Possible to use visual studio to simulate ?
    Hello guys.
    I was wondering if it was possible to load smarthome.py in to visual studio and use this for debugging, instead of stopping starting sh.py every time?
    it is not possible.
    so long
    Marcus
      But there are turorials for eclipse
        Nice, that could also be usefull... where to find theese?
          https://github.com/mknx/smarthome/wi...f-Smarthome.py
          https://github.com/mknx/smarthome/wi...d-Smarthome.py
            Which of the solutions works best for debugging?
            Is it then possible to change the logics and run it, without need to restart hs every time?
            Zuletzt geändert von Rasmus7700; 23.03.2015, 18:38.
              you don't have to restart sh every time you change a logic. You could reload and start logics via the cli plugin.
              so long
              Marcus
                What is it in point 3 that should be copied to the hs?
                "Als erstes muss das komplette pysrc Folder welches den pydevd enthält, per WinSCP oder über die Samba Freigabe auf den Raspberry kopiert werden.
                Am besten jetzt einen Ordner "pysrc" unter "/usr/local/lib/python3.2/dist-packages/" anlegen:"
