Hallo
Nach einem Neustart des Raspberry hatte ich plötzlich einen Websocket Error. Hab mir das Log angesehen. Kenn mich aber absolut nicht aus.
Es zeigt einen Error im luxtronic2_plugin. Da habe ich aber nichts geändert oder so.
Könnt ihr bitte einen Blick draufwerfen??
2015-02-25 09:20:16 ERROR Main Item item.type: problem creating: could not convert string to float:
2015-02-25 09:20:17 WARNING system.datum_uhrzeit.sonne.position Item system.datum_uhrzeit.sonne.position: value (2.3335578441619873, 0.3712237775325775) does not match type num. Via Init None
2015-02-25 09:20:32 ERROR SQLite dump Method SQLite dump exception: could not convert string to float:
Traceback (most recent call last):
File "/usr/smarthome/lib/scheduler.py", line 344, in _task
obj()
File "/usr/smarthome/plugins/sqlite/__init__.py", line 160, in _dump
self.update_item(item)
File "/usr/smarthome/plugins/sqlite/__init__.py", line 147, in update_item
val = float(item())
ValueError: could not convert string to float:
2015-02-25 09:25:31 ERROR Luxtronic2 Method Luxtronic2 exception: error receiving answer: timeout
File "/usr/smarthome/plugins/luxtronic2/__init__.py", line 106, in _request
answer = self._sock.recv(length)
socket.timeout: timed out
During handling of the above exception, another exception occurred:
obj()
File "/usr/smarthome/plugins/luxtronic2/__init__.py", line 265, in _refresh
self.refresh_calculated()
File "/usr/smarthome/plugins/luxtronic2/__init__.py", line 204, in refresh_calculated
answer = self._request(request, 12)
File "/usr/smarthome/plugins/luxtronic2/__init__.py", line 109, in _request
raise luxex("error receiving answer: timeout")
plugins.luxtronic2.luxex: error receiving answer: timeout
2015-02-25 09:25:32 ERROR SQLite dump Method SQLite dump exception: could not convert string to float:
obj()
val = float(item())
2015-02-25 09:30:33 ERROR SQLite dump Method SQLite dump exception: could not convert string to float:
obj()
val = float(item())
2015-02-25 09:35:33 ERROR SQLite dump Method SQLite dump exception: could not convert string to float:
obj()
val = float(item())
2015-02-25 09:40:33 ERROR SQLite dump Method SQLite dump exception: could not convert string to float:
obj()
val = float(item())
2015-02-25 09:45:33 ERROR SQLite dump Method SQLite dump exception: could not convert string to float:
obj()
val = float(item())
2015-02-25 09:50:33 ERROR SQLite dump Method SQLite dump exception: could not convert string to float:
obj()
val = float(item())
2015-02-25 09:55:33 ERROR SQLite dump Method SQLite dump exception: could not convert string to float:
obj()
val = float(item())
2015-02-25 10:00:33 ERROR SQLite dump Method SQLite dump exception: could not convert string to float:
obj()
val = float(item())
2015-02-25 10:05:33 ERROR SQLite dump Method SQLite dump exception: could not convert string to float:
obj()
val = float(item())
2015-02-25 10:10:33 ERROR SQLite dump Method SQLite dump exception: could not convert string to float:
obj()
val = float(item())
2015-02-25 10:15:33 ERROR SQLite dump Method SQLite dump exception: could not convert string to float:
obj()
val = float(item())
2015-02-25 10:20:34 ERROR SQLite dump Method SQLite dump exception: could not convert string to float:
obj()
val = float(item())
2015-02-25 10:25:33 ERROR SQLite dump Method SQLite dump exception: could not convert string to float:
obj()
val = float(item())
2015-02-25 10:30:33 ERROR SQLite dump Method SQLite dump exception: could not convert string to float:
obj()
val = float(item())
2015-02-25 10:35:33 ERROR SQLite dump Method SQLite dump exception: could not convert string to float:
obj()
val = float(item())
2015-02-25 10:40:33 ERROR SQLite dump Method SQLite dump exception: could not convert string to float:
obj()
val = float(item())
2015-02-25 10:45:33 ERROR SQLite dump Method SQLite dump exception: could not convert string to float:
obj()
val = float(item())
2015-02-25 10:50:34 ERROR SQLite dump Method SQLite dump exception: could not convert string to float:
obj()
val = float(item())
2015-02-25 10:55:33 ERROR SQLite dump Method SQLite dump exception: could not convert string to float:
obj()
val = float(item())
2015-02-25 11:00:33 ERROR SQLite dump Method SQLite dump exception: could not convert string to float:
obj()
val = float(item())
2015-02-25 11:05:33 ERROR SQLite dump Method SQLite dump exception: could not convert string to float:
obj()
val = float(item())
2015-02-25 11:10:33 ERROR SQLite dump Method SQLite dump exception: could not convert string to float:
obj()
val = float(item())
2015-02-25 11:15:34 ERROR SQLite dump Method SQLite dump exception: could not convert string to float:
obj()
val = float(item())
2015-02-25 11:20:33 ERROR SQLite dump Method SQLite dump exception: could not convert string to float:
obj()
val = float(item())
2015-02-25 11:25:34 ERROR SQLite dump Method SQLite dump exception: could not convert string to float:
obj()
val = float(item())
2015-02-25 11:30:33 ERROR SQLite dump Method SQLite dump exception: could not convert string to float:
obj()
val = float(item())
2015-02-25 11:35:33 ERROR SQLite dump Method SQLite dump exception: could not convert string to float:
obj()
val = float(item())
2015-02-25 11:40:33 ERROR SQLite dump Method SQLite dump exception: could not convert string to float:
obj()
val = float(item())
2015-02-25 11:45:33 ERROR SQLite dump Method SQLite dump exception: could not convert string to float:
obj()
val = float(item())
2015-02-25 11:50:34 ERROR SQLite dump Method SQLite dump exception: could not convert string to float:
obj()
val = float(item())
2015-02-25 11:55:34 ERROR SQLite dump Method SQLite dump exception: could not convert string to float:
obj()
val = float(item())
2015-02-25 12:00:34 ERROR SQLite dump Method SQLite dump exception: could not convert string to float:
obj()
val = float(item())
Init SmartHome.py 1.0-35-gf62db45+
