Trying to make heating controler with logics.
    Hello,
    I'm tring to manage my heating with logics.
    I try this but the scheduler didn t seem to work :
    from datetime import date, datetime
    programmes = {
    	'P1': ['6h30','7h45','16h00','22h45'],
    	'P2': ['7h30','23h30']
    zones = {
    	'Z1': ['salon','sam','cuisine'],
    	'Z2': ['chenfant','chparents']
    sched = [
    	# LMMJVSDCAbs day of week + holidays => day mode on when * present else night mode
    	('-----***-', 'Z1', 'P1'),
    	('*----***-', 'Z2', 'P1')
    # Gestion du jour
    jour = date.today().weekday()
    if sh.system.conges:
    	jour = 7
    if sh.system.absence:
    	jour = 8
    # Parcours du sched
    for cron, zone, prog in sched:
    	if cron[jour] == '*':
    		# On applique le planing a la zone
    		status = True
    		for hour in programmes[prog]:
    			for room in zones[zone] :
    				h, m = map(int, hour.split('h'))
    				dt = sh.now().replace(hour = h, minute = m)
    				logger.info("***" +str(dt) +"***")
    				sh.trigger('ItemChange', value=(room +".temp.journuit", status), dt=dt)
    			status = not status
    Is it possible to schedule a logics several times ?
    Thanks a lot
    Have a look at
    Configuration ? SmartHome.py 1.0 documentation
    and
    It's hard to understand your logic because I don't understand the language. But as far as I understood it, you could achieve the same thing by using crontab together with a value. With that, you could avoid to declare the time values in the logic itself. You even can combine several crontab entries with the pipe symbol '|'.
    hth
    Mit freundlichen Grüßen
    Niko Will
      i can't use crontab and cycle, the value change all days (holidays, WE ...)
      so i should use sh.trigger ?
      i comment my code in english :
      progs = {
              #the first hour always put mode day on radiator, second hour mode night etc ....
      zones = {
              #make zone for radiator
      sched = [
              # MTWTFSSH day of week + holidays => day mode on when * present else night mode
      # day handle
      if sh.system.conges: #if holidays but at home
              jour = 7
      if sh.system.absence: #if holidays not at home
              jour = 8
      # sched read
                      status = True
                      for hour in progs[prog]:
                                      #schedule the change of heating on each radiator
                              status = not status
      Is it more understandable ?
      Thanks for your help
        Ho my god ! It works
        i thinked it didn't work because the trigger was not listed in "lo" command
        i don't know where i can find the schedule action ?
