Type num mismatch
    Type num mismatch
    I am making heating controller to my summer cottage. I am using 1-wire DS18B20 temperature sensor which is connected to Raspberry Pi's GPIO 4. I try to start using OWFS, but I didn't get it working with temperature sensor connected straight to RPi. So I made python script which reads temperature straigt from file. Now I have problem copying temperature to smarthome. Following warning comes " temperature does not match type num".
    I have same kind of problem with my knx-house copying from/to Hager thermostate.
    Here is my config files:
    items/smarthome.conf:
    [mokki]
        [[sisa]]
           [[[temperature]]]
                type = num
                visu_acl = rw
                sqlite = yes
    etc/logic.conf:
    [temperature_change_lookup] # checks for temperature changes
     	filename = temperature_change_lookup.py
    	crontab = init
    logics/temperature_change_lookup.py:
    #!/usr/bin/env python3
    import time
    while 1:
     # Open the file that we viewed earlier so that python can see what is in it. Replace the serial number as before.
     tfile = open("/sys/bus/w1/devices/28-000005a037fc/w1_slave")
     # Read all of the text in the file.
     text = tfile.read()
     # Close the file now that the text has been read.
     tfile.close()
     # Split the text with new lines (\n) and select the second line.
     secondline = text.split("\n")[1]
     # Split the line into words, referring to the spaces, and select the 10th word (counting from 0).
     temperaturedata = secondline.split(" ")[9]
     print ("temperaturedata: ", temperaturedata) #debuging
     # The first two characters are "t=", so get rid of those and convert the temperature from a string to a number.
     temperature = float(temperaturedata[2:])
     # Put the decimal point in the right place and display it.
     temperature = temperature / 1000.0
     print ("Temperature: ",temperature) #debuging
     sh.mokki.sisa.temperature('temperature')
     print ("sh.mokki.sisa.temperature: ",sh.mokki.sisa.temperature()) #debuging
     time.sleep(10) # wait untill checks temperature again
    smarthome.py debug:
    2014-04-02 11:33:21,654 INFO     Main         Thread: Main, still alive -- smarthome.py:stop:370
    temperaturedata:  t=22437
    Temperature:  [COLOR="Red"]22.437[/COLOR]
    [COLOR="Red"]2014-04-02 11:33:23,033 WARNING  temperature_change_lookup Item mokki.sisa.temperature: value temperature does not match type num. Via Logic None -- item.py:__update:347[/COLOR]
    sh.mokki.sisa.temperature: [COLOR="red"] 0[/COLOR]
    So could somebody help me what I am doing wrong!
    remove the ' around temperature. If you do that, it will be interpreted as a string.
    So Long
    Marcus
    Gesendet von unterwegs
      Thank you! That was easy. Now I can also complete my house knx-system.
