PyCharm Debug "SH not defined"
    Hello Guys.
    Finally i've managed to get the PyCharm debugger up.
    Now it's connected to the Smarthome.py system, then i get the following errors in the debugger output:
    ssh://rasmus@192.168.50.7:22/usr/bin/python3 -u /home/rasmus/.pycharm_helpers/pydev/pydevd.py --multiproc --client '0.0.0.0' --port 42922 --file /usr/local/smarthome/logics/heating.py
    pydev debugger: process 31435 is connecting
    Connected to pydev debugger (build 141.2569)
      File "/home/rasmus/.pycharm_helpers/pydev/pydevd.py", line 2358, in <module>
        globals = debugger.run(setup['file'], None, None, is_module)
      File "/home/rasmus/.pycharm_helpers/pydev/pydevd.py", line 1778, in run
        pydev_imports.execfile(file, globals, locals)  # execute the script
      File "/home/rasmus/.pycharm_helpers/pydev/_pydev_imps/_pydev_execfile.py", line 18, in execfile
        exec(compile(contents+"\n", file, 'exec'), glob, loc)
      File "/usr/local/smarthome/logics/heating.py", line 7, in <module>
        if sh.big_bathroom.heating.mode() == 1 and sh.big_bathroom.heating.pv() < sh.big_bathroom.heating.sp():
    NameError: name 'sh' is not defined
    It says that the "sh" isn't defined?????
    Any ideas
    Can't the debugging be down with the name of the sh. items?
    Could someone please explain
