Variables in logics?
    Hello.
    Can you program the logics, like it was traditionally python? etc. like creating an temp variable just by assigning a value to the?
    et.
    a=50
    Or do i have to create the item in the "items" config?
    I've tried just assign a value to a variable inside the logics, but i get an attribute error - so i was wondering if it's my code, or i have to create the item before writing to it?
    It's just for internally use in the logics
    et.
    a=50
    yes.
    so long
    Marcus
      Great, so if i can run the scripts in Visual Studio with a python compiler, then it should also work in sh.py
      It's a bit easier to do when you are pretty n00b at python
