Squeezebox Plugin - Frage
    hat schon jemand das Plugin mit "Softsqueeze" zum laufen gebracht?
    Ich habe auf meinem Windows- Rechner Softsqueeze installiert. Läuft auch, aber über sh bekomme ich keinen Zugriff.
    ERROR    Connections  Squeezebox: could not connect to 127.0.0.1:9090 (TCP): [Errno 111] Connection refused
    Meine Plugin.conf:
    [squeezebox]
        class_name = Squeezebox
        class_path = plugins.squeezebox
        host = 127.0.0.1
        port = 9090
    Meine item.conf:
    [Squeezebox_2]
      squeezebox_playerid = d6:56:05:7d:bc:84
      [[Name]]
        type = str
        visu = yes
        squeezebox_recv = * player name ?
        squeezebox_init = * player name
      [[IP]]
        type = str
        visu = yes
        squeezebox_recv = * player ip ?
        squeezebox_init = * player ip
      [[Signal_Strength]]
        type = num
        visu = yes
        squeezebox_recv = * signalstrength
      [[Power]]
        type = bool
        visu = yes
        squeezebox_send = <playerid> power {}
        squeezebox_recv = <playerid> prefset server power
        squeezebox_init = <playerid> power
      [[Mute]]
        type = bool
        visu = yes
        squeezebox_send = d6:56:05:7d:bc:84 mixer muting {}
        squeezebox_recv = d6:56:05:7d:bc:84 prefset server mute
        squeezebox_init = d6:56:05:7d:bc:84 mixer muting
      [[Volume]]
        type = num
        visu = yes
        squeezebox_send = * mixer volume {}
        squeezebox_recv = * prefset server volume
        squeezebox_init = * mixer volume
      [[Volume_Up]]
        type = bool
        enforce_updates = true
        visu = yes
        squeezebox_send = * button volup
      [[Volume_Down]]
        type = bool
        visu = yes
        squeezebox_send = * button voldown
      [[Play]]
        type = bool
        visu = yes
        squeezebox_send = <d6:56:05:7d:bc:84> play
        squeezebox_recv = <d6:56:05:7d:bc:84> play
        squeezebox_init = <d6:56:05:7d:bc:84> mode
      [[Stop]]
        type = bool
        visu = yes
        squeezebox_send = <playerid> stop
        squeezebox_recv = <playerid> stop
        squeezebox_init = <playerid> mode
      [[Pause]]
        type = bool
        visu = yes
        squeezebox_send = <playerid> pause {}
        squeezebox_recv = <playerid> pause
    Bei den Einstellungen in Softsqueeze ist folgendes eingetragen:
    Server Hostname: 127.0.0.1
    Server HTTP Port: 9090
    Server SlimProtoPort: 3483
    Softsqueeze MAC: d6:56:05:7d:bc:84
    Kann jemand helfen? Oder gibt´s eine andere Möglichkeit über sh Musik am Windows-Rechner abzuspielen?
    Lg Max
    Als Hostname vielleicht mal die IP des Windows Rechners eingeben!
    Baustelle 2.0 !
      die IP 127.0.0.1 zeigt auf sich selber und ist nicht ansprechbar von aussen.
      gib in einer dosbox ipconfig ein und such nach IPv4 Adresse und trage die dann ein.
      VG
      Jürgen
        Danke, jetzt klappt´s.
        Lg Max
