python zerbockt.. problem mit sh.sun.pos(degree=True)
    Beim Einbauen von eclipse mit remote debug pysrc ist mir irgendetwas in die Hose gegangen..
    2016-01-22 08:45:25,660 ERROR    Main         Plugin autoblind exception: 'bool' object has no attribute 'pos' -- plugin.py:__init__:57
      File "/usr/local/smarthome/lib/plugin.py", line 53, in __init__
        plugin_thread = Plugin(smarthome, plugin, classname, classpath, args)
      File "/usr/local/smarthome/lib/plugin.py", line 82, in __init__
        exec("self.plugin = {0}.{1}(smarthome{2})".format(classpath, classname, args))
      File "<string>", line 1, in <module>
      File "/usr/local/smarthome/plugins/autoblind/__init__.py", line 69, in __init__
        AutoBlindCurrent.init(smarthome)
      File "/usr/local/smarthome/plugins/autoblind/AutoBlindCurrent.py", line 34, in init
        values = AbCurrent(smarthome)
      File "/usr/local/smarthome/plugins/autoblind/AutoBlindCurrent.py", line 53, in __init__
        self.update()
      File "/usr/local/smarthome/plugins/autoblind/AutoBlindCurrent.py", line 86, in update
        azimut, altitude = self.__sh.sun.pos()
    AttributeError: 'bool' object has no attribute 'pos'
    autoblind läuft so natürlich nicht,..
    2016-01-22 08:48:38,348 ERROR    sonnenstand  Logic: sonnenstand, File: /usr/local/smarthome/logics/sonnenstand.py, Line: 8, Method: <module>, Exception: 'bool' object has no attribute 'pos' -- scheduler.py:_task:348
      File "/usr/local/smarthome/lib/scheduler.py", line 341, in _task
        exec(obj.bytecode)
      File "/usr/local/smarthome/logics/sonnenstand.py", line 8, in <module>
        azimut, altitude = sh.sun.pos(degree=True)
    > pp(sys.path)"
    '/home/smarthome',
    '/usr/local/lib/python3.2/dist-packages/pysrc',
    '/usr/lib/python2.7',
    '/usr/lib/python2.7/plat-linux2',
    '/usr/lib/python2.7/lib-tk',
    '/usr/lib/python2.7/lib-old',
    '/usr/lib/python2.7/lib-dynload',
    '/usr/local/lib/python2.7/dist-packages',
    '/usr/lib/python2.7/dist-packages',
    '/usr/lib/python2.7/dist-packages/PIL',
    '/usr/lib/python2.7/dist-packages/gtk-2.0',
    '/usr/lib/pymodules/python2.7']
    Hat jemand eine Idee was mir für das sh.sun.pos fehlt?
    Gruß Ivan
    ich denke ephem ist nicht installiert.
    bis bald
    Marcus
    Zuletzt geändert von callidomus; 22.01.2016, 09:48. Grund: ephem
      Danke,
      hatte versehentlich den Ordner dist-packages gelöscht..
      Zuletzt geändert von ivande; 22.01.2016, 11:14. Grund: Rechtschreibung
        Hallo callidomus Markus
        kann die python-Version eigentlich aktualisert werden, damit smarthome.py noch damit läuft?
        Gruß Ivan
          ich denke ja. Probiert habe ich nicht.
          Bis bald
          Marcus
            Bei mir läuft aktuell Python 3.5 ohne Probleme
