logic not working
    logic not working
    trying a very basic logic, and it's driving me crazy can't get i t to work
    my files below
    Items
    [Forbrug]
        [[Varme]]
            [[[Spisebord]]]
                type = bool
                visu = yes
                visu_acl = rw
                knx_dpt = 1
                    knx_listen = 0/1/4
                    knx_send = 0/1/4
            [[[Logik]]]
                type = bool
                visu = yes
                visu_acl = rw
                    knx_dpt = 1
                    knx_listen = 0/1/17
    # /usr/local/smarthome/etc/logic.conf
    [MyLogic]
        filename = nat.py
         watch_item = sh.Forbrug.Varme.Logik
    # logics/nat.py
    if not sh.Forbrug.Varme.Spisebord():
        sh.Forbrug.Varme.Spisebord('on')
    You must not use sh. in the watch_item line.
    watch_item = Forbrug.Varme.Logik
    is correct.
    Perhaps you want to add
    enforce_updates = true
    to your item Logik?!?
    Mode
      Where is the problem? Is your logic loaded at the start of sh.py (you should see it in the log file)?
      Mit freundlichen Grüßen
      Niko Will
