SMA Plugin Warining
    SMA Plugin Warining
    leider sendet das Plug in nichts auf den Bus, vielleicht erkennt ihr den Fehler.
    plugin.conf
    # plugin.conf
    [knx]
       class_name = KNX
       class_path = plugins.knx
    #   host = 127.0.0.1
    #   port = 6720
    #   send_time = 600 # update date/time every 600 seconds, default none
    #   time_ga = 1/1/1 # default none
    #   date_ga = 1/1/2 # default none
    [sma]
        class_name = SMA
        class_path = plugins.sma
        bt_addr = 00:80:25:2D:41:F4
        password = 0000
        update_cycle = 60
        allowed_timedelta = 10
    [visu]
        class_name = WebSocket
        class_path = plugins.visu
    #   ip='0.0.0.0'
    #   port=2424
    #   acl = ro
        smartvisu_dir = /var/www/smartvisu
    [cli]
        class_name = CLI
        class_path = plugins.cli
        ip = 0.0.0.0
        update = True
    [sql]
        class_name = SQL
        class_path = plugins.sqlite
    #[ow]
    #    class_name = OneWire
    #    class_path = plugins.onewire
    #    host = 127.0.0.1
    #    port = 4304
    items-sma.conf
    [Inverter]
      [[Einspeiseleistung_in_W]]
        type = num
        sma = "AC_P_TOTAL"
        visu_acl = rw
        knx_dpt = 12
        knx_send =8/4/0
        knx_reply = 8/4/0
        knx_init = 8/4/0
      [[Tagesertrag_in_Wh]]
        type = num
        sma = "E_DAY"
        visu_acl = rw
        knx_dpt = 12
        knx_send =8/4/1
        knx_reply = 8/4/1
        knx_init = 8/4/1
      [[Totale_Einspeiseleistung_in_Wh]]
        type = num
        sma = "E_TOTAL"
        visu_acl = rw
        knx_dpt = 12
        knx_send =8/4/2
        knx_reply = 8/4/2
        knx_init = 8/4/2
      [[Serial_Number]]
        type = num
        sma = INV_SERIAL
        visu_acl = rw
        knx_dpt = 12
        knx_send =8/4/3
        knx_reply = 8/4/3
        knx_init = 8/4/3
      [[MAC_Address]]
        type = str
        sma = "INV_ADDRESS"
        visu_acl = rw
        knx_dpt = 16000
        knx_send =8/4/4
        knx_reply = 8/4/4
        knx_init = 8/4/4
      [[Last_Update_Of_Data]]
        type = str
        sma = LAST_UPDATE
        visu_acl = rw
        knx_dpt = 16000
        knx_send =8/4/5
        knx_reply = 8/4/5
        knx_init = 8/4/5
      [[DC_Power_String1_in_W]]
        type = num
        sma = DC_STRING1_P
        visu_acl = rw
        knx_dpt = 12
        knx_send =8/4/6
        knx_reply = 8/4/6
        knx_init = 8/4/6
      [[DC_Power_String2_in_W]]
        type = num
        sma = DC_STRING2_P
        visu_acl = rw
        knx_dpt = 12
        knx_send =8/4/7
        knx_reply = 8/4/7
        knx_init = 8/4/7
      [[DC_Voltage_String1_in_V]]
        type = num
        sma = DC_STRING1_U
        visu_acl = rw
        knx_dpt = 12
        knx_send =8/4/8
        knx_reply = 8/4/8
        knx_init = 8/4/8
      [[DC_Voltage_String2_in_V]]
        type = num
        sma = DC_STRING2_U
        visu_acl = rw
        knx_dpt = 12
        knx_send =8/4/9
        knx_reply = 8/4/9
        knx_init = 8/4/9
      [[DC_Current_String1_in_A]]
        type = num
        sma = DC_STRING1_I
        visu_acl = rw
        knx_dpt = 12
        knx_send =8/4/10
        knx_reply = 8/4/10
        knx_init = 8/4/10
      [[DC_Current_String2_in_A]]
        type = num
        sma = DC_STRING2_I
        visu_acl = rw
        knx_dpt = 12
        knx_send =8/4/11
        knx_reply = 8/4/11
        knx_init = 8/4/11
      [[Operating_Time_in_s]]
        type = num
        sma = OPERATING_TIME
        visu_acl = rw
        knx_dpt = 12
        knx_send =8/4/12
        knx_reply = 8/4/12
        knx_init = 8/4/12
      [[Feeding_Time_in_s]]
        type = num
        sma = FEEDING_TIME
        visu_acl = rw
        knx_dpt = 12
        knx_send =8/4/13
        knx_reply = 8/4/13
        knx_init = 8/4/13
      [[Grid_Frequency_in_Hz]]
        type = num
        sma = GRID_FREQUENCY
        visu_acl = rw
        knx_dpt = 12
        knx_send =8/4/14
        knx_reply = 8/4/14
        knx_init = 8/4/14
      [[Inverter_Status]]
        type = str
        sma = STATUS
        visu_acl = rw
        knx_dpt = 12
        knx_send =8/4/15
        knx_reply = 8/4/15
        knx_init = 8/4/15
      [[Relais_Status]]
        type = str
        sma = GRID_RELAY
        visu_acl = rw
        knx_dpt = 12
        knx_send =8/4/16
        knx_reply = 8/4/16
        knx_init = 8/4/16
      [[Software_Version]]
        type = str
        sma = SW_VERSION
    visu_acl = rw
        knx_dpt = 12
        knx_send =8/4/17
        knx_reply = 8/4/17
        knx_init = 8/4/17
    Log Datei
    2014-03-14 08:07:46,020 INFO     Main         Start SmartHome.py 1.0-32-gfd0043e+ -- smarthome.py:__init__:231
    2014-03-14 08:07:46,027 DEBUG    Main         Python 3.2.3 -- smarthome.py:__init__:232
    2014-03-14 08:07:46,035 INFO     Main         Init Scheduler -- scheduler.py:__init__:86
    2014-03-14 08:07:46,043 INFO     Main         Init Plugins -- smarthome.py:start:274
    2014-03-14 08:07:46,060 DEBUG    Scheduler    creating 5 workers -- scheduler.py:run:93
    2014-03-14 08:07:46,075 DEBUG    Main         Plugin: knx -- plugin.py:__init__:43
    2014-03-14 08:07:46,117 DEBUG    Main         Plugin: sma -- plugin.py:__init__:43
    2014-03-14 08:07:46,146 DEBUG    Main         Plugin: visu -- plugin.py:__init__:43
    2014-03-14 08:07:46,245 DEBUG    Main         Plugin: cli -- plugin.py:__init__:43
    2014-03-14 08:07:46,260 DEBUG    Main         Plugin: sql -- plugin.py:__init__:43
    2014-03-14 08:07:46,297 DEBUG    Main         SQLite 3.7.13 -- __init__.py:__init__:62
    2014-03-14 08:07:46,401 DEBUG    Main         SQLite: database integrity ok -- __init__.py:__init__:78
    2014-03-14 08:07:46,433 DEBUG    Main         SQLite pack next time: 2014-03-15 03:02:00+01:00 -- scheduler.py:_next_time:289
    2014-03-14 08:07:46,442 INFO     Main         Init Items -- smarthome.py:start:280
    2014-03-14 08:07:46,707 DEBUG    Main         Item env.core.memory = 13717504.0 via SQLite None None -- item.py:set:457
    2014-03-14 08:07:46,739 DEBUG    Main         Item env.core.threads = 8.0 via SQLite None None -- item.py:set:457
    2014-03-14 08:07:46,778 DEBUG    Main         Item env.core.garbage = 0.0 via SQLite None None -- item.py:set:457
    2014-03-14 08:07:46,786 DEBUG    Main         Item env.core: no type specified. -- item.py:__init__:242
    2014-03-14 08:07:46,845 DEBUG    Main         Item env.location: no type specified. -- item.py:__init__:242
    2014-03-14 08:07:46,890 DEBUG    Main         Item env.system.load = 0.04 via SQLite None None -- item.py:set:457
    2014-03-14 08:07:46,903 DEBUG    Main         Item env.system: no type specified. -- item.py:__init__:242
    2014-03-14 08:07:46,909 DEBUG    Main         Item env: no type specified. -- item.py:__init__:242
    2014-03-14 08:07:46,925 DEBUG    Main         KNX: Inverter.Einspeiseleistung_in_W listen on and init with 8/4/0 -- __init__.py:parse_item:244
    2014-03-14 08:07:46,931 DEBUG    Main         KNX: Inverter.Einspeiseleistung_in_W reply to 8/4/0 -- __init__.py:parse_item:267
    2014-03-14 08:07:46,936 DEBUG    Main         sma: Inverter.Einspeiseleistung_in_W connected to field AC_P_TOTAL (0x263f01) -- __init__.py:parse_item:340
    2014-03-14 08:07:46,948 DEBUG    Main         KNX: Inverter.Tagesertrag_in_Wh listen on and init with 8/4/1 -- __init__.py:parse_item:244
    2014-03-14 08:07:46,954 DEBUG    Main         KNX: Inverter.Tagesertrag_in_Wh reply to 8/4/1 -- __init__.py:parse_item:267
    2014-03-14 08:07:46,959 DEBUG    Main         sma: Inverter.Tagesertrag_in_Wh connected to field E_DAY (0x262201) -- __init__.py:parse_item:340
    2014-03-14 08:07:46,971 DEBUG    Main         KNX: Inverter.Totale_Einspeiseleistung_in_Wh listen on and init with 8/4/2 -- __init__.py:parse_item:244
    2014-03-14 08:07:46,977 DEBUG    Main         KNX: Inverter.Totale_Einspeiseleistung_in_Wh reply to 8/4/2 -- __init__.py:parse_item:267
    2014-03-14 08:07:46,982 DEBUG    Main         sma: Inverter.Totale_Einspeiseleistung_in_Wh connected to field E_TOTAL (0x260101) -- __init__.py:parse_item:340
    2014-03-14 08:07:46,994 DEBUG    Main         KNX: Inverter.Serial_Number listen on and init with 8/4/3 -- __init__.py:parse_item:244
    2014-03-14 08:07:47,000 DEBUG    Main         KNX: Inverter.Serial_Number reply to 8/4/3 -- __init__.py:parse_item:267
    2014-03-14 08:07:47,005 DEBUG    Main         sma: Inverter.Serial_Number connected to field INV_SERIAL) -- __init__.py:parse_item:350
    2014-03-14 08:07:47,017 DEBUG    Main         KNX: Inverter.MAC_Address listen on and init with 8/4/4 -- __init__.py:parse_item:244
    2014-03-14 08:07:47,022 DEBUG    Main         KNX: Inverter.MAC_Address reply to 8/4/4 -- __init__.py:parse_item:267
    2014-03-14 08:07:47,028 DEBUG    Main         sma: Inverter.MAC_Address connected to field INV_ADDRESS) -- __init__.py:parse_item:350
    2014-03-14 08:07:47,039 DEBUG    Main         KNX: Inverter.Last_Update_Of_Data listen on and init with 8/4/5 -- __init__.py:parse_item:244
    2014-03-14 08:07:47,045 DEBUG    Main         KNX: Inverter.Last_Update_Of_Data reply to 8/4/5 -- __init__.py:parse_item:267
    2014-03-14 08:07:47,051 DEBUG    Main         sma: Inverter.Last_Update_Of_Data connected to field LAST_UPDATE) -- __init__.py:parse_item:350
    2014-03-14 08:07:47,062 DEBUG    Main         KNX: Inverter.DC_Power_String1_in_W listen on and init with 8/4/6 -- __init__.py:parse_item:244
    2014-03-14 08:07:47,068 DEBUG    Main         KNX: Inverter.DC_Power_String1_in_W reply to 8/4/6 -- __init__.py:parse_item:267
    2014-03-14 08:07:47,074 DEBUG    Main         sma: Inverter.DC_Power_String1_in_W connected to field DC_STRING1_P (0x251e01) -- __init__.py:parse_item:340
    2014-03-14 08:07:47,086 DEBUG    Main         KNX: Inverter.DC_Power_String2_in_W listen on and init with 8/4/7 -- __init__.py:parse_item:244
    2014-03-14 08:07:47,093 DEBUG    Main         KNX: Inverter.DC_Power_String2_in_W reply to 8/4/7 -- __init__.py:parse_item:267
    2014-03-14 08:07:47,098 DEBUG    Main         sma: Inverter.DC_Power_String2_in_W connected to field DC_STRING2_P (0x251e02) -- __init__.py:parse_item:340
    2014-03-14 08:07:47,110 DEBUG    Main         KNX: Inverter.DC_Voltage_String1_in_V listen on and init with 8/4/8 -- __init__.py:parse_item:244
    2014-03-14 08:07:47,116 DEBUG    Main         KNX: Inverter.DC_Voltage_String1_in_V reply to 8/4/8 -- __init__.py:parse_item:267
    2014-03-14 08:07:47,122 DEBUG    Main         sma: Inverter.DC_Voltage_String1_in_V connected to field DC_STRING1_U (0x451f01) -- __init__.py:parse_item:340
    2014-03-14 08:07:47,135 DEBUG    Main         KNX: Inverter.DC_Voltage_String2_in_V listen on and init with 8/4/9 -- __init__.py:parse_item:244
    2014-03-14 08:07:47,143 DEBUG    Main         KNX: Inverter.DC_Voltage_String2_in_V reply to 8/4/9 -- __init__.py:parse_item:267
    2014-03-14 08:07:47,148 DEBUG    Main         sma: Inverter.DC_Voltage_String2_in_V connected to field DC_STRING2_U (0x451f02) -- __init__.py:parse_item:340
    2014-03-14 08:07:47,161 DEBUG    Main         KNX: Inverter.DC_Current_String1_in_A listen on and init with 8/4/10 -- __init__.py:parse_item:244
    2014-03-14 08:07:47,167 DEBUG    Main         KNX: Inverter.DC_Current_String1_in_A reply to 8/4/10 -- __init__.py:parse_item:267
    2014-03-14 08:07:47,173 DEBUG    Main         sma: Inverter.DC_Current_String1_in_A connected to field DC_STRING1_I (0x452101) -- __init__.py:parse_item:340
    2014-03-14 08:07:47,184 DEBUG    Main         KNX: Inverter.DC_Current_String2_in_A listen on and init with 8/4/11 -- __init__.py:parse_item:244
    2014-03-14 08:07:47,190 DEBUG    Main         KNX: Inverter.DC_Current_String2_in_A reply to 8/4/11 -- __init__.py:parse_item:267
    2014-03-14 08:07:47,195 DEBUG    Main         sma: Inverter.DC_Current_String2_in_A connected to field DC_STRING2_I (0x452102) -- __init__.py:parse_item:340
    2014-03-14 08:07:47,207 DEBUG    Main         KNX: Inverter.Operating_Time_in_s listen on and init with 8/4/12 -- __init__.py:parse_item:244
    2014-03-14 08:07:47,213 DEBUG    Main         KNX: Inverter.Operating_Time_in_s reply to 8/4/12 -- __init__.py:parse_item:267
    2014-03-14 08:07:47,219 DEBUG    Main         sma: Inverter.Operating_Time_in_s connected to field OPERATING_TIME (0x462e01) -- __init__.py:parse_item:340
    2014-03-14 08:07:47,230 DEBUG    Main         KNX: Inverter.Feeding_Time_in_s listen on and init with 8/4/13 -- __init__.py:parse_item:244
    2014-03-14 08:07:47,236 DEBUG    Main         KNX: Inverter.Feeding_Time_in_s reply to 8/4/13 -- __init__.py:parse_item:267
    2014-03-14 08:07:47,242 DEBUG    Main         sma: Inverter.Feeding_Time_in_s connected to field FEEDING_TIME (0x462f01) -- __init__.py:parse_item:340
    2014-03-14 08:07:47,253 DEBUG    Main         KNX: Inverter.Grid_Frequency_in_Hz listen on and init with 8/4/14 -- __init__.py:parse_item:244
    2014-03-14 08:07:47,259 DEBUG    Main         KNX: Inverter.Grid_Frequency_in_Hz reply to 8/4/14 -- __init__.py:parse_item:267
    2014-03-14 08:07:47,265 DEBUG    Main         sma: Inverter.Grid_Frequency_in_Hz connected to field GRID_FREQUENCY (0x465701) -- __init__.py:parse_item:340
    2014-03-14 08:07:47,276 DEBUG    Main         KNX: Inverter.Inverter_Status listen on and init with 8/4/15 -- __init__.py:parse_item:244
    2014-03-14 08:07:47,282 DEBUG    Main         KNX: Inverter.Inverter_Status reply to 8/4/15 -- __init__.py:parse_item:267
    2014-03-14 08:07:47,288 DEBUG    Main         sma: Inverter.Inverter_Status connected to field STATUS (0x214801) -- __init__.py:parse_item:340
    2014-03-14 08:07:47,300 DEBUG    Main         KNX: Inverter.Relais_Status listen on and init with 8/4/16 -- __init__.py:parse_item:244
    2014-03-14 08:07:47,305 DEBUG    Main         KNX: Inverter.Relais_Status reply to 8/4/16 -- __init__.py:parse_item:267
    2014-03-14 08:07:47,311 DEBUG    Main         sma: Inverter.Relais_Status connected to field GRID_RELAY (0x416401) -- __init__.py:parse_item:340
    2014-03-14 08:07:47,323 DEBUG    Main         KNX: Inverter.Software_Version listen on and init with 8/4/17 -- __init__.py:parse_item:244
    2014-03-14 08:07:47,329 DEBUG    Main         KNX: Inverter.Software_Version reply to 8/4/17 -- __init__.py:parse_item:267
    2014-03-14 08:07:47,335 DEBUG    Main         sma: Inverter.Software_Version connected to field SW_VERSION (0x823401) -- __init__.py:parse_item:340
    2014-03-14 08:07:47,341 DEBUG    Main         Item Inverter: no type specified. -- item.py:__init__:242
    2014-03-14 08:07:47,368 DEBUG    Main         Item first.hallway: no type specified. -- item.py:__init__:242
    2014-03-14 08:07:47,384 DEBUG    Main         Item first.living.light: no type specified. -- item.py:__init__:242
    2014-03-14 08:07:47,499 DEBUG    Main         Item first.living.blind: no type specified. -- item.py:__init__:242
    2014-03-14 08:07:47,516 DEBUG    Main         Item first.living: no type specified. -- item.py:__init__:242
    2014-03-14 08:07:47,521 DEBUG    Main         Item first: no type specified. -- item.py:__init__:242
    2014-03-14 08:07:47,546 DEBUG    Main         KNX: second.sleeping.light.level listen on 3/2/14 -- __init__.py:parse_item:235
    2014-03-14 08:07:47,553 DEBUG    Main         KNX: Light listen on 3/2/12 -- __init__.py:parse_item:235
    2014-03-14 08:07:47,625 DEBUG    Main         Item second.sleeping.blind: no type specified. -- item.py:__init__:242
    2014-03-14 08:07:47,636 DEBUG    Main         Item second.sleeping: no type specified. -- item.py:__init__:242
    2014-03-14 08:07:47,731 DEBUG    Main         Item second.bath.blind: no type specified. -- item.py:__init__:242
    2014-03-14 08:07:47,737 DEBUG    Main         Item second.bath: no type specified. -- item.py:__init__:242
    2014-03-14 08:07:47,742 DEBUG    Main         Item second: no type specified. -- item.py:__init__:242
    2014-03-14 08:07:47,758 DEBUG    Main         KNX: Licht.Buero listen on and init with 1/2/6 -- __init__.py:parse_item:244
    2014-03-14 08:07:47,764 DEBUG    Main         KNX: Licht.Buero reply to 1/2/6 -- __init__.py:parse_item:267
    2014-03-14 08:07:47,770 DEBUG    Main         Item Licht: no type specified. -- item.py:__init__:242
    2014-03-14 08:07:47,784 INFO     Main         Start Plugins -- plugin.py:start:65
    2014-03-14 08:07:47,847 INFO     Main         Start Logics -- logic.py:__init__:33
    2014-03-14 08:07:47,853 DEBUG    Main         Reading Logics from /usr/smarthome/lib/env/logic_conf -- logic.py:_read_logics:64
    2014-03-14 08:07:47,884 DEBUG    Main         Reading Logics from /usr/smarthome/etc/logic.conf -- logic.py:_read_logics:64
    2014-03-14 08:07:47,912 DEBUG    Main         Logic: dummy -- logic.py:__init__:44
    2014-03-14 08:07:47,989 DEBUG    Main         dummy next time: 2014-03-14 08:07:57+01:00 -- scheduler.py:_next_time:289
    2014-03-14 08:07:48,008 DEBUG    Main         Logic: hello -- logic.py:__init__:44
    2014-03-14 08:07:48,024 DEBUG    Main         Logic: env_init -- logic.py:__init__:44
    2014-03-14 08:07:48,057 DEBUG    Main         Logic: env_stat -- logic.py:__init__:44
    2014-03-14 08:07:48,088 DEBUG    Main         env_stat next time: 2014-03-14 08:08:00+01:00 -- scheduler.py:_next_time:289
    2014-03-14 08:07:48,099 DEBUG    Main         Logic: env_loc -- logic.py:__init__:44
    2014-03-14 08:07:48,254 DEBUG    Connections  KNX: connected to 127.0.0.1:6720 -- connection.py:connect:386
    2014-03-14 08:07:48,261 DEBUG    Connections  KNX: enable group monitor -- __init__.py:handle_connect:117
    2014-03-14 08:07:48,267 DEBUG    Connections  KNX: init read -- __init__.py:handle_connect:123
    2014-03-14 08:07:48,304 DEBUG    Connections  WebSocket: binding to 0.0.0.0:2424 (TCP) -- connection.py:connect:161
    2014-03-14 08:07:48,324 DEBUG    Connections  CLI: binding to 0.0.0.0:2323 (TCP) -- connection.py:connect:161
    2014-03-14 08:07:48,366 INFO     sma          sma: via bluetooth connected to 00:80:25:2D:41:F4 -- __init__.py:run:229
    2014-03-14 08:07:48,413 INFO     sma          sma: own bluetooth address: 00:15:83:15:a3:10 -- __init__.py:_inv_connect:510
    2014-03-14 08:07:48,641 INFO     sma          sma: inverter serial = 304956956 -- __init__.py:_inv_login:583
    2014-03-14 08:07:48,648 DEBUG    sma          Item Inverter.MAC_Address = 00:80:25:2D:41:F4 via SMA 304956956 None -- item.py:__update:363
    2014-03-14 08:07:48,661 DEBUG    sma          Item Inverter.Serial_Number = 304956956 via SMA 304956956 None -- item.py:__update:363
    2014-03-14 08:07:48,740 INFO     sma          sma: inverter timestamp = 0s / host timestamp = 1394780868s / diff = -1394780868s -- __init__.py:run:256
    2014-03-14 08:07:48,749 DEBUG    sma          SMA next time: 2014-03-14 08:07:58+01:00 -- scheduler.py:_next_time:289
    2014-03-14 08:07:49,155 DEBUG    Main         KNX: 0.0.0 read 8/4/0 -- __init__.py:parse_telegram:203
    2014-03-14 08:07:49,166 DEBUG    Main         KNX: 0.0.0 read 8/4/1 -- __init__.py:parse_telegram:203
    2014-03-14 08:07:49,179 DEBUG    Main         KNX: 0.0.0 read 8/4/2 -- __init__.py:parse_telegram:203
    2014-03-14 08:07:49,201 DEBUG    Main         KNX: 0.0.0 read 8/4/3 -- __init__.py:parse_telegram:203
    2014-03-14 08:07:49,209 DEBUG    Main         KNX: 0.0.0 read 8/4/4 -- __init__.py:parse_telegram:203
    2014-03-14 08:07:49,220 DEBUG    Main         KNX: 0.0.0 read 8/4/5 -- __init__.py:parse_telegram:203
    2014-03-14 08:07:49,240 DEBUG    Main         KNX: 0.0.0 read 8/4/6 -- __init__.py:parse_telegram:203
    2014-03-14 08:07:49,260 DEBUG    Main         KNX: 0.0.0 read 8/4/7 -- __init__.py:parse_telegram:203
    2014-03-14 08:07:49,267 DEBUG    Main         KNX: 0.0.0 read 8/4/8 -- __init__.py:parse_telegram:203
    2014-03-14 08:07:49,280 DEBUG    Main         KNX: 0.0.0 read 8/4/9 -- __init__.py:parse_telegram:203
    2014-03-14 08:07:49,300 DEBUG    Main         KNX: 0.0.0 read 8/4/10 -- __init__.py:parse_telegram:203
    2014-03-14 08:07:49,307 DEBUG    Main         KNX: 0.0.0 read 8/4/11 -- __init__.py:parse_telegram:203
    2014-03-14 08:07:49,320 DEBUG    Main         KNX: 0.0.0 read 8/4/12 -- __init__.py:parse_telegram:203
    2014-03-14 08:07:49,340 DEBUG    Main         KNX: 0.0.0 read 8/4/13 -- __init__.py:parse_telegram:203
    2014-03-14 08:07:49,355 DEBUG    Main         KNX: 0.0.0 read 8/4/14 -- __init__.py:parse_telegram:203
    2014-03-14 08:07:49,363 DEBUG    Main         KNX: 0.0.0 read 8/4/15 -- __init__.py:parse_telegram:203
    2014-03-14 08:07:49,372 DEBUG    Main         KNX: closing socket 127.0.0.1:6720 -- connection.py:close:303
    2014-03-14 08:07:53,291 INFO     hello        Hello World! -- hello.py:<module>:3
    2014-03-14 08:07:53,294 DEBUG    sh.gc        Garbage collector: collected 0 objects. -- smarthome.py:_garbage_collection:498
    2014-03-14 08:07:53,298 DEBUG    env_init     Item env.core.version = 1.0-32-gfd0043e+ via Logic None None -- item.py:__update:363
    2014-03-14 08:07:53,301 DEBUG    env_loc      Item env.location.sunrise = 2014-03-15 06:32:18.342844+01:00 via Logic None None -- item.py:__update:363
    2014-03-14 08:07:53,358 DEBUG    env_init     Item env.core.start = 2014-03-14 08:07:53.341992+01:00 via Logic None None -- item.py:__update:363
    2014-03-14 08:07:53,405 DEBUG    env_init     Item env.system.name = smarthome.local via Logic None None -- item.py:__update:363
    2014-03-14 08:07:53,435 DEBUG    env_loc      Item env.location.sunset = 2014-03-14 18:21:15.493579+01:00 via Logic None None -- item.py:__update:363
    2014-03-14 08:07:53,443 DEBUG    env_init     Item env.system.start = 2014-03-14 07:21:44.439514+01:00 via Logic None None -- item.py:__update:363
    2014-03-14 08:07:53,549 DEBUG    env_loc      Item env.location.moonrise = 2014-03-14 16:17:56.392142+01:00 via Logic None None -- item.py:__update:363
    2014-03-14 08:07:53,637 DEBUG    env_loc      Item env.location.moonset = 2014-03-15 05:42:17.196463+01:00 via Logic None None -- item.py:__update:363
    2014-03-14 08:07:53,683 DEBUG    env_loc      Item env.location.moonphase = 4 via Logic None None -- item.py:__update:363
    2014-03-14 08:07:53,737 DEBUG    sh.gc        Object references: 9064 -- smarthome.py:_maintenance:490
    2014-03-14 08:07:53,768 DEBUG    env_loc      Item env.location.day = True via Logic None None -- item.py:__update:363
    2014-03-14 08:07:53,860 DEBUG    Scheduler    env_loc next time: 2014-03-14 08:37:53+01:00 -- scheduler.py:_next_time:289
    2014-03-14 08:07:53,888 DEBUG    Scheduler    sh.gc next time: 2014-03-15 02:04:00+01:00 -- scheduler.py:_next_time:289
    2014-03-14 08:07:57,413 DEBUG    dummy        Item first.living.temperature = 23 via Logic None None -- item.py:__update:363
    2014-03-14 08:07:57,424 DEBUG    dummy        Item first.living.humidity = 52 via Logic None None -- item.py:__update:363
    2014-03-14 08:07:57,435 DEBUG    dummy        Item second.sleeping.temperature = 18 via Logic None None -- item.py:__update:363
    2014-03-14 08:07:57,446 DEBUG    dummy        Item second.bath.temperature = 23 via Logic None None -- item.py:__update:363
    2014-03-14 08:07:57,919 DEBUG    Scheduler    dummy next time: 2014-03-14 08:12:57+01:00 -- scheduler.py:_next_time:289
    2014-03-14 08:07:58,438 DEBUG    Connections  KNX: connected to 127.0.0.1:6720 -- connection.py:connect:386
    2014-03-14 08:07:58,455 DEBUG    Connections  KNX: enable group monitor -- __init__.py:handle_connect:117
    2014-03-14 08:07:58,530 WARNING  sma          sma: rx - unknown/malformed response! -- __init__.py:run:312
    2014-03-14 08:07:58,539 WARNING  sma          sma: rx - len=44 data=[0x7e, 0xff, 0x03, 0x60, 0x65, 0x09, 0x90, 0xf4, 0x41, 0x2d, 0x25, 0x80, 0x00, 0x00, 0xe0, 0xb5, 0x00, 0x1c, 0x46, 0x2d, 0x12, 0x00, 0x00, 0xff, 0xff, 0x00, 0x00, 0x05, 0x80, 0x01, 0x02, 0x00, 0x51, 0x00, 0x3f, 0x26, 0x00, 0xff, 0x3f, 0x26, 0x00, 0xce, 0x6c, 0x7e]
     -- __init__.py:run:313
    2014-03-14 08:07:58,548 WARNING  sma          sma: sma2-seq=32773 / sma2-data=[0x01 0x02 0x00 0x51 0x00 0x3f 0x26 0x00 0xff 0x3f 0x26 0x00 0xce 0x6c 0x7e]
     -- __init__.py:run:315
    2014-03-14 08:07:58,949 DEBUG    Scheduler    SMA next time: 2014-03-14 08:08:58+01:00 -- scheduler.py:_next_time:289
    2014-03-14 08:07:59,660 DEBUG    Main         knx: 1.1.10 set 8/1/21 to 00000000 -- __init__.py:parse_telegram:181
    2014-03-14 08:07:59,687 DEBUG    Main         knx: 1.1.10 set 8/1/22 to 00000000 -- __init__.py:parse_telegram:181
    2014-03-14 08:07:59,719 DEBUG    Main         knx: 1.1.10 set 8/1/23 to 41600000 -- __init__.py:parse_telegram:181
    2014-03-14 08:07:59,851 DEBUG    Main         knx: 1.1.10 set 8/1/24 to 436c0000 -- __init__.py:parse_telegram:181
    2014-03-14 08:07:59,881 DEBUG    Main         knx: 1.1.10 set 8/1/25 to 436d0000 -- __init__.py:parse_telegram:181
    2014-03-14 08:07:59,911 DEBUG    Main         knx: 1.1.10 set 8/1/26 to 43690000 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:00,536 DEBUG    env_stat     Item env.core.memory = 13524992 via Logic None None -- item.py:__update:363
    2014-03-14 08:08:00,548 DEBUG    env_stat     Item env.system.load = 0.06 via Logic None None -- item.py:__update:363
    2014-03-14 08:08:00,560 DEBUG    env_stat     Item env.location.moonlight = 94 via Logic None None -- item.py:__update:363
    2014-03-14 08:08:00,762 DEBUG    Main         knx: 1.1.10 set 8/1/27 to 3f3d70a3 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:00,792 DEBUG    Main         knx: 1.1.10 set 8/1/28 to 3f828f5b -- __init__.py:parse_telegram:181
    2014-03-14 08:08:00,822 DEBUG    Main         knx: 1.1.10 set 8/1/29 to 3fb70a3c -- __init__.py:parse_telegram:181
    2014-03-14 08:08:00,980 DEBUG    Scheduler    env_stat next time: 2014-03-14 08:13:00+01:00 -- scheduler.py:_next_time:289
    2014-03-14 08:08:01,791 DEBUG    Main         knx: 1.1.10 set 8/1/15 to 41300000 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:01,820 DEBUG    Main         knx: 1.1.10 set 8/1/18 to 438a8000 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:01,850 DEBUG    Main         knx: 1.1.10 set 8/1/19 to 42b60000 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:01,880 DEBUG    Main         knx: 1.1.10 set 8/1/20 to 42d60000 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:01,906 DEBUG    Main         knx: 1.1.11 set 8/2/9 to 3bc49ba4 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:03,518 WARNING  sma          sma: rx - unknown/malformed response! -- __init__.py:run:312
    2014-03-14 08:08:03,538 WARNING  sma          sma: rx - len=44 data=[0x7e, 0xff, 0x03, 0x60, 0x65, 0x09, 0x90, 0xf4, 0x41, 0x2d, 0x25, 0x80, 0x00, 0x00, 0xe0, 0xb5, 0x00, 0x1c, 0x46, 0x2d, 0x12, 0x00, 0x00, 0xff, 0xff, 0x00, 0x00, 0x06, 0x80, 0x01, 0x02, 0x00, 0x54, 0x00, 0x01, 0x26, 0x00, 0xff, 0x22, 0x26, 0x00, 0x69, 0xb7, 0x7e]
    2014-03-14 08:08:03,548 WARNING  sma          sma: sma2-seq=32774 / sma2-data=[0x01 0x02 0x00 0x54 0x00 0x01 0x26 0x00 0xff 0x22 0x26 0x00 0x69 0xb7 0x7e]
    2014-03-14 08:08:06,809 DEBUG    Main         knx: 1.1.10 set 8/1/15 to 41200000 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:06,839 DEBUG    Main         knx: 1.1.10 set 8/1/18 to 438a8000 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:06,869 DEBUG    Main         knx: 1.1.10 set 8/1/19 to 42b40000 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:06,899 DEBUG    Main         knx: 1.1.10 set 8/1/20 to 42d00000 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:06,926 DEBUG    Main         knx: 1.1.11 set 8/2/9 to 3bc49ba4 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:07,040 DEBUG    Main         knx: 1.1.50 set 7/3/0 to 01 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:07,232 DEBUG    Main         knx: 1.1.254 set 0/5/30 to 3d06 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:07,740 DEBUG    Main         knx: 1.1.254 set 0/5/14 to 340d -- __init__.py:parse_telegram:181
    2014-03-14 08:08:08,040 DEBUG    Main         knx: 1.1.254 set 7/2/0 to a80808 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:08,064 DEBUG    Main         knx: 1.1.254 set 7/2/1 to 0e030e -- __init__.py:parse_telegram:181
    2014-03-14 08:08:08,506 WARNING  sma          sma: rx - unknown/malformed response! -- __init__.py:run:312
    2014-03-14 08:08:08,515 WARNING  sma          sma: rx - len=44 data=[0x7e, 0xff, 0x03, 0x60, 0x65, 0x09, 0x90, 0xf4, 0x41, 0x2d, 0x25, 0x80, 0x00, 0x00, 0xe0, 0xb5, 0x00, 0x1c, 0x46, 0x2d, 0x12, 0x00, 0x00, 0xff, 0xff, 0x00, 0x00, 0x07, 0x80, 0x01, 0x02, 0x80, 0x53, 0x00, 0x1e, 0x25, 0x00, 0xff, 0x1e, 0x25, 0x00, 0xb2, 0x2b, 0x7e]
    2014-03-14 08:08:08,525 WARNING  sma          sma: sma2-seq=32775 / sma2-data=[0x01 0x02 0x80 0x53 0x00 0x1e 0x25 0x00 0xff 0x1e 0x25 0x00 0xb2 0x2b 0x7e]
    2014-03-14 08:08:11,821 DEBUG    Main         knx: 1.1.10 set 8/1/15 to 41200000 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:11,850 DEBUG    Main         knx: 1.1.10 set 8/1/18 to 438d0000 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:11,880 DEBUG    Main         knx: 1.1.10 set 8/1/19 to 42ba0000 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:11,910 DEBUG    Main         knx: 1.1.10 set 8/1/20 to 42ce0000 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:11,939 DEBUG    Main         knx: 1.1.12 set 8/0/7 to 457a0000 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:11,963 DEBUG    Main         knx: 1.1.11 set 8/2/9 to 3bc49ba4 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:12,426 DEBUG    Main         knx: 1.1.50 set 7/1/0 to 658d -- __init__.py:parse_telegram:181
    2014-03-14 08:08:12,886 DEBUG    Main         knx: 1.1.50 set 7/1/3 to 658d -- __init__.py:parse_telegram:181
    2014-03-14 08:08:12,958 DEBUG    Main         knx: 1.1.50 set 7/1/5 to 658d -- __init__.py:parse_telegram:181
    2014-03-14 08:08:13,522 WARNING  sma          sma: rx - unknown/malformed response! -- __init__.py:run:312
    2014-03-14 08:08:13,531 WARNING  sma          sma: rx - len=44 data=[0x7e, 0xff, 0x03, 0x60, 0x65, 0x09, 0x90, 0xf4, 0x41, 0x2d, 0x25, 0x80, 0x00, 0x00, 0xe0, 0xb5, 0x00, 0x1c, 0x46, 0x2d, 0x12, 0x00, 0x00, 0xff, 0xff, 0x00, 0x00, 0x08, 0x80, 0x01, 0x02, 0x80, 0x53, 0x00, 0x1f, 0x45, 0x00, 0xff, 0x21, 0x45, 0x00, 0x0e, 0x05, 0x7e]
    2014-03-14 08:08:13,541 WARNING  sma          sma: sma2-seq=32776 / sma2-data=[0x01 0x02 0x80 0x53 0x00 0x1f 0x45 0x00 0xff 0x21 0x45 0x00 0x0e 0x05 0x7e]
    2014-03-14 08:08:14,700 DEBUG    Main         knx: 1.1.10 set 8/1/21 to 00000000 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:14,730 DEBUG    Main         knx: 1.1.10 set 8/1/22 to 00000000 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:14,760 DEBUG    Main         knx: 1.1.10 set 8/1/23 to 40e00000 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:14,890 DEBUG    Main         knx: 1.1.10 set 8/1/24 to 436c0000 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:14,918 DEBUG    Main         knx: 1.1.10 set 8/1/25 to 436c0000 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:14,947 DEBUG    Main         knx: 1.1.10 set 8/1/26 to 436a0000 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:15,803 DEBUG    Main         knx: 1.1.10 set 8/1/27 to 3f3d70a3 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:15,832 DEBUG    Main         knx: 1.1.10 set 8/1/28 to 3f83d709 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:15,862 DEBUG    Main         knx: 1.1.10 set 8/1/29 to 3fb70a3c -- __init__.py:parse_telegram:181
    2014-03-14 08:08:16,635 DEBUG    Main         knx: 1.1.254 set 0/0/60 to 0c28 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:16,836 DEBUG    Main         knx: 1.1.10 set 8/1/15 to 41000000 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:16,866 DEBUG    Main         knx: 1.1.10 set 8/1/18 to 438c8000 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:16,898 DEBUG    Main         knx: 1.1.10 set 8/1/19 to 42ba0000 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:16,929 DEBUG    Main         knx: 1.1.10 set 8/1/20 to 42ce0000 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:16,958 DEBUG    Main         knx: 1.1.11 set 8/2/9 to 3bc49ba4 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:17,091 DEBUG    Main         knx: 1.1.254 set 0/0/62 to 0333 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:17,118 DEBUG    Main         knx: 1.1.254 set 0/0/61 to 6e -- __init__.py:parse_telegram:181
    2014-03-14 08:08:17,150 DEBUG    Main         knx: 1.1.254 set 0/0/63 to 41000000 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:17,807 DEBUG    Main         knx: 1.1.50 set 7/3/0 to 01 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:18,540 WARNING  sma          sma: rx - unknown/malformed response! -- __init__.py:run:312
    2014-03-14 08:08:18,548 WARNING  sma          sma: rx - len=44 data=[0x7e, 0xff, 0x03, 0x60, 0x65, 0x09, 0x90, 0xf4, 0x41, 0x2d, 0x25, 0x80, 0x00, 0x00, 0xe0, 0xb5, 0x00, 0x1c, 0x46, 0x2d, 0x12, 0x00, 0x00, 0xff, 0xff, 0x00, 0x00, 0x09, 0x80, 0x01, 0x02, 0x00, 0x54, 0x00, 0x2e, 0x46, 0x00, 0xff, 0x2f, 0x46, 0x00, 0x61, 0x4f, 0x7e]
    2014-03-14 08:08:18,558 WARNING  sma          sma: sma2-seq=32777 / sma2-data=[0x01 0x02 0x00 0x54 0x00 0x2e 0x46 0x00 0xff 0x2f 0x46 0x00 0x61 0x4f 0x7e]
    2014-03-14 08:08:20,528 DEBUG    Main         knx: 1.1.254 set 0/0/3 to 159d -- __init__.py:parse_telegram:181
    2014-03-14 08:08:21,048 DEBUG    Main         knx: 1.1.254 set 7/2/0 to a80815 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:21,091 DEBUG    Main         knx: 1.1.254 set 7/2/1 to 0e030e -- __init__.py:parse_telegram:181
    2014-03-14 08:08:21,851 DEBUG    Main         knx: 1.1.10 set 8/1/15 to 41600000 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:21,881 DEBUG    Main         knx: 1.1.10 set 8/1/18 to 438c8000 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:21,911 DEBUG    Main         knx: 1.1.10 set 8/1/19 to 42ba0000 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:21,941 DEBUG    Main         knx: 1.1.10 set 8/1/20 to 42cc0000 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:21,971 DEBUG    Main         knx: 1.1.11 set 8/2/9 to 3bc49ba4 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:23,529 WARNING  sma          sma: rx - unknown/malformed response! -- __init__.py:run:312
    2014-03-14 08:08:23,538 WARNING  sma          sma: rx - len=44 data=[0x7e, 0xff, 0x03, 0x60, 0x65, 0x09, 0x90, 0xf4, 0x41, 0x2d, 0x25, 0x80, 0x00, 0x00, 0xe0, 0xb5, 0x00, 0x1c, 0x46, 0x2d, 0x12, 0x00, 0x00, 0xff, 0xff, 0x00, 0x00, 0x0a, 0x80, 0x01, 0x02, 0x00, 0x51, 0x00, 0x57, 0x46, 0x00, 0xff, 0x57, 0x46, 0x00, 0x28, 0xa8, 0x7e]
    2014-03-14 08:08:23,548 WARNING  sma          sma: sma2-seq=32778 / sma2-data=[0x01 0x02 0x00 0x51 0x00 0x57 0x46 0x00 0xff 0x57 0x46 0x00 0x28 0xa8 0x7e]
    2014-03-14 08:08:26,222 DEBUG    Main         knx: 1.1.254 set 0/0/30 to 07a4 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:26,580 DEBUG    Main         knx: 1.1.254 set 0/0/31 to 75 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:26,605 DEBUG    Main         knx: 1.1.254 set 0/0/32 to 02fa -- __init__.py:parse_telegram:181
    2014-03-14 08:08:26,650 DEBUG    Main         knx: 1.1.254 set 0/0/33 to 40f7ae14 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:26,865 DEBUG    Main         knx: 1.1.10 set 8/1/15 to 40800000 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:26,893 DEBUG    Main         knx: 1.1.10 set 8/1/18 to 438d8000 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:26,923 DEBUG    Main         knx: 1.1.10 set 8/1/19 to 42ba0000 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:26,953 DEBUG    Main         knx: 1.1.10 set 8/1/20 to 42d00000 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:26,985 DEBUG    Main         knx: 1.1.11 set 8/2/9 to 3bc49ba4 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:28,461 DEBUG    Main         knx: 1.1.50 set 7/3/0 to 01 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:28,547 WARNING  sma          sma: rx - unknown/malformed response! -- __init__.py:run:312
    2014-03-14 08:08:28,565 WARNING  sma          sma: rx - len=44 data=[0x7e, 0xff, 0x03, 0x60, 0x65, 0x09, 0x90, 0xf4, 0x41, 0x2d, 0x25, 0x80, 0x00, 0x00, 0xe0, 0xb5, 0x00, 0x1c, 0x46, 0x2d, 0x12, 0x00, 0x00, 0xff, 0xff, 0x00, 0x00, 0x0b, 0x80, 0x01, 0x02, 0x80, 0x51, 0x00, 0x48, 0x21, 0x00, 0xff, 0x48, 0x21, 0x00, 0x66, 0xa4, 0x7e]
    2014-03-14 08:08:28,575 WARNING  sma          sma: sma2-seq=32779 / sma2-data=[0x01 0x02 0x80 0x51 0x00 0x48 0x21 0x00 0xff 0x48 0x21 0x00 0x66 0xa4 0x7e]
    2014-03-14 08:08:29,529 DEBUG    Main         knx: 1.1.254 set 0/0/6 to 0d2d -- __init__.py:parse_telegram:181
    2014-03-14 08:08:29,742 DEBUG    Main         knx: 1.1.10 set 8/1/21 to 00000000 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:29,772 DEBUG    Main         knx: 1.1.10 set 8/1/22 to 00000000 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:29,803 DEBUG    Main         knx: 1.1.10 set 8/1/23 to 40800000 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:29,932 DEBUG    Main         knx: 1.1.10 set 8/1/24 to 436c0000 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:29,963 DEBUG    Main         knx: 1.1.10 set 8/1/25 to 436c0000 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:29,993 DEBUG    Main         knx: 1.1.10 set 8/1/26 to 436a0000 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:30,405 DEBUG    Main         knx: 1.1.9 set 4/2/5 to 00 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:30,486 DEBUG    Main         knx: 15.15.255 set 4/4/0 to 00 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:30,510 DEBUG    Main         knx: 1.1.9 set 4/0/0 to 00 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:30,608 DEBUG    Main         knx: 1.1.9 set 4/0/1 to 00 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:30,654 DEBUG    Main         knx: 15.15.255 set 4/4/1 to 01 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:30,710 DEBUG    Main         knx: 1.1.9 set 4/0/5 to 00 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:30,814 DEBUG    Main         knx: 1.1.9 set 4/0/6 to 01 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:30,834 DEBUG    Main         knx: 15.15.255 set 2/1/0 to 00 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:30,860 DEBUG    Main         knx: 1.1.10 set 8/1/27 to 3f3d70a3 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:30,890 DEBUG    Main         knx: 1.1.10 set 8/1/28 to 3f866666 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:30,921 DEBUG    Main         knx: 1.1.10 set 8/1/29 to 3fb851eb -- __init__.py:parse_telegram:181
    2014-03-14 08:08:30,942 DEBUG    Main         knx: 1.1.9 set 4/0/7 to 00 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:31,019 DEBUG    Main         knx: 1.1.9 set 4/0/10 to 00 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:31,885 DEBUG    Main         knx: 1.1.10 set 8/1/15 to 40c00000 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:31,915 DEBUG    Main         knx: 1.1.10 set 8/1/18 to 438c8000 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:31,938 DEBUG    Main         knx: 1.1.254 set 0/1/50 to 07f8 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:31,964 DEBUG    Main         knx: 1.1.10 set 8/1/19 to 42b80000 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:31,989 DEBUG    Main         knx: 1.1.12 set 8/0/7 to 457a0000 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:32,016 DEBUG    Main         knx: 1.1.11 set 8/2/9 to 3ba3d70a -- __init__.py:parse_telegram:181
    2014-03-14 08:08:32,041 DEBUG    Main         knx: 1.1.10 set 8/1/20 to 42d00000 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:32,065 DEBUG    Main         knx: 1.1.254 set 7/2/0 to a80820 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:32,102 DEBUG    Main         knx: 1.1.254 set 7/2/1 to 0e030e -- __init__.py:parse_telegram:181
    2014-03-14 08:08:32,294 DEBUG    Main         knx: 1.1.254 set 0/1/51 to 6e -- __init__.py:parse_telegram:181
    2014-03-14 08:08:32,323 DEBUG    Main         knx: 1.1.254 set 0/1/52 to 02e5 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:32,362 DEBUG    Main         knx: 1.1.254 set 0/1/53 to 40f3851f -- __init__.py:parse_telegram:181
    2014-03-14 08:08:33,541 WARNING  sma          sma: rx - unknown/malformed response! -- __init__.py:run:312
    2014-03-14 08:08:33,562 WARNING  sma          sma: rx - len=44 data=[0x7e, 0xff, 0x03, 0x60, 0x65, 0x09, 0x90, 0xf4, 0x41, 0x2d, 0x25, 0x80, 0x00, 0x00, 0xe0, 0xb5, 0x00, 0x1c, 0x46, 0x2d, 0x12, 0x00, 0x00, 0xff, 0xff, 0x00, 0x00, 0x0c, 0x80, 0x01, 0x02, 0x80, 0x51, 0x00, 0x64, 0x41, 0x00, 0xff, 0x64, 0x41, 0x00, 0x84, 0x42, 0x7e]
    2014-03-14 08:08:33,577 WARNING  sma          sma: sma2-seq=32780 / sma2-data=[0x01 0x02 0x80 0x51 0x00 0x64 0x41 0x00 0xff 0x64 0x41 0x00 0x84 0x42 0x7e]
    2014-03-14 08:08:33,846 DEBUG    Main         knx: 1.1.19 set 1/0/0 to 00 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:33,911 DEBUG    Main         knx: 1.1.2 set 1/0/1 to 00 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:33,978 DEBUG    Main         KNX: 15.15.255 read 1/0/0 -- __init__.py:parse_telegram:203
    2014-03-14 08:08:33,999 DEBUG    Main         knx: 1.1.50 set 7/3/0 to 01 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:34,019 DEBUG    Main         knx: 1.1.2 set 1/0/0 to 00 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:35,014 DEBUG    Main         knx: 1.1.12 set 8/0/6 to 001100a2 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:36,470 DEBUG    Main         knx: 1.1.254 set 0/0/4 to 0cd5 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:36,896 DEBUG    Main         knx: 1.1.10 set 8/1/15 to 40e00000 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:36,923 DEBUG    Main         knx: 1.1.10 set 8/1/18 to 438e0000 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:36,953 DEBUG    Main         knx: 1.1.10 set 8/1/19 to 42b60000 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:36,983 DEBUG    Main         knx: 1.1.10 set 8/1/20 to 42d00000 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:37,017 DEBUG    Main         knx: 1.1.11 set 8/2/9 to 3ba3d70a -- __init__.py:parse_telegram:181
    2014-03-14 08:08:37,312 DEBUG    Main         knx: 1.1.10 set 8/1/3 to 00001987 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:37,339 DEBUG    Main         knx: 1.1.10 set 8/1/4 to 00000081 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:37,369 DEBUG    Main         knx: 1.1.10 set 8/1/5 to 000000eb -- __init__.py:parse_telegram:181
    2014-03-14 08:08:37,399 DEBUG    Main         knx: 1.1.10 set 8/1/6 to 00000840 -- __init__.py:parse_telegram:181
    2014-03-14 08:08:37,924 INFO     Main         Number of Threads: 8 -- smarthome.py:stop:348
    2014-03-14 08:08:37,930 INFO     Main         Stop Plugins -- plugin.py:stop:70
    2014-03-14 08:08:38,556 WARNING  sma          sma: rx - unknown/malformed response! -- __init__.py:run:312
    2014-03-14 08:08:38,572 WARNING  sma          sma: rx - len=44 data=[0x7e, 0xff, 0x03, 0x60, 0x65, 0x09, 0x90, 0xf4, 0x41, 0x2d, 0x25, 0x80, 0x00, 0x00, 0xe0, 0xb5, 0x00, 0x1c, 0x46, 0x2d, 0x12, 0x00, 0x00, 0xff, 0xff, 0x00, 0x00, 0x0d, 0x80, 0x01, 0x02, 0x00, 0x58, 0x00, 0x34, 0x82, 0x00, 0xff, 0x34, 0x82, 0x00, 0x4f, 0xb6, 0x7e]
    2014-03-14 08:08:38,582 WARNING  sma          sma: sma2-seq=32781 / sma2-data=[0x01 0x02 0x00 0x58 0x00 0x34 0x82 0x00 0xff 0x34 0x82 0x00 0x4f 0xb6 0x7e]
    2014-03-14 08:08:44,280 DEBUG    Main         KNX: closing socket 127.0.0.1:6720 -- connection.py:close:303
    2014-03-14 08:08:44,599 DEBUG    sma          sma: connection to inverter closed -- __init__.py:run:321
    2014-03-14 08:08:44,606 INFO     Main         SmartHome.py stopped -- smarthome.py:stop:372
    Init SmartHome.py 1.0-32-gfd0043e+
    Kann. Mir keiner helfen?
    Gesendet von meinem iPad mit Tapatalk
