Multiple if statements?
    Hello Guys.
    I'm having a bit difficult with a logic, the code is:
    if sh.Sleeping_Room.Heating.Mode == 1:
    	if sh.Sleeping_Room.Heating.SP() > 5.0:
    		sh.Sleeping_Room.Heating.Valve('1')
    	else:
    		sh.Sleeping_Room.Heating.Valve('0')
    elif sh.Sleeping_Room.Heating.Mode == 3:
    	if sh.Sleeping_Room.Heating.SP() > 2.0:
    	else:
    else:
    This doesn't work, in the debugger i can see that the mode changes to 1, then it seems like it doesn't execute the next IF statement??
    If i do like this:
    	else:
    it works like it should.... What am i doing wrong?
    The Heating.Mode is 1 byte output from the RTR widget.....
    No one has a idea?
      Try this one:
      if sh.Sleeping_Room.Heating.Mode() == 1 and sh.Sleeping_Room.Heating.SP() > 5.0:
      else:
        Okay, i will try that...
        But, shouldn't it be possible with multiple statements? I think in other cases that would be needed....
          You forgot some brackets:
          if [URL="http://redaktion.knx-user-forum.de/lexikon/sh/"]sh[/URL].Sleeping_Room.Heating.Mode[COLOR=Red][B]()[/B][/COLOR] == 1:
                  if [URL="http://redaktion.knx-user-forum.de/lexikon/sh/"]sh[/URL].Sleeping_Room.Heating.SP() > 5.0:
                  else:
          and so on
          Btw: Without actually having checked the whole logic itself, it seems a bit complicated to me.
          Why not doing something like this (UNTESTED of course)?
          if [URL="http://redaktion.knx-user-forum.de/lexikon/sh/"]sh[/URL].Sleeping_Room.Heating.Mode() == 1 and [URL="http://redaktion.knx-user-forum.de/lexikon/sh/"]sh[/URL].Sleeping_Room.Heating.SP() > 5:
          elif: if [URL="http://redaktion.knx-user-forum.de/lexikon/sh/"]sh[/URL].Sleeping_Room.Heating.Mode() == 3 and [URL="http://redaktion.knx-user-forum.de/lexikon/sh/"]sh[/URL].Sleeping_Room.Heating.SP() > 2:
          else:
          Cheers, Martin
            Yes, that's also possible.
            Was just my first try to see what i can and can't do with the logics
            The example you write is much lesser complicated.... But that also uses the elif, as i was trying to get working - thanks a lot
              Without elif (maybe):
              if ([URL="http://redaktion.knx-user-forum.de/lexikon/sh/"]sh[/URL].Sleeping_Room.Heating.Mode() == 1 and [URL="http://redaktion.knx-user-forum.de/lexikon/sh/"]sh[/URL].Sleeping_Room.Heating.SP() > 5:) or ([URL="http://redaktion.knx-user-forum.de/lexikon/sh/"]sh[/URL].Sleeping_Room.Heating.Mode() == 3 and [URL="http://redaktion.knx-user-forum.de/lexikon/sh/"]sh[/URL].Sleeping_Room.Heating.SP() > 2):
                   [URL="http://redaktion.knx-user-forum.de/lexikon/sh/"]sh[/URL].Sleeping_Room.Heating.Valve('1')
              else:
                   [URL="http://redaktion.knx-user-forum.de/lexikon/sh/"]sh[/URL].Sleeping_Room.Heating.Valve('0')
                else:
                Yes that's also possible i think, but the expressions gets very long then, and not pretty
                Normally it's possible to use multiple IF, or even better would be a CASE statement
                  Hello again
                  I've done some coding in Visual Studio with the Python package installed, which gives me a big help writing logics and stuff for the sh.py.
                  And again this thread confuses me: If i do like this in Visual Studio, it works great:
                  if weekday == 6 or weekday == 7 and int_t3_on_hour != 0 and int_t3_on_minute != 0 :
                      print(7)
                      if hour == int_t3_on_hour and minute == int_t3_on_minute and outside_light == False :
                          outside_light = True
                          print(8)
                      if hour == int_t3_off_hour and minute == int_t3_off_minute and outside_light == True :
                          outside_light = False
                          print(9)
                  But if i use that in the sh.py it only prints the number "7" in the debugger, which seems like it doesn't "eat" the next IF statement - even if it does in Visual Studio..... Could some one please explain why or how i use multiple if statements?
                  ------------edit:
                  Seems like the best way is to use a / to break a line and then use the AND operator :/
