Trying to install on new Ubuntu LTS system - Error Eibd?
    Hello Guys.
    I'm trying to install the system on a new Ubuntu LTS 14 server.
    Everything went fine, just had a problem when trying to install the package:
    apt-get -y --force-yes install bcusdk The package can't be found when trying this command - what can be wrong?
    I've followed the guide from the smarthome Wiki...
    https://github.com/mknx/smarthome/wi...ibd-und-1-Wire
    did you add the repository to file "sources.list":
    deb http://www.auto.tuwien.ac.at/~mkoegler/debian eib main
    deb-src http://www.auto.tuwien.ac.at/~mkoegler/debian eib main
    Regards
    offline
      No, I haven't done that.... Thanks
      is it same package for Ubuntu? Seems like the one you are listing here is for Debian?
        As Ubuntu bases on Debian, you can use these packages
          That worked - thanks a lot
