Sh.py Logic In memory or?
    Hello.
    im using a Ubuntu system to do debugging of logics in sh.py....
    when running a logic, it seems like sh.py loads it all in the mem at startup, so when changing a logic it is nessecary to restart smarthome - is this correct - or is there a solution where it will accept changes without restart?
    Hi, you can change a logic with the cli plugin. This gives you a command line interface, where you can reload a logic with the command rl. Regards, Waldemar
    OpenKNX www.openknx.de
