Working with timers?
    Hello peoples...
    I'm a bit confused about how to Work with timers in SH.py.
    eg if i want a Motion detector to turn on a light for 5 min and reset every time the detector input goes high - and if no activity within 5 minutes - turn the light off...
    Could i use the timer function, and do something like:
    IF Motion1 == True:
    Light1 = 100%
    Timer(5m,0%)
    So when the Motion becomes true, set light to 100% and set a timer to set it to 0%?
    Could some one please give a short code sample of how to do that? I'm planning to create different timers in the same logic file
    Thanks
    go to the documentation and look for autotimer.
    so long
    Marcus
      Hi.
      Yes i've already did that...
      autotimer(time, value)
      Set a timer to run at every item change. Specify the time (in seconds), or use m to specify minutes. e.g. autotimer(‘10m’, 42) to set the item after 10 minutes to 42. If you call autotimer() without a timer or value, the functionality will be disabled.
      timer(time, value)
      Same as autotimer, excepts it runs only once."
      But the autotimer runs on every change, what if i only want the action to be executed every time the item goes == 1
      Wouldn't then be the normal timer to use, and just create a logic saying when item ==1 starts the timer? and set the logic to monitor that input?
        yes you could do that.
        so long
        Marcus
          Nice....
          What if i then want the timer to be resat every time the input goes high? So it's kind of a timeout when no activity through a Motion sensor is active?
          Greetings
