- √ - could someone please explain eval and eval_trigger?
    Hello Guys..
    The eval and eval_trigger doesn't make any sense for me, i'm very confused after reading around in the doc and at this forum - seems like many different ways to do it, but i can't see the logic in it....
    All i wanna do is eval on a bool. If the bool goes high it must turn on light, if bool goes low it must turn off the light..... I'm trying this:
            [[[floor_on_off]]]
            type=bool
            visu_acl=rw
            knx_dpt=1
            knx_listen=2/0/0
            knx_send=2/0/0
            knx_init=2/0/0
            eval = true if sh.garage.light.constant_floor else None
            eval_trigger = garage.light.constant_floor
    The eval is a bit that comes from a pushbutton to override presence sensors...
    When this one get's high it must turn on the object "Floor_on_off"
    Could someone please write the correct expression - so it can make sense for me
    Okay, finally i've found it...
    The only problem was that false must be False and true must be True....
    I'm leaving this thread - maybe other could look in it later and see.... This one works now
      You are really near a solution:
      eval = true if not sh.garage.light.constant_floor() else false
      In eval you have to use sh.foo.bar() to get the value of foo.bar item.
      In eval_trigger you have to use the item foo.bar without sh.
      Baustelle 2.0 !
