[Solved] KNX connection "connection refused"
    SOLVED:
    Problem was eibd start script was set as a debian machine - not ubuntu. Changed script -
    all worked
    Maybe someone could use the information later
    Hello Guys.
    I've installed the Sh.py from the guide in the wiki on a fresh Ubuntu 14 installation.
    I can't get the eibd function to connect to my KNX....
    When starting sh.py in -d mode, it says:
    ERROR Connections KNX: could not connect to 127.0.0.1:6720 (TCP): [Errno 111] Connection refused -- connection.py:connect:382
    When trying to do a groupswrite ip:localhost 0/0/1 1 i get the same error "Open Failed - Connection Refused"
    What can be wrong here?
    My plugin.cong:
    # plugin.conf
    [knx]
       class_name = KNX
       class_path = plugins.knx
       host = 127.0.0.1
       port = 6720
    #   send_time = 600 # update date/time every 600 seconds, default none
    #   time_ga = 1/1/1 # default none
    #   date_ga = 1/1/2 # default none
    #[ow]
    My eidb config:
      GNU nano 2.2.6                   File: /etc/default/eibd
    EIB_ARGS="--daemon --Server --Tunnelling --Discovery --GroupCache --listen-tcp"
    EIB_ADDR="0.0.1"
    EIB_IF="ipt:192.168.50.10"
    EIB_UID="rasmus"
    But when starting the eibd deamon manually with:
    eibd -c -R -S -T -t1023 ipt:192.168.50.7
    i get a lot of KNX data
    Seems like the eibd deamon isn't running.... When starting it manually i can see following when
    ps ax | grep eibd
    i get:
     3239 pts/1    S+     0:00 eibd -c -R -S -T -t1023 ipt:192.168.50.10
     3265 pts/0    S+     0:00 grep --color=auto eibd
    But when starting with the script defined in etc/init.d/eibd start i only get
    When starting /etc/init.d/eibd start:
    root@smarthome:/etc/init.d# eibd start
    No listen-address given
    Zuletzt geändert von Rasmus7700; 11.10.2015, 15:39.
    Maybe you could outline the actual differences between the given Ubuntu and the final solving debian scripts ...?
    Regards,
    Bernd
      Ofcourse
      In the /etc/init.d/eibd file following must be choosen:
      PATH=/sbin:/usr/sbin:/bin:/usr/bin:/usr/local/bin
      #Ubuntu: DAEMON=/usr/bin/$NAME
      #Debian: DAEMON=/usr/local/bin/$NAME
      DAEMON=/usr/local/bin/$NAME PIDFILE=/var/run/$NAME.pid
      SCRIPTNAME=/etc/init.d/$NAME
      Remember:
