Downlights","EG.Anbau.Decke","EG.Schlafen.Temperatur.heizen","EG.Buero.Temperatur.ist","EG.Buero.Praesenz","EG.Buero.FensterLinks","EG.Buero.FensterRechts","EG.Buero.Decke","EG.Buero.Temperatur.heizen","EG.Bad.Temperatur.ist","EG.Bad.Praesenz","EG.Bad.Praesenz.nacht","EG.Bad.Fenster","EG.Bad.Spiegel","EG.Bad.Temperatur.heizen","EG.Kueche.Temperatur.ist","EG.Kueche.Praesenz","EG.Kueche.Tuer","EG.Kueche.Decke","EG.Kueche.Temperatur.heizen","EG.WC.Praesenz","EG.WC.Fenster","EG.WC.Decke","EG.WC.Spiegel"]}' -- __init__.py:json_parse:270
2013-12-22 16:14:00,899 WARNING Main Client 192.168.2.31:55856 requested invalid item: EG.Wohnen.Tuer -- __init__.py:json_parse:294
2013-12-22 16:14:00,905 WARNING Main Client 192.168.2.31:55856 requested invalid item: EG.Bad.Temperatur.heizen -- __init__.py:json_parse:294
2013-12-22 16:14:00,911 WARNING Main Client 192.168.2.31:55856 requested invalid item: EG.WC.Fenster -- __init__.py:json_parse:294
2013-12-22 16:14:00,917 WARNING Main Client 192.168.2.31:55856 requested invalid item: EG.Bad.Spiegel -- __init__.py:json_parse:294
2013-12-22 16:14:00,927 WARNING Main Client 192.168.2.31:55856 requested invalid item: EG.Anbau.Decke -- __init__.py:json_parse:294
2013-12-22 16:14:00,938 WARNING Main Client 192.168.2.31:55856 requested invalid item: EG.Wohnen.Couch -- __init__.py:json_parse:294
2013-12-22 16:14:00,945 WARNING Main Client 192.168.2.31:55856 requested invalid item: EG.Essen.Fenster -- __init__.py:json_parse:294
2013-12-22 16:14:00,953 WARNING Main Client 192.168.2.31:55856 requested invalid item: EG.Kueche.Decke -- __init__.py:json_parse:294
2013-12-22 16:14:00,959 WARNING Main Client 192.168.2.31:55856 requested invalid item: EG.Bad.Fenster -- __init__.py:json_parse:294
2013-12-22 16:14:00,972 WARNING Main Client 192.168.2.31:55856 requested invalid item: EG.Essen.Tisch -- __init__.py:json_parse:294
2013-12-22 16:14:00,980 WARNING Main Client 192.168.2.31:55856 requested invalid item: EG.Kueche.Temperatur.ist -- __init__.py:json_parse:294
2013-12-22 16:14:00,989 WARNING Main Client 192.168.2.31:55856 requested invalid item: EG.Wohnen.Temperatur.heizen -- __init__.py:json_parse:294
2013-12-22 16:14:00,995 WARNING Main Client 192.168.2.31:55856 requested invalid item: EG.Bad.Praesenz -- __init__.py:json_parse:294
2013-12-22 16:14:01,002 WARNING Main Client 192.168.2.31:55856 requested invalid item: EG.WC.Decke -- __init__.py:json_parse:294
2013-12-22 16:14:01,009 WARNING Main Client 192.168.2.31:55856 requested invalid item: EG.WC.Praesenz -- __init__.py:json_parse:294
2013-12-22 16:14:01,015 WARNING Main Client 192.168.2.31:55856 requested invalid item: EG.Kueche.Temperatur.heizen -- __init__.py:json_parse:294
2013-12-22 16:14:01,021 WARNING Main Client 192.168.2.31:55856 requested invalid item: EG.Wohnen.Lesen -- __init__.py:json_parse:294
2013-12-22 16:14:01,028 WARNING Main Client 192.168.2.31:55856 requested invalid item: EG.Bad.Praesenz.nacht -- __init__.py:json_parse:294
2013-12-22 16:14:01,034 WARNING Main Client 192.168.2.31:55856 requested invalid item: EG.Wohnen.Temperatur.ist -- __init__.py:json_parse:294
2013-12-22 16:14:01,040 WARNING Main Client 192.168.2.31:55856 requested invalid item: EG.Bad.Temperatur.ist -- __init__.py:json_parse:294
2013-12-22 16:14:01,046 WARNING Main Client 192.168.2.31:55856 requested invalid item: EG.WC.Spiegel -- __init__.py:json_parse:294
2013-12-22 16:14:01,052 WARNING Main Client 192.168.2.31:55856 requested invalid item: EG.Wohnen.Praesenz -- __init__.py:json_parse:294
2013-12-22 16:14:01,058 WARNING Main Client 192.168.2.31:55856 requested invalid item: EG.Essen.Temperatur.heizen -- __init__.py:json_parse:294
2013-12-22 16:14:01,064 WARNING Main Client 192.168.2.31:55856 requested invalid item: EG.Wohnen.FensterSuedLinks -- __init__.py:json_parse:294
2013-12-22 16:14:01,070 WARNING Main Client 192.168.2.31:55856 requested invalid item: EG.Kueche.Tuer -- __init__.py:json_parse:294
2013-12-22 16:14:01,077 WARNING Main Client 192.168.2.31:55856 requested invalid item: EG.Kueche.Praesenz -- __init__.py:json_parse:294
2013-12-22 16:14:05,310 DEBUG Main knx: 1.2.103 set 7/2/10 to 1c19 -- __init__.py:parse_telegram:181
2013-12-22 16:14:09,353 DEBUG Main 192.168.2.31:55856 sent '{"cmd":"monitor","items":["EG.Buero.Decke","EG.Buero.Temperatur.ist","EG.Buero.Temperatur.txtmodus","EG.Buero.Temperatur.sollwertverschiebung","EG.Buero.Temperatur.soll","EG.Buero.Temperatur.komfort","EG.Buero.Temperatur.nacht","EG.Buero.Temperatur.frostschutz","EG.Buero.Temperatur.sperren","EG.Buero.Rollo.pos","EG.Buero.Rollo.move","EG.Buero.Rollo.stop","EG.Buero.Rollo.shade","EG.Buero.Rollo.auto_down","EG.Buero.Rollo.auto_up","EG.Buero.Rollo.auto_shade","EG.Buero.FensterLinks","EG.Buero.FensterRechts","EG.Buero.Praesenz","EG.Buero.Temperatur.stellwert","EG.Wohnen.Temperatur.ist","EG.Wohnen.Praesenz","EG.Wohnen.FensterSuedLinks","EG.Essen.Fenster","EG.Wohnen.Tuer","EG.Wohnen.Couch","EG.Wohnen.Lesen","EG.Essen.Tisch","EG.Wohnen.Temperatur.heizen","EG.Essen.Temperatur.heizen","EG.Schlafen.Temperatur.ist","EG.Schlafen.Praesenz","EG.Schlafen.FensterLinks","EG.Schlafen.FensterRechts","EG.Schlafen.Decke","EG.Schlafen.Downlights","EG.Anbau.Decke","EG.Schlafen.Temperatur.heizen","EG.Buero.Temperatur.heizen","EG.Bad.Temperatur.ist","EG.Bad.Praesenz","EG.Bad.Praesenz.nacht","EG.Bad.Fenster","EG.Bad.Spiegel","EG.Bad.Temperatur.heizen","EG.Kueche.Temperatur.ist","EG.Kueche.Praesenz","EG.Kueche.Tuer","EG.Kueche.Decke","EG.Kueche.Temperatur.heizen","EG.WC.Praesenz","EG.WC.Fenster","EG.WC.Decke","EG.WC.Spiegel"]}' -- __init__.py:json_parse:270
2013-12-22 16:14:09,373 DEBUG Main 192.168.2.31:55856 sent '{"cmd":"series","item":"EG.Buero.Temperatur.ist","series":"avg","start":"1d"}' -- __init__.py:json_parse:270
2013-12-22 16:14:09,596 DEBUG Main 192.168.2.31:55856 sent '{"cmd":"series","item":"EG.Buero.Temperatur.soll","series":"avg","start":"1d"}' -- __init__.py:json_parse:270
2013-12-22 16:14:09,813 DEBUG Main 192.168.2.31:55856 sent '{"cmd":"series","item":"EG.Buero.Temperatur.stellwert","series":"avg","start":"1d"}' -- __init__.py:json_parse:270
2013-12-22 16:14:19,432 DEBUG Main 192.168.2.31:55856 sent '{"cmd":"item","id":"EG.Buero.Temperatur.komfort","val":"0"}' -- __init__.py:json_parse:270
2013-12-22 16:14:19,437 DEBUG Main Triggering EG.Buero.Temperatur.komfort-eval - by: Visu source: 192.168.2.31:55856 dest: None value: {'dest': None, 'source': '192.168.2.31:5 -- scheduler.py:trigger:162
2013-12-22 16:14:19,445 WARNING EG.Buero.Temperatur.komfort-eval Item EG.Buero.Temperatur.komfort: problem evaluating value if value < 2 else (sh.EG.Buero.Temperatur.modus() & 0x01): unorderable types: str() < int() -- item.py:__run_eval:331
2013-12-22 16:14:40,387 DEBUG Main 192.168.2.31:55856 sent '{"cmd":"item","id":"EG.Buero.Temperatur.komfort","val":"1"}' -- __init__.py:json_parse:270
2013-12-22 16:14:40,392 DEBUG Main Triggering EG.Buero.Temperatur.komfort-eval - by: Visu source: 192.168.2.31:55856 dest: None value: {'dest': None, 'source': '192.168.2.31:5 -- scheduler.py:trigger:162
2013-12-22 16:14:40,398 WARNING EG.Buero.Temperatur.komfort-eval Item EG.Buero.Temperatur.komfort: problem evaluating value if value < 2 else (sh.EG.Buero.Temperatur.modus() & 0x01): unorderable types: str() < int() -- item.py:__run_eval:331
2013-12-22 16:14:42,422 DEBUG Main knx: 1.2.101 set 5/2/1 to 0c60 -- __init__.py:parse_telegram:181
2013-12-22 16:14:43,663 DEBUG Main KNX: 1.2.15 read 5/2/0 -- __init__.py:parse_telegram:203
2013-12-22 16:14:43,742 DEBUG Main knx: 1.2.100 set 5/2/0 to 07c6 -- __init__.py:parse_telegram:181
2013-12-22 16:14:43,754 DEBUG Main KNX: 1.2.15 read 5/2/2 -- __init__.py:parse_telegram:203
2013-12-22 16:14:44,750 DEBUG Main KNX: 1.2.15 read 5/2/3 -- __init__.py:parse_telegram:203
2013-12-22 16:14:45,754 DEBUG Main KNX: 1.2.15 read 5/2/4 -- __init__.py:parse_telegram:203
2013-12-22 16:14:45,819 DEBUG Main knx: 1.2.40 set 5/2/4 to 19.2 -- __init__.py:parse_telegram:190
2013-12-22 16:14:45,826 DEBUG Main KNX: 1.2.15 read 7/2/11 -- __init__.py:parse_telegram:203
2013-12-22 16:14:45,919 DEBUG Main knx: 1.2.120 set 7/2/11 to 0069 -- __init__.py:parse_telegram:181
2013-12-22 16:14:45,925 DEBUG Main KNX: 1.2.15 read 1/2/31 -- __init__.py:parse_telegram:203
2013-12-22 16:14:45,994 DEBUG Main knx: 1.2.2 set 1/2/31 to 00 -- __init__.py:parse_telegram:181
2013-12-22 16:14:55,431 DEBUG env_loc Item env.location.sunset = 2013-12-23 16:14:29.275595+01:00 via Logic None None -- item.py:__update:363
2013-12-22 16:14:55,462 DEBUG env_loc Item env.location.moonrise = 2013-12-22 21:42:06.251976+01:00 via Logic None None -- item.py:__update:363
2013-12-22 16:14:55,937 INFO Main Number of Threads: 7 -- smarthome.py:stop:348
2013-12-22 16:14:55,942 INFO Main Stop Plugins -- plugin.py:stop:70
2013-12-22 16:14:55,958 DEBUG Main WebSocketHandler: closing socket 192.168.2.31:55856 -- connection.py:close:303
2013-12-22 16:14:55,989 DEBUG Scheduler env_loc next time: 2013-12-22 16:44:55+01:00 -- scheduler.py:_next_time:289
2013-12-22 16:14:57,335 DEBUG Main KNX: closing socket 192.168.2.100:6720 -- connection.py:close:303
2013-12-22 16:14:57,340 INFO Main SmartHome.py stopped -- smarthome.py:stop:372
admin@smarthome:/usr/smarthome$ bin/smarthome.py --d
2014-01-05 19:50:58,101 INFO Main Start SmartHome.py 1.0-22-g9c5d8fd -- smarthome.py:__init__:231
2014-01-05 19:50:58,106 DEBUG Main Python 3.2.3 -- smarthome.py:__init__:232
2014-01-05 19:50:58,112 INFO Main Init Scheduler -- scheduler.py:__init__:86
2014-01-05 19:50:58,118 INFO Main Init Plugins -- smarthome.py:start:274
2014-01-05 19:50:58,133 DEBUG Scheduler creating 5 workers -- scheduler.py:run:93
2014-01-05 19:50:58,140 DEBUG Main Plugin: knx -- plugin.py:__init__:43
2014-01-05 19:50:58,166 DEBUG Main Plugin: visu -- plugin.py:__init__:43
2014-01-05 19:50:58,260 DEBUG Main Plugin: cli -- plugin.py:__init__:43
2014-01-05 19:50:58,273 DEBUG Main Plugin: sql -- plugin.py:__init__:43
2014-01-05 19:50:58,305 DEBUG Main SQLite 3.7.13 -- __init__.py:__init__:62
2014-01-05 19:51:00,846 DEBUG Main SQLite: database integrity ok -- __init__.py:__init__:78
2014-01-05 19:51:00,873 DEBUG Main SQLite pack next time: 2014-01-06 03:02:00+01:00 -- scheduler.py:_next_time:289
2014-01-05 19:51:00,879 INFO Main Init Items -- smarthome.py:start:280
2014-01-05 19:51:01,398 DEBUG Main Item env.core.memory = 14955026.283943404 via SQLite None None -- item.py:set:457
2014-01-05 19:51:01,758 DEBUG Main Item env.core.threads = 7.0 via SQLite None None -- item.py:set:457
2014-01-05 19:51:02,111 DEBUG Main Item env.core.garbage = 0.0 via SQLite None None -- item.py:set:457
2014-01-05 19:51:02,117 DEBUG Main Item env.core: no type specified. -- item.py:__init__:242
2014-01-05 19:51:02,157 DEBUG Main Item env.location: no type specified. -- item.py:__init__:242
2014-01-05 19:51:02,506 DEBUG Main Item env.system.load = 0.2586439508382478 via SQLite None None -- item.py:set:457
2014-01-05 19:51:02,516 DEBUG Main Item env.system: no type specified. -- item.py:__init__:242
2014-01-05 19:51:02,520 DEBUG Main Item env: no type specified. -- item.py:__init__:242
2014-01-05 19:51:02,536 DEBUG Main KNX: EG.Buero.Decke listen on 1/2/33 -- __init__.py:parse_item:235
2014-01-05 19:51:02,541 DEBUG Main KNX: EG.Buero.Decke listen on and init with 1/2/33 -- __init__.py:parse_item:244
2014-01-05 19:51:02,555 DEBUG Main KNX: EG.Buero.Temperatur.ist listen on 5/2/4 -- __init__.py:parse_item:235
2014-01-05 19:51:02,566 DEBUG Main KNX: EG.Buero.Temperatur.soll listen on and init with 5/2/24 -- __init__.py:parse_item:244
2014-01-05 19:51:02,582 DEBUG Main KNX: EG.Buero.Temperatur.stellwert listen on and init with 5/2/84 -- __init__.py:parse_item:244
2014-01-05 19:51:02,592 DEBUG Main KNX: EG.Buero.Temperatur.modus listen on and init with 5/2/64 -- __init__.py:parse_item:244
2014-01-05 19:51:02,636 WARNING Main Item EG.Buero.Temperatur.sperren: problem reading cache: [Errno 2] No such file or directory: '/usr/smarthome/var/cache/EG.Buero.Temperatur.sperren' -- item.py:__init__:236
2014-01-05 19:51:02,642 DEBUG Main KNX: EG.Buero.Temperatur.sperren listen on and init with 5/2/74 -- __init__.py:parse_item:244
2014-01-05 19:51:02,647 DEBUG Main Item EG.Buero.Temperatur: no type specified. -- item.py:__init__:242
2014-01-05 19:51:02,656 DEBUG Main KNX: EG.Buero.FensterLinks listen on 4/2/9 -- __init__.py:parse_item:235
2014-01-05 19:51:02,661 DEBUG Main KNX: EG.Buero.FensterLinks listen on and init with 4/2/9 -- __init__.py:parse_item:244
2014-01-05 19:51:02,670 DEBUG Main KNX: EG.Buero.FensterRechts listen on 4/2/10 -- __init__.py:parse_item:235
2014-01-05 19:51:02,674 DEBUG Main KNX: EG.Buero.FensterRechts listen on and init with 4/2/10 -- __init__.py:parse_item:244
2014-01-05 19:51:02,697 DEBUG Main KNX: EG.Buero.Rollo.pos listen on 3/2/98 -- __init__.py:parse_item:235
2014-01-05 19:51:02,702 DEBUG Main KNX: EG.Buero.Rollo.pos listen on and init with 3/2/98 -- __init__.py:parse_item:244
2014-01-05 19:51:02,711 DEBUG Main KNX: EG.Buero.Rollo.shade listen on 3/2/128 -- __init__.py:parse_item:235
2014-01-05 19:51:02,720 DEBUG Main KNX: EG.Buero.Rollo.night listen on 3/2/158 -- __init__.py:parse_item:235
2014-01-05 19:51:02,730 WARNING Main Item EG.Buero.Rollo.auto_down: problem reading cache: [Errno 2] No such file or directory: '/usr/smarthome/var/cache/EG.Buero.Rollo.auto_down' -- item.py:__init__:236
2014-01-05 19:51:02,742 WARNING Main Item EG.Buero.Rollo.auto_up: problem reading cache: [Errno 2] No such file or directory: '/usr/smarthome/var/cache/EG.Buero.Rollo.auto_up' -- item.py:__init__:236
2014-01-05 19:51:02,753 WARNING Main Item EG.Buero.Rollo.auto_shade: problem reading cache: [Errno 2] No such file or directory: '/usr/smarthome/var/cache/EG.Buero.Rollo.auto_shade' -- item.py:__init__:236
2014-01-05 19:51:02,760 DEBUG Main Item EG.Buero.Rollo: no type specified. -- item.py:__init__:242
2014-01-05 19:51:02,768 DEBUG Main KNX: EG.Buero.Praesenz listen on 6/2/2 -- __init__.py:parse_item:235
2014-01-05 19:51:02,773 DEBUG Main Item EG.Buero: no type specified. -- item.py:__init__:242
2014-01-05 19:51:02,786 DEBUG Main KNX: EG.Schlafen.Decke listen on 1/2/35 -- __init__.py:parse_item:235
2014-01-05 19:51:02,791 DEBUG Main KNX: EG.Schlafen.Decke listen on and init with 1/2/35 -- __init__.py:parse_item:244
2014-01-05 19:51:02,804 DEBUG Main KNX: EG.Schlafen.Downlights.dimmen listen on 1/2/120 -- __init__.py:parse_item:235
2014-01-05 19:51:02,809 DEBUG Main KNX: EG.Schlafen.Downlights.dimmen listen on and init with 1/2/120 -- __init__.py:parse_item:244
2014-01-05 19:51:02,814 DEBUG Main KNX: EG.Schlafen.Downlights listen on 1/2/36 -- __init__.py:parse_item:235
2014-01-05 19:51:02,818 DEBUG Main KNX: EG.Schlafen.Downlights listen on and init with 1/2/36 -- __init__.py:parse_item:244
2014-01-05 19:51:02,834 DEBUG Main KNX: EG.Schlafen.Temperatur.ist listen on 5/2/5 -- __init__.py:parse_item:235
2014-01-05 19:51:02,845 DEBUG Main KNX: EG.Schlafen.Temperatur.soll listen on and init with 5/2/25 -- __init__.py:parse_item:244
2014-01-05 19:51:02,860 DEBUG Main KNX: EG.Schlafen.Temperatur.stellwert listen on and init with 5/2/85 -- __init__.py:parse_item:244
2014-01-05 19:51:02,871 DEBUG Main KNX: EG.Schlafen.Temperatur.modus listen on and init with 5/2/65 -- __init__.py:parse_item:244
2014-01-05 19:51:02,915 DEBUG Main KNX: EG.Schlafen.Temperatur.sperren listen on and init with 5/2/75 -- __init__.py:parse_item:244
2014-01-05 19:51:02,920 DEBUG Main Item EG.Schlafen.Temperatur: no type specified. -- item.py:__init__:242
2014-01-05 19:51:02,929 DEBUG Main KNX: EG.Schlafen.FensterLinks listen on 4/2/6 -- __init__.py:parse_item:235
2014-01-05 19:51:02,934 DEBUG Main KNX: EG.Schlafen.FensterLinks listen on and init with 4/2/6 -- __init__.py:parse_item:244
2014-01-05 19:51:02,943 DEBUG Main KNX: EG.Schlafen.FensterRechts listen on 4/2/7 -- __init__.py:parse_item:235
2014-01-05 19:51:02,947 DEBUG Main KNX: EG.Schlafen.FensterRechts listen on and init with 4/2/7 -- __init__.py:parse_item:244
2014-01-05 19:51:02,971 DEBUG Main KNX: EG.Schlafen.Rollo.pos listen on 3/2/96 -- __init__.py:parse_item:235
2014-01-05 19:51:02,976 DEBUG Main KNX: EG.Schlafen.Rollo.pos listen on and init with 3/2/96 -- __init__.py:parse_item:244
2014-01-05 19:51:02,985 DEBUG Main KNX: EG.Schlafen.Rollo.shade listen on 3/2/126 -- __init__.py:parse_item:235
2014-01-05 19:51:02,994 DEBUG Main KNX: EG.Schlafen.Rollo.night listen on 3/2/156 -- __init__.py:parse_item:235
2014-01-05 19:51:03,019 DEBUG Main Item EG.Schlafen.Rollo: no type specified. -- item.py:__init__:242
2014-01-05 19:51:03,028 DEBUG Main KNX: EG.Schlafen.Praesenz listen on 6/2/3 -- __init__.py:parse_item:235
2014-01-05 19:51:03,033 DEBUG Main Item EG.Schlafen: no type specified. -- item.py:__init__:242
2014-01-05 19:51:03,046 DEBUG Main Item EG.Zentral: no type specified. -- item.py:__init__:242
2014-01-05 19:51:03,051 DEBUG Main Item EG: no type specified. -- item.py:__init__:242
2014-01-05 19:51:03,096 DEBUG Main Triggering EG.Buero.Temperatur.komfort - by: Init source: None dest: None value: {'caller': 'Init', 'value': False} -- scheduler.py:trigger:162
2014-01-05 19:51:03,102 DEBUG Main Triggering EG.Buero.Temperatur.standby - by: Init source: None dest: None value: {'caller': 'Init', 'value': False} -- scheduler.py:trigger:162
2014-01-05 19:51:03,109 DEBUG Main Triggering EG.Buero.Temperatur.nacht - by: Init source: None dest: None value: {'caller': 'Init', 'value': False} -- scheduler.py:trigger:162
2014-01-05 19:51:03,117 DEBUG Main Triggering EG.Buero.Temperatur.frostschutz - by: Init source: None dest: None value: {'caller': 'Init', 'value': False} -- scheduler.py:trigger:162
2014-01-05 19:51:03,125 DEBUG Main Triggering EG.Buero.Temperatur.frostalarm - by: Init source: None dest: None value: {'caller': 'Init', 'value': False} -- scheduler.py:trigger:162
2014-01-05 19:51:03,132 DEBUG Main Triggering EG.Buero.Temperatur.heizen - by: Init source: None dest: None value: {'caller': 'Init', 'value': False} -- scheduler.py:trigger:162
2014-01-05 19:51:03,140 DEBUG Main Triggering EG.Schlafen.Temperatur.komfort - by: Init source: None dest: None value: {'caller': 'Init', 'value': False} -- scheduler.py:trigger:162
2014-01-05 19:51:03,147 DEBUG Main Triggering EG.Schlafen.Temperatur.standby - by: Init source: None dest: None value: {'caller': 'Init', 'value': False} -- scheduler.py:trigger:162
2014-01-05 19:51:03,155 DEBUG Main Triggering EG.Schlafen.Temperatur.nacht - by: Init source: None dest: None value: {'caller': 'Init', 'value': False} -- scheduler.py:trigger:162
2014-01-05 19:51:03,162 DEBUG Main Triggering EG.Schlafen.Temperatur.frostschutz - by: Init source: None dest: None value: {'caller': 'Init', 'value': False} -- scheduler.py:trigger:162
2014-01-05 19:51:03,170 DEBUG Main Triggering EG.Schlafen.Temperatur.frostalarm - by: Init source: None dest: None value: {'caller': 'Init', 'value': False} -- scheduler.py:trigger:162
2014-01-05 19:51:03,181 DEBUG Main Triggering EG.Schlafen.Temperatur.heizen - by: Init source: None dest: None value: {'caller': 'Init', 'value': False} -- scheduler.py:trigger:162
2014-01-05 19:51:03,192 INFO Main Start Plugins -- plugin.py:start:65
2014-01-05 19:51:03,257 INFO Main Start Logics -- logic.py:__init__:33
2014-01-05 19:51:03,262 DEBUG Main Reading Logics from /usr/smarthome/lib/env/logic_conf -- logic.py:_read_logics:64
2014-01-05 19:51:03,306 DEBUG Main Reading Logics from /usr/smarthome/etc/logic.conf -- logic.py:_read_logics:64
2014-01-05 19:51:03,371 DEBUG Main Logic: rtr_message_EG_Kueche -- logic.py:__init__:44
2014-01-05 19:51:03,498 DEBUG Main Logic: env_loc -- logic.py:__init__:44
2014-01-05 19:51:03,532 DEBUG Main Logic: logic_sunrise -- logic.py:__init__:44
2014-01-05 19:51:03,534 DEBUG Connections KNX: connected to 192.168.2.100:6720 -- connection.py:connect:386
2014-01-05 19:51:03,543 DEBUG Connections KNX: enable group monitor -- __init__.py:handle_connect:117
2014-01-05 19:51:03,558 DEBUG Connections KNX: init read -- __init__.py:handle_connect:123
2014-01-05 19:51:03,574 DEBUG Main logic_sunrise next time: 2014-01-06 07:20:38.249857+00:00 -- scheduler.py:_next_time:289
2014-01-05 19:51:03,584 DEBUG Main Logic: env_stat -- logic.py:__init__:44
2014-01-05 19:51:03,597 DEBUG Connections WebSocket: binding to 0.0.0.0:2424 (TCP) -- connection.py:connect:161
2014-01-05 19:51:03,617 DEBUG Connections CLI: binding to 0.0.0.0:2323 (TCP) -- connection.py:connect:161
2014-01-05 19:51:03,610 DEBUG Main env_stat next time: 2014-01-05 19:51:15+01:00 -- scheduler.py:_next_time:289
2014-01-05 19:51:03,626 DEBUG Main Logic: rtr_message_EG_Schlafen -- logic.py:__init__:44
2014-01-05 19:51:03,650 DEBUG Main Logic: rtr_message_EG_Bad -- logic.py:__init__:44
2014-01-05 19:51:03,672 DEBUG Main Logic: rtr_message_EG_Buero -- logic.py:__init__:44
2014-01-05 19:51:03,695 DEBUG Main Logic: rtr_message_EG_Wohnen -- logic.py:__init__:44
2014-01-05 19:51:03,717 DEBUG Main Logic: logic_sunset -- logic.py:__init__:44
2014-01-05 19:51:03,742 DEBUG Main logic_sunset next time: 2014-01-06 16:13:57.010014+00:00 -- scheduler.py:_next_time:289
2014-01-05 19:51:03,748 DEBUG Main Logic: hello -- logic.py:__init__:44
2014-01-05 19:51:03,760 DEBUG Main Logic: env_init -- logic.py:__init__:44
2014-01-05 19:51:03,794 DEBUG Main KNX: 1.2.15 read 1/2/33 -- __init__.py:parse_telegram:203
2014-01-05 19:51:03,816 DEBUG Main KNX: 1.2.15 read 5/2/24 -- __init__.py:parse_telegram:203
2014-01-05 19:51:03,829 DEBUG Main KNX: 1.2.15 read 5/2/84 -- __init__.py:parse_telegram:203
2014-01-05 19:51:03,838 DEBUG Main KNX: 1.2.15 read 5/2/64 -- __init__.py:parse_telegram:203
2014-01-05 19:51:03,846 DEBUG Main KNX: 1.2.15 read 5/2/74 -- __init__.py:parse_telegram:203
2014-01-05 19:51:03,854 DEBUG Main KNX: 1.2.15 read 4/2/9 -- __init__.py:parse_telegram:203
2014-01-05 19:51:03,864 DEBUG Main KNX: 1.2.15 read 4/2/10 -- __init__.py:parse_telegram:203
2014-01-05 19:51:03,872 DEBUG Main KNX: 1.2.15 read 3/2/98 -- __init__.py:parse_telegram:203
2014-01-05 19:51:03,878 DEBUG Main KNX: 1.2.15 read 1/2/35 -- __init__.py:parse_telegram:203
2014-01-05 19:51:03,887 DEBUG Main KNX: 1.2.15 read 1/2/120 -- __init__.py:parse_telegram:203
2014-01-05 19:51:03,894 DEBUG Main KNX: 1.2.15 read 1/2/36 -- __init__.py:parse_telegram:203
2014-01-05 19:51:03,901 DEBUG Main knx: 1.2.2 set 1/2/33 to True -- __init__.py:parse_telegram:190
2014-01-05 19:51:03,907 DEBUG Main Item EG.Buero.Decke = True via KNX 1.2.2 1/2/33 -- item.py:__update:363
2014-01-05 19:51:03,914 DEBUG Main KNX: 1.2.15 read 5/2/25 -- __init__.py:parse_telegram:203
2014-01-05 19:51:03,920 DEBUG Main KNX: 1.2.15 read 5/2/85 -- __init__.py:parse_telegram:203
2014-01-05 19:51:03,926 DEBUG Main KNX: 1.2.15 read 5/2/65 -- __init__.py:parse_telegram:203
2014-01-05 19:51:03,932 DEBUG Main KNX: 1.2.15 read 5/2/75 -- __init__.py:parse_telegram:203
2014-01-05 19:51:03,937 DEBUG Main KNX: 1.2.15 read 4/2/6 -- __init__.py:parse_telegram:203
2014-01-05 19:51:03,942 DEBUG Main knx: 1.2.5 set 5/2/24 to 20.0 -- __init__.py:parse_telegram:190
2014-01-05 19:51:03,948 DEBUG Main Item EG.Buero.Temperatur.soll = 20.0 via KNX 1.2.5 5/2/24 -- item.py:__update:363
2014-01-05 19:51:03,956 DEBUG Main KNX: 1.2.15 read 4/2/7 -- __init__.py:parse_telegram:203
2014-01-05 19:51:03,961 DEBUG Main KNX: 1.2.15 read 3/2/96 -- __init__.py:parse_telegram:203
2014-01-05 19:51:03,968 DEBUG Main knx: 1.2.5 set 5/2/84 to 20.0 -- __init__.py:parse_telegram:190
2014-01-05 19:51:03,975 DEBUG Main Item EG.Buero.Temperatur.stellwert = 20.0 via KNX 1.2.5 5/2/84 -- item.py:__update:363
2014-01-05 19:51:03,983 DEBUG Main Triggering EG.Buero.Temperatur.heizen - by: KNX source: 1.2.5 dest: 5/2/84 value: {'source': 'EG.Buero.Temperatur.stellwer -- scheduler.py:trigger:162
2014-01-05 19:51:03,991 DEBUG EG.Buero.Temperatur.heizen Item EG.Buero.Temperatur.heizen = True via Eval EG.Buero.Temperatur.stellwert None -- item.py:__update:363
2014-01-05 19:51:03,994 DEBUG Main knx: 1.2.5 set 5/2/64 to 33 -- __init__.py:parse_telegram:190
2014-01-05 19:51:04,006 DEBUG Main Item EG.Buero.Temperatur.modus = 33 via KNX 1.2.5 5/2/64 -- item.py:__update:363
2014-01-05 19:51:04,011 DEBUG Main Triggering EG.Buero.Temperatur.komfort - by: KNX source: 1.2.5 dest: 5/2/64 value: {'source': 'EG.Buero.Temperatur.modus', -- scheduler.py:trigger:162
2014-01-05 19:51:04,017 DEBUG Main Triggering EG.Buero.Temperatur.standby - by: KNX source: 1.2.5 dest: 5/2/64 value: {'source': 'EG.Buero.Temperatur.modus', -- scheduler.py:trigger:162
2014-01-05 19:51:04,022 DEBUG EG.Buero.Temperatur.komfort Item EG.Buero.Temperatur.komfort = True via Eval EG.Buero.Temperatur.modus None -- item.py:__update:363
2014-01-05 19:51:04,026 DEBUG Main Triggering EG.Buero.Temperatur.nacht - by: KNX source: 1.2.5 dest: 5/2/64 value: {'source': 'EG.Buero.Temperatur.modus', -- scheduler.py:trigger:162
2014-01-05 19:51:04,040 DEBUG Main Triggering EG.Buero.Temperatur.frostschutz - by: KNX source: 1.2.5 dest: 5/2/64 value: {'source': 'EG.Buero.Temperatur.modus', -- scheduler.py:trigger:162
2014-01-05 19:51:04,047 DEBUG Main Triggering EG.Buero.Temperatur.frostalarm - by: KNX source: 1.2.5 dest: 5/2/64 value: {'source': 'EG.Buero.Temperatur.modus', -- scheduler.py:trigger:162
2014-01-05 19:51:04,057 DEBUG Main knx: 1.2.5 set 5/2/74 to False -- __init__.py:parse_telegram:190
2014-01-05 19:51:04,075 DEBUG Main knx: 1.2.15 set 5/2/34 to 01 -- __init__.py:parse_telegram:181
2014-01-05 19:51:04,101 DEBUG Main knx: 1.2.6 set 3/2/98 to 255 -- __init__.py:parse_telegram:190
2014-01-05 19:51:04,107 DEBUG Main Item EG.Buero.Rollo.pos = 255 via KNX 1.2.6 3/2/98 -- item.py:__update:363
2014-01-05 19:51:04,135 DEBUG Main knx: 1.2.2 set 1/2/35 to False -- __init__.py:parse_telegram:190
2014-01-05 19:51:04,229 DEBUG Main knx: 1.2.5 set 5/2/25 to 19.0 -- __init__.py:parse_telegram:190
2014-01-05 19:51:04,236 DEBUG Main Item EG.Schlafen.Temperatur.soll = 19.0 via KNX 1.2.5 5/2/25 -- item.py:__update:363
2014-01-05 19:51:04,245 DEBUG Main knx: 1.2.3 set 1/2/120 to 0 -- __init__.py:parse_telegram:190
2014-01-05 19:51:04,263 DEBUG Main knx: 1.2.5 set 5/2/85 to 0.0 -- __init__.py:parse_telegram:190
2014-01-05 19:51:04,271 DEBUG Main Triggering EG.Schlafen.Temperatur.heizen - by: KNX source: 1.2.5 dest: 5/2/85 value: {'source': 'EG.Schlafen.Temperatur.stell -- scheduler.py:trigger:162
2014-01-05 19:51:04,325 DEBUG Main knx: 1.2.5 set 5/2/65 to 33 -- __init__.py:parse_telegram:190
2014-01-05 19:51:04,331 DEBUG Main Item EG.Schlafen.Temperatur.modus = 33 via KNX 1.2.5 5/2/65 -- item.py:__update:363
2014-01-05 19:51:04,337 DEBUG Main Triggering EG.Schlafen.Temperatur.komfort - by: KNX source: 1.2.5 dest: 5/2/65 value: {'source': 'EG.Schlafen.Temperatur.modus -- scheduler.py:trigger:162
2014-01-05 19:51:04,342 DEBUG Main Triggering EG.Schlafen.Temperatur.standby - by: KNX source: 1.2.5 dest: 5/2/65 value: {'source': 'EG.Schlafen.Temperatur.modus -- scheduler.py:trigger:162
2014-01-05 19:51:04,347 DEBUG EG.Schlafen.Temperatur.komfort Item EG.Schlafen.Temperatur.komfort = True via Eval EG.Schlafen.Temperatur.modus None -- item.py:__update:363
2014-01-05 19:51:04,352 DEBUG Main Triggering EG.Schlafen.Temperatur.nacht - by: KNX source: 1.2.5 dest: 5/2/65 value: {'source': 'EG.Schlafen.Temperatur.modus -- scheduler.py:trigger:162
2014-01-05 19:51:04,366 DEBUG Main Triggering EG.Schlafen.Temperatur.frostschutz - by: KNX source: 1.2.5 dest: 5/2/65 value: {'source': 'EG.Schlafen.Temperatur.modus -- scheduler.py:trigger:162
2014-01-05 19:51:04,374 DEBUG Main Triggering EG.Schlafen.Temperatur.frostalarm - by: KNX source: 1.2.5 dest: 5/2/65 value: {'source': 'EG.Schlafen.Temperatur.modus -- scheduler.py:trigger:162
2014-01-05 19:51:04,386 DEBUG Main knx: 1.2.5 set 5/2/75 to False -- __init__.py:parse_telegram:190
2014-01-05 19:51:04,393 DEBUG Main knx: 1.2.3 set 1/2/36 to False -- __init__.py:parse_telegram:190
2014-01-05 19:51:04,399 DEBUG Main knx: 1.2.15 set 5/2/35 to 01 -- __init__.py:parse_telegram:181
2014-01-05 19:51:04,469 DEBUG Main knx: 1.2.6 set 3/2/96 to 255 -- __init__.py:parse_telegram:190
2014-01-05 19:51:04,475 DEBUG Main Item EG.Schlafen.Rollo.pos = 255 via KNX 1.2.6 3/2/96 -- item.py:__update:363
2014-01-05 19:51:08,872 DEBUG env_loc Item env.location.sunrise = 2014-01-06 08:20:38.249857+01:00 via Logic None None -- item.py:__update:363
2014-01-05 19:51:08,875 INFO hello Hello World! -- hello.py:<module>:3
2014-01-05 19:51:08,878 DEBUG env_init Item env.core.version = 1.0-22-g9c5d8fd via Logic None None -- item.py:__update:363
2014-01-05 19:51:08,880 DEBUG sh.gc Garbage collector: collected 0 objects. -- smarthome.py:_garbage_collection:498
2014-01-05 19:51:08,926 DEBUG env_init Item env.core.start = 2014-01-05 19:51:08.898239+01:00 via Logic None None -- item.py:__update:363
2014-01-05 19:51:08,933 DEBUG env_loc Item env.location.sunset = 2014-01-06 16:27:41.210810+01:00 via Logic None None -- item.py:__update:363
2014-01-05 19:51:08,953 DEBUG env_init Item env.system.name = smarthome.local via Logic None None -- item.py:__update:363
2014-01-05 19:51:09,000 DEBUG env_init Item env.system.start = 2013-12-01 22:51:30.997060+01:00 via Logic None None -- item.py:__update:363
2014-01-05 19:51:09,032 DEBUG env_loc Item env.location.moonrise = 2014-01-06 10:45:12.223980+01:00 via Logic None None -- item.py:__update:363
2014-01-05 19:51:09,093 DEBUG env_loc Item env.location.moonset = 2014-01-05 22:13:49.489963+01:00 via Logic None None -- item.py:__update:363
2014-01-05 19:51:09,134 DEBUG env_loc Item env.location.moonphase = 1 via Logic None None -- item.py:__update:363
2014-01-05 19:51:09,203 DEBUG env_loc Item env.location.night = True via Logic None None -- item.py:__update:363
2014-01-05 19:51:09,249 DEBUG sh.gc Object references: 9533 -- smarthome.py:_maintenance:490
2014-01-05 19:51:09,437 DEBUG Scheduler env_loc next time: 2014-01-05 20:21:09+01:00 -- scheduler.py:_next_time:289
2014-01-05 19:51:09,460 DEBUG Scheduler sh.gc next time: 2014-01-06 02:04:00+01:00 -- scheduler.py:_next_time:289
2014-01-05 19:51:09,872 DEBUG Main knx: 1.2.60 set 5/2/6 to 0c01 -- __init__.py:parse_telegram:181
2014-01-05 19:51:15,105 DEBUG env_stat Item env.core.memory = 15876096 via Logic None None -- item.py:__update:363
2014-01-05 19:51:15,122 DEBUG env_stat Item env.system.load = 0.28 via Logic None None -- item.py:__update:363
2014-01-05 19:51:15,136 DEBUG env_stat Item env.location.moonlight = 25 via Logic None None -- item.py:__update:363
2014-01-05 19:51:15,535 DEBUG Scheduler env_stat next time: 2014-01-05 19:56:15+01:00 -- scheduler.py:_next_time:289
2014-01-05 19:52:11,064 DEBUG Main KNX: 1.2.15 read 5/2/1 -- __init__.py:parse_telegram:203
2014-01-05 19:52:11,123 DEBUG Main knx: 1.2.101 set 5/2/1 to 0c38 -- __init__.py:parse_telegram:181
2014-01-05 19:52:11,129 DEBUG Main KNX: 1.2.15 read 5/2/2 -- __init__.py:parse_telegram:203
2014-01-05 19:52:12,131 DEBUG Main KNX: 1.2.15 read 5/2/3 -- __init__.py:parse_telegram:203
2014-01-05 19:52:13,135 DEBUG Main KNX: 1.2.15 read 5/2/4 -- __init__.py:parse_telegram:203
2014-01-05 19:52:13,196 DEBUG Main knx: 1.2.40 set 5/2/4 to 19.2 -- __init__.py:parse_telegram:190
2014-01-05 19:52:13,202 DEBUG Main KNX: 1.2.15 read 5/2/5 -- __init__.py:parse_telegram:203
2014-01-05 19:52:13,263 DEBUG Main knx: 1.2.82 set 5/2/5 to 19.2 -- __init__.py:parse_telegram:190
2014-01-05 19:52:13,269 DEBUG Main KNX: 1.2.15 read 7/2/11 -- __init__.py:parse_telegram:203
2014-01-05 19:52:13,361 DEBUG Main knx: 1.2.120 set 7/2/11 to 0028 -- __init__.py:parse_telegram:181
2014-01-05 19:52:13,372 DEBUG Main KNX: 1.2.15 read 1/2/31 -- __init__.py:parse_telegram:203
2014-01-05 19:52:13,437 DEBUG Main knx: 1.2.2 set 1/2/31 to 00 -- __init__.py:parse_telegram:181
2014-01-05 19:52:20,027 DEBUG Main knx: 1.2.21 set 7/2/15 to 0e7d -- __init__.py:parse_telegram:181
2014-01-05 19:52:34,552 DEBUG Main knx: 1.2.82 set 5/2/5 to 19.2 -- __init__.py:parse_telegram:190
2014-01-05 19:52:36,504 DEBUG Main knx: 1.1.40 set 1/4/20 to 01 -- __init__.py:parse_telegram:181
2014-01-05 19:52:36,528 DEBUG Main knx: 1.1.1 set 1/4/23 to 01 -- __init__.py:parse_telegram:181
2014-01-05 19:52:47,016 DEBUG Main knx: 1.1.40 set 1/3/45 to 00 -- __init__.py:parse_telegram:181
2014-01-05 19:52:47,148 DEBUG Main knx: 1.1.2 set 1/3/48 to 00 -- __init__.py:parse_telegram:181
2014-01-05 19:54:34,296 DEBUG Main knx: 1.1.20 set 1/3/20 to 00 -- __init__.py:parse_telegram:181
2014-01-05 19:54:34,432 DEBUG Main knx: 1.1.2 set 1/3/23 to 00 -- __init__.py:parse_telegram:181
2014-01-05 19:54:36,520 DEBUG Main knx: 1.1.1 set 1/4/23 to 00 -- __init__.py:parse_telegram:181
2014-01-05 19:55:07,260 DEBUG Main WebSocket: incoming connection from 192.168.2.31:51141 to 0.0.0.0:2424 -- connection.py:accept:188
2014-01-05 19:55:07,651 DEBUG Main 192.168.2.31:51141 sent '{"cmd":"proto","ver":3}' -- __init__.py:json_parse:270
2014-01-05 19:55:07,671 DEBUG Main 192.168.2.31:51141 sent '{"cmd":"monitor","items":["EG.Buero.Decke","EG.Buero.Temperatur.ist","EG.Buero.Temperatur.txtmodus","EG.Buero.Temperatur.sollwertverschiebung","EG.Buero.Temperatur.soll","EG.Buero.Temperatur.komfort","EG.Buero.Temperatur.nacht","EG.Buero.Temperatur.frostschutz","EG.Buero.Temperatur.sperren","EG.Buero.Rollo.pos","EG.Buero.Rollo.move","EG.Buero.Rollo.stop","EG.Buero.Rollo.shade","EG.Buero.Rollo.auto_down","EG.Buero.Rollo.auto_up","EG.Buero.Rollo.auto_shade","EG.Buero.FensterLinks","EG.Buero.FensterRechts","EG.Buero.Praesenz","EG.Buero.Temperatur.stellwert","EG.Wohnen.Temperatur.ist","EG.Wohnen.Praesenz","EG.Wohnen.FensterSuedLinks","EG.Essen.Fenster","EG.Wohnen.Tuer","EG.Wohnen.Couch","EG.Wohnen.Lesen","EG.Essen.Tisch","EG.Wohnen.Temperatur.heizen","EG.Essen.Temperatur.heizen","EG.Schlafen.Temperatur.ist","EG.Schlafen.Praesenz","EG.Schlafen.FensterLinks","EG.Schlafen.FensterRechts","EG.Schlafen.Decke","EG.Schlafen.Downlights","EG.Anbau.Decke","EG.Schlafen.Temperatur.heizen","EG.Buero.Temperatur.heizen","EG.Bad.Temperatur.ist","EG.Bad.Praesenz","EG.Bad.Praesenz.nacht","EG.Bad.Fenster","EG.Bad.Spiegel","EG.Bad.Temperatur.heizen","EG.Kueche.Temperatur.ist","EG.Kueche.Praesenz","EG.Kueche.Tuer","EG.Kueche.Decke","EG.Kueche.Temperatur.heizen","EG.WC.Praesenz","EG.WC.Fenster","EG.WC.Decke","EG.WC.Spiegel"]}' -- __init__.py:json_parse:270
2014-01-05 19:55:07,677 WARNING Main Client 192.168.2.31:51141 requested invalid item: EG.Wohnen.Tuer -- __init__.py:json_parse:294
2014-01-05 19:55:07,683 WARNING Main Client 192.168.2.31:51141 requested invalid item: EG.Bad.Temperatur.heizen -- __init__.py:json_parse:294
2014-01-05 19:55:07,691 WARNING Main Client 192.168.2.31:51141 requested invalid item: EG.WC.Fenster -- __init__.py:json_parse:294
2014-01-05 19:55:07,697 WARNING Main Client 192.168.2.31:51141 requested invalid item: EG.Bad.Spiegel -- __init__.py:json_parse:294
2014-01-05 19:55:07,704 WARNING Main Client 192.168.2.31:51141 requested invalid item: EG.Anbau.Decke -- __init__.py:json_parse:294
2014-01-05 19:55:07,711 WARNING Main Client 192.168.2.31:51141 requested invalid item: EG.Wohnen.Couch -- __init__.py:json_parse:294
2014-01-05 19:55:07,722 WARNING Main Client 192.168.2.31:51141 requested invalid item: EG.Wohnen.Praesenz -- __init__.py:json_parse:294
2014-01-05 19:55:07,731 WARNING Main Client 192.168.2.31:51141 requested invalid item: EG.Kueche.Decke -- __init__.py:json_parse:294
2014-01-05 19:55:07,738 WARNING Main Client 192.168.2.31:51141 requested invalid item: EG.Bad.Fenster -- __init__.py:json_parse:294
2014-01-05 19:55:07,744 WARNING Main Client 192.168.2.31:51141 requested invalid item: EG.Essen.Tisch -- __init__.py:json_parse:294
2014-01-05 19:55:07,754 WARNING Main Client 192.168.2.31:51141 requested invalid item: EG.Kueche.Temperatur.ist -- __init__.py:json_parse:294
2014-01-05 19:55:07,762 WARNING Main Client 192.168.2.31:51141 requested invalid item: EG.Wohnen.Temperatur.heizen -- __init__.py:json_parse:294
2014-01-05 19:55:07,768 WARNING Main Client 192.168.2.31:51141 requested invalid item: EG.Bad.Praesenz -- __init__.py:json_parse:294
2014-01-05 19:55:07,776 WARNING Main Client 192.168.2.31:51141 requested invalid item: EG.WC.Decke -- __init__.py:json_parse:294
2014-01-05 19:55:07,783 WARNING Main Client 192.168.2.31:51141 requested invalid item: EG.WC.Praesenz -- __init__.py:json_parse:294
2014-01-05 19:55:07,789 WARNING Main Client 192.168.2.31:51141 requested invalid item: EG.Kueche.Temperatur.heizen -- __init__.py:json_parse:294
2014-01-05 19:55:07,796 WARNING Main Client 192.168.2.31:51141 requested invalid item: EG.Wohnen.Lesen -- __init__.py:json_parse:294
2014-01-05 19:55:07,803 WARNING Main Client 192.168.2.31:51141 requested invalid item: EG.Bad.Praesenz.nacht -- __init__.py:json_parse:294
2014-01-05 19:55:07,809 WARNING Main Client 192.168.2.31:51141 requested invalid item: EG.Wohnen.Temperatur.ist -- __init__.py:json_parse:294
2014-01-05 19:55:07,816 WARNING Main Client 192.168.2.31:51141 requested invalid item: EG.Bad.Temperatur.ist -- __init__.py:json_parse:294
2014-01-05 19:55:07,822 WARNING Main Client 192.168.2.31:51141 requested invalid item: EG.WC.Spiegel -- __init__.py:json_parse:294
2014-01-05 19:55:07,829 WARNING Main Client 192.168.2.31:51141 requested invalid item: EG.Essen.Fenster -- __init__.py:json_parse:294
2014-01-05 19:55:07,836 WARNING Main Client 192.168.2.31:51141 requested invalid item: EG.Essen.Temperatur.heizen -- __init__.py:json_parse:294
2014-01-05 19:55:07,843 WARNING Main Client 192.168.2.31:51141 requested invalid item: EG.Wohnen.FensterSuedLinks -- __init__.py:json_parse:294
2014-01-05 19:55:07,849 WARNING Main Client 192.168.2.31:51141 requested invalid item: EG.Kueche.Tuer -- __init__.py:json_parse:294
2014-01-05 19:55:07,856 WARNING Main Client 192.168.2.31:51141 requested invalid item: EG.Kueche.Praesenz -- __init__.py:json_parse:294
2014-01-05 19:55:07,864 DEBUG Main 192.168.2.31:51141 sent '{"cmd":"series","item":"EG.Buero.Temperatur.ist","series":"avg","start":"1d"}' -- __init__.py:json_parse:270
2014-01-05 19:55:08,433 DEBUG Main 192.168.2.31:51141 sent '{"cmd":"series","item":"EG.Buero.Temperatur.soll","series":"avg","start":"1d"}' -- __init__.py:json_parse:270
2014-01-05 19:55:08,992 DEBUG Main 192.168.2.31:51141 sent '{"cmd":"series","item":"EG.Buero.Temperatur.stellwert","series":"avg","start":"1d"}' -- __init__.py:json_parse:270
2014-01-05 19:55:17,817 DEBUG Main 192.168.2.31:51141 sent '{"cmd":"item","id":"EG.Buero.Temperatur.komfort","val":"0"}' -- __init__.py:json_parse:270
2014-01-05 19:55:17,823 DEBUG Main Triggering EG.Buero.Temperatur.komfort-eval - by: Visu source: 192.168.2.31:51141 dest: None value: {'dest': None, 'source': '192.168.2.31:5 -- scheduler.py:trigger:162
2014-01-05 19:55:17,830 WARNING EG.Buero.Temperatur.komfort-eval Item EG.Buero.Temperatur.komfort: problem evaluating value if value < 2 else (sh.EG.Buero.Temperatur.modus() & 0x01): unorderable types: str() < int() -- item.py:__run_eval:331
2014-01-05 19:55:18,840 DEBUG Main 192.168.2.31:51141 sent '{"cmd":"item","id":"EG.Buero.Temperatur.frostschutz","val":"1"}' -- __init__.py:json_parse:270
2014-01-05 19:55:18,845 DEBUG Main Triggering EG.Buero.Temperatur.frostschutz-eval - by: Visu source: 192.168.2.31:51141 dest: None value: {'dest': None, 'source': '192.168.2.31:5 -- scheduler.py:trigger:162
2014-01-05 19:55:18,858 WARNING EG.Buero.Temperatur.frostschutz-eval Item EG.Buero.Temperatur.frostschutz: problem evaluating value if value < 2 else ((sh.EG.Buero.Temperatur.modus() & 0x08) >> 3): unorderable types: str() < int() -- item.py:__run_eval:331
[EG]
[[Schlafen]]
[[[Decke]]]
type = bool
visu = yes
knx_dpt = 1
knx_listen = 1/2/35
knx_init = 1/2/35
knx_send = 1/2/5
visu_acl = rw
[[[Downlights]]]
type = bool
visu = yes
knx_dpt = 1
knx_listen = 1/2/36
knx_init = 1/2/36
knx_send = 1/2/6
visu_acl = rw
[[[[dimmen]]]]
type = num
visu = yes
knx_dpt = 5
knx_listen = 1/2/120
knx_init = 1/2/120
knx_send = 1/2/90
visu_acl = rw
[[[Temperatur]]]
[[[[ist]]]]
type = num
visu = yes
knx_dpt = 9
knx_listen = 5/2/5
cache = yes
sqlite = yes
[[[[soll]]]]
type = num
visu = yes
knx_dpt = 9
knx_init = 5/2/25
sqlite = yes
[[[[sollwertverschiebung]]]]
type = num
visu = yes
knx_dpt = 9
knx_send = 5/2/105
visu_acl = rw
[[[[stellwert]]]]
type = num
visu = yes
knx_dpt = 5001
knx_init = 5/2/85
sqlite = yes
enforce_updates = yes
[[[[modus]]]]
type = num
knx_dpt = 20
knx_init = 5/2/65
[[[[txtmodus]]]]
type = str
visu = yes
[[[[komfort]]]]
type = bool
visu = yes
knx_dpt = 1
knx_send = 5/2/35
visu_acl = rw
eval = value if value < 2 else (sh.EG.Schlafen.Temperatur.modus() & 0x01)
eval_trigger = EG.Schlafen.Temperatur.modus
[[[[standby]]]]
type = bool
visu = yes
visu_acl = rw
eval = value if value < 2 else ((sh.EG.Schlafen.Temperatur.modus() & 0x02) >> 1)
[[[[nacht]]]]
type = bool
visu = yes
knx_dpt = 1
knx_send = 5/2/45
visu_acl = rw
eval = value if value < 2 else ((sh.EG.Schlafen.Temperatur.modus() & 0x04) >> 2)
[[[[frostschutz]]]]
type = bool
visu = yes
knx_dpt = 1
knx_send = 5/2/95
visu_acl = rw
eval = value if value < 2 else ((sh.EG.Schlafen.Temperatur.modus() & 0x08) >> 3)
[[[[frostalarm]]]]
type = bool
visu = yes
eval = (sh.EG.Schlafen.Temperatur.modus() & 0x80) >> 7
[[[[heizen]]]]
type = bool
visu = yes
eval = 0 if value == 0 else 1
eval_trigger = EG.Schlafen.Temperatur.stellwert
[[[[sperren]]]]
type = bool
visu = yes
knx_dpt = 1
knx_init = 5/2/75
knx_send = 5/2/75
visu_acl = rw
[[[FensterLinks]]]
type = bool
visu = yes
knx_dpt = 1
knx_listen = 4/2/6
knx_init = 4/2/6
[[[FensterRechts]]]
type = bool
visu = yes
knx_dpt = 1
knx_listen = 4/2/7
knx_init = 4/2/7
[[[Rollo]]]
[[[[move]]]]
type = bool
visu = yes
knx_dpt = 1
knx_send = 3/2/6
visu_acl = rw
[[[[stop]]]]
type = num
visu = yes
knx_dpt = 1
knx_send = 3/2/36
visu_acl = rw
[[[[pos]]]]
type = num
visu = yes
knx_dpt = 5
knx_listen = 3/2/96
knx_init = 3/2/96
knx_send = 3/2/66
visu_acl = rw
[[[[shade]]]]
type = bool
visu = yes
knx_dpt = 1
knx_listen = 3/2/126
knx_send = 3/2/126
visu_acl = rw
[[[[night]]]]
type = bool
visu = yes
knx_dpt = 1
knx_listen = 3/2/156
knx_send = 3/2/156
visu_acl = rw
[[[[auto_down]]]]
type = bool
visu = yes
visu_acl = rw
cache = yes
[[[[auto_up]]]]
type = bool
visu = yes
visu_acl = rw
cache = yes
[[[[auto_shade]]]]
type = bool
visu = yes
visu_acl = rw
cache = yes
[[[Praesenz]]]
type = bool
visu = yes
knx_dpt = 1
knx_listen = 6/2/3
# logic.conf
[hello]
filename = hello.py
crontab = init
[rtr_message_EG_Buero]
filename = rtr_message_EG_Buero.py
watch_item = EG.Buero.Temperatur.modus(), EG.Buero.Temperatur.sperren()
[rtr_message_EG_Schlafen]
filename = rtr_message_EG_Schlafen.py
crontab = init
watch_item = EG.Schlafen.Temperatur.modus(), EG.Schlafen.Temperatur.sperren()
