Fehlermeldung im interaktiven Modus Zeichencodec?
    ich bekomme im Terminal zyklisch folgende Fehlermeldung ausgeworden, wenn ich smarthome.py im interaktiven Modus starte:
    PHP-Code:
      File "/usr/lib/python3.2/logging/__init__.py", line 941, in emit
        stream.write(msg)
    UnicodeEncodeError: 'ascii' codec can't encode character '\xfc' in position 691:        ordinal not in range(128)
    Logged from file uvr.py, line 76
        stream.write(msg)
    UnicodeEncodeError: 'ascii' codec can't encode character '\xfc' in position 709:        ordinal not in range(128)
    Logged from file uvr.py, line 121
        stream.write(msg)
    UnicodeEncodeError: 'ascii' codec can't encode character '\xfc' in position 57:        ordinal not in range(128)
    Logged from file uvr.py, line 131
        stream.write(msg)
    UnicodeEncodeError: 'ascii' codec can't encode character '\xfc' in position 74:        ordinal not in range(128)
    Logged from file uvr.py, line 141
        stream.write(msg)
    UnicodeEncodeError: 'ascii' codec can't encode character '\xe4' in position 74:        ordinal not in range(128)
        stream.write(msg)
    UnicodeEncodeError: 'ascii' codec can't encode character '\xe4' in position 91:        ordinal not in range(128)
        stream.write(msg)
        stream.write(msg)
        stream.write(msg)
    UnicodeEncodeError: 'ascii' codec can't encode character '\xf6' in position 114:        ordinal not in range(128)
    Logged from file __init__.py, line 162
        stream.write(msg)
    UnicodeEncodeError: 'ascii' codec can't encode character '\xf6' in position 82:        ordinal not in range(128)
    Logged from file item.py, line 369
        stream.write(msg)
    UnicodeEncodeError: 'ascii' codec can't encode character '\xf6' in position 90:        ordinal not in range(128)
        stream.write(msg)
    UnicodeEncodeError: 'ascii' codec can't encode character '\xf6' in position 101:        ordinal not in range(128)
        stream.write(msg)
    UnicodeEncodeError: 'ascii' codec can't encode character '\xf6' in position 83:        ordinal not in range(128)
    ich habe die aktuele develop Version istalliert (1.1.922.dev) die Kodierung von uvr.py ist laut WinSCP UTF-8
    Ich bekomme keine Fehlermeldungen ins Log, es funktioniert auch meines erachtens alles einwandfrei, vielleicht ist es aber für die Entwickler von Interesse.
    Ich habe es mir ncoh mal angeschaut, es liegt wohl an einem fehlerhaften Zeichen in der HTML-Datei der UVR (das Gradzeichen wird im Browser nicht richti dargestellt).
    Der Thread kann gerne gelöscht werden - ich kann dies leider nicht tun.
      nee, Fehler liegt in Deiner Shell-Umgebung. Du musst die auf UTF-8 umstellen.
      Suche mal nach LC_ALL Shell de.DE UTF-8.
      Bis bald
      Marcus
        hi Markus,
        vielen Dank - habe in etc/profile
        PHP-Code:
        export LC_ALL=de_DE.UTF-8
        export LANG=de_DE.UTF-8
        export LANGUAGE=de_DE.UTF-8
        hinzugefügt und jetzt sind die Fehler weg.
