smarthome schaltet nicht
    leider läufts noch nicht rund.
    Über smartvisu kommen Schaltrequests rein, die von smarthome korrekt erkannt und interpretiert werden:
    2014-02-20 19:23:07,685 DEBUG Main WebSocket: incoming connection from 192.168.0.114:55838 to 0.0.0.0:2424 -- connection.py:accept:188
    2014-02-20 19:23:07,966 DEBUG Main 192.168.0.114:55838 sent '{"cmd":"proto","ver":3}' -- __init__.py:json_parse:270
    2014-02-20 19:23:07,975 DEBUG Main 192.168.0.114:55838 sent '{"cmd":"monitor","items":["EG.Kueche.Deckenspots"]}' -- __init__.py:json_parse:270
    2014-02-20 19:23:10,092 DEBUG Main 192.168.0.114:55838 sent '{"cmd":"item","id":"EG.Kueche.Deckenspots","val": "1"}' -- __init__.py:json_parse:270
    2014-02-20 19:23:10,110 DEBUG Main Item EG.Kueche.Deckenspots = True via Visu 192.168.0.114:55838 None -- item.py:__update:363
    2014-02-20 19:23:10,660 DEBUG Main 192.168.0.114:55838 sent '{"cmd":"item","id":"EG.Kueche.Deckenspots","val": "0"}' -- __init__.py:json_parse:270
    2014-02-20 19:23:10,666 DEBUG Main Item EG.Kueche.Deckenspots = False via Visu 192.168.0.114:55838 None -- item.py:__update:363
    2014-02-20 19:23:11,171 DEBUG Main 192.168.0.114:55838 sent '{"cmd":"item","id":"EG.Kueche.Deckenspots","val": "1"}' -- __init__.py:json_parse:270
    2014-02-20 19:23:11,177 DEBUG Main Item EG.Kueche.Deckenspots = True via Visu 192.168.0.114:55838 None -- item.py:__update:363
    2014-02-20 19:23:11,649 DEBUG Main 192.168.0.114:55838 sent '{"cmd":"item","id":"EG.Kueche.Deckenspots","val": "0"}' -- __init__.py:json_parse:270
    2014-02-20 19:23:11,656 DEBUG Main Item EG.Kueche.Deckenspots = False via Visu 192.168.0.114:55838 None -- item.py:__update:363
    2014-02-20 19:23:12,131 DEBUG Main 192.168.0.114:55838 sent '{"cmd":"item","id":"EG.Kueche.Deckenspots","val": "1"}' -- __init__.py:json_parse:270
    2014-02-20 19:23:12,137 DEBUG Main Item EG.Kueche.Deckenspots = True via Visu 192.168.0.114:55838 None -- item.py:__update:363
    2014-02-20 19:23:13,796 DEBUG Main 192.168.0.114:55838 sent '{"cmd":"item","id":"EG.Kueche.Deckenspots","val": "0"}' -- __init__.py:json_parse:270
    2014-02-20 19:23:13,802 DEBUG Main Item EG.Kueche.Deckenspots = False via Visu 192.168.0.114:55838 None -- item.py:__update:363
    2014-02-20 19:23:14,200 DEBUG Main 192.168.0.114:55838 sent '{"cmd":"item","id":"EG.Kueche.Deckenspots","val": "1"}' -- __init__.py:json_parse:270
    2014-02-20 19:23:14,206 DEBUG Main Item EG.Kueche.Deckenspots = True via Visu 192.168.0.114:55838 None -- item.py:__update:363
    Trotzdem ist am Aktor Schweigen im Wald. Nichts.
    Über eibd kann ich über groupwrite ohne Probleme schalten:
    root@fileserver:/opt/smarthome# groupswrite ip:localhost 4/0/1 0
    Send request
    "K L I C K"
    root@fileserver:/opt/smarthome# groupswrite ip:localhost 4/0/1 1
    Send request
    "K L I C K"
    Hier ist die Item Konfiguration:
    [EG]
    [[Kueche]]
    [[[Deckenspots]]]
    type = bool
    knx_dpt = 1
    visu_acl = rw
    knx_listen = 10/0/1
    knx_init = 10/0/1
    knx_send = 4/0/1
    Hat jemand einen Tip ?
    sigpic
    Christian Huck
    Tel.: 089 / 122 80 995
    Email: mail@homeintelligence.de
    Web: www.homeintelligence.de
    Mehr lesen, und weniger Fragen. Das ist die letzte Anfänger-Frage für eine Woche, die ich von Dir beantworte.
    KNX-Plugin verwendet?
    Bis nächste Woche
    Marcus
      Vielen Dank für den freundlichem Umgangston.
      Werde mich dann Mal nach "Anfänger"-Freundlichen Alternativen umschauen.
      sigpic
      Christian Huck
        sorry, Du hast Recht. Das war nicht nett.
        Bis bald
        Marcus
          kein Problem.
          Also - JA - es lag am KNX Plugin.
          Und mir war nicht bewusst dass man die Basisfunktionalitäten zunächst über Plugins aktivieren muss.
          Nevermind...
          Schönen Abend.
          sigpic
          Christian Huck
            KNX ist halt hier keine Basisfunktion
            Mit freundlichen Grüßen
            Niko Will
              Dann entschuldige dich bitte noch für deine kostenlose Arbeit, den kostenlosen Support und das kostenlose Image für den Pi, das du alles in deiner Freizeit und freiwillig erstellt. Ach ja und dann entschuldige dich gefälligst auch, das du so doof warst eine FAQ zu erstellen und den Leuten damit zu helfen, nur das sie hier nicht mehr jede Frage 10 mal stellen können!
              ENTSCHULDIGE DICH!
