Immer aktuell: Sonos-Broker und Sonos-Plugin / HowTo
Sonos-Broker v1.0 (2017-02-18)- Attention: cleaned-up configuration file. Please re-configure your Sonos Broker installation
- command "transport_actions" to Sonos Broker and Sonos command line tool
- this options shows all possible actions for the current track (e.g. Next, Stop, Play ...)
- command 'nightmode' added (only for supported speakers)
- bug: Spotify Radio was handled as a normal radio station and should be fixed
- GoogleTTS improvements
- GoogleTTS: files now stored with md5 sum of tts_language and tts_string to reduce the filename length
- GoogleTTS: now works in streaming mode per default, no web service is needed.
- GoogleTTS: the local ip address for the streaming url will be detected automatically (by default)
- play_tts: (optional) attribute 'force_stream_mode' (re)-added to Sonos Broker and Command line tool
- bug: endless loop while trying to play a track from a non-existing url
- bug: wrong path in systemd script
- bug: the 'volume' of all zone members will now be restored correctly after playing the snippet
- command optional parameter 'play' added to command "unjoin"
- with 'play' set to true, the prevoiusly played track (before joining a group) will resumed
- changed executable name from "sonos_broker" to "sonos-broker"
- changed command line tool from "sonos_cmd" to "sonos-cmd"
- changed default installation path of sonos_broker.cfg to /etc/default/sonos-broker
- stopping a running Sonos Broker instance is handled a bit more gracefully
- updated setup script
- auto-start scripts for systemd and upstart automatically placed in the appropriate folder by the installation script
- 'daemonize' behaviour removed
- unnecessary parameter 'stop' removed
- updated documentation
- added "zone_member" command to Sonos Broker (to retrieve this value actively)
- added commands 'join' and 'unjoin' to Sonos Broker commandline tool
- bug: error when trying to decode non-ascii chars and the systems stdout was no set to utf8 (added to FAQ, see documentation)
Sonos-Plugin for SmarthomeNG v1.0 (2017-02-18)- Attention: only compatible with SmarthomeNG
- SmartPlugin functionality added
- dpt3 functionality added for volume item
- command 'transport_actions' added
- play_tts: attribute 'force_stream_mode' (re)-added
- added attribute 'play' to 'unjoin'
- resumes the last played track / radio before join to another group
- added missing 'track_album' property
- add new property 'playlist_total_tracks'
- attribute 'is_coordiantor' in example has now the right value
- version string updated
- change expected Sonos Broker version to v1.0
Sonos-Widget for SmartVISU (2017-02-18)- complete rewrite of widget for Sonos Broker >= 1.0
- compatible for SmartVISU 2.8 and 2.9 (untested)
DOKUMENTATION:
Sonos-Broker
SmarthomeNG-Plugin
Sonos-Widget
DOWNLOADS:
Sonos-Broker
Smarthome-Plugin
Sonos-Widget
Bitte keine Antworten auf diesen Post. Hier soll nur das aktuelle Release des Brokers und des Plugins gepostet sein. Für Fragen, Anregungen und Support steht dieser
-- Supportthread --
bereit. Nur dort werden Fragen auch beantwortet ;-)
Sonos-Broker v1.1 (2017-02-19)- bugfix: play_tunein should working now (after some SoCo changes)
- SoCo framework update
Sonos-Plugin for SmarthomeNG v1.1 (2017-02-19)- changed expected Sonos Broker version to 1.1
- change output of volume_dpt3 items from warning to debug
DOKUMENTATION:
Sonos-Broker
SmarthomeNG-Plugin
Sonos-Widget
DOWNLOADS:
Sonos-Broker
Smarthome-Plugin
Sonos-Widget
-- Supportthread --
bereit. Nur dort werden Fragen auch beantwortet ;-)Zuletzt geändert von pfischi; 20.02.2017, 00:14.
Sonos Plugin 1.3.1- complete re-written Sonos plugin
- Sonos Broker nis no longer needed
- SmartVISU widget integrated
- better documentation
- lots of bugfixes and improvements
Link on Github
-- Supportthread --
Sonos Plugin 1.4.3- added parameter to set a dedicated audio snippet path
- newest SoCo framework update
- Bugfix: an error was thrown if now default tts language was set
Link on Github
-- Supportthread --
Sonos Plugin 1.4.4- TuneIn fix (function 'play_tunein') until the SoCo framework fixed the MusicService issue
- complete rewritten Sonos widget for SmartVisu 2.9
- small offset for TTS playback duration
Link on Github
Bitte keine Antworten auf diesen Post. Hier wird nur das aktuelle Release des Plugins gepostet. Für Fragen, Anregungen und Support steht dieser
-- Supportthread --
Sonos Plugin 1.4.8- SoCo framework updated to version 0.16
- bugfix: Google TTS token generation
- bugfix: coordinator is now set up correctly
Link on Github
-- Supportthread --
