Neues Plugin - Siemens OZW, Gas-Therme
    [Codebeispiel] Neues Plugin - Siemens OZW, Gas-Therme
    Moin,
    anbei ein Plug-In, um meine Gasbrennwert-Therme mittels Siemens OZW auszulesen.
    #!/usr/bin/env python3
    #  Copyright 2015 KNX-Username : KHome
    #  Quick-Dirty Solution with CURL / JQ
    #  Free for non-commercial use
    # to install jq follow:
    # https://stedolan.github.io/jq/download/
    import logging
    import subprocess
    import time
    logger = logging.getLogger('SiemensOZW')
    class SiemensOZW():
        _items = []
        def __init__(self, smarthome, host='192.168.178.178', username=None, password=None, cycle=60):
            self._sh = smarthome
            self._ozwhost = host
            self._username = username
            self._password = password
            self._sid = 0
            self._cycle = int(cycle)
            self.refresh_cycle = self._cycle
        def run(self):
            logging.warning("SiemensOZW is running")
            self.alive = True
            self._sh.scheduler.add('ozwcycle', self.refresh, prio=5, cycle=self._cycle, offset=2)
        def stop(self):
            self.alive = False
        def parse_item(self, item):
            if 'ozw_nr' in item.conf:
                self._items.append(item)
                return self.update_item
        def update_item(self, item, caller=None, source=None, dest=None):
            #logging.warning("update function")
            if caller != 'SiemensOZW':
                #logger.info("update item: {0}".format(item.id()))
                value = str(int(item()))
        def refresh(self):
            #logging.warning("refresh function")
            for item in self._items:
                time.sleep(1)
                ozw_variable = item.conf['ozw_nr']
                value = self.request(ozw_variable)
                #logging.warning(ozw_variable)
                #logging.warning(value)
                #if reading fails (i.e. at broadcast-commands) the value will not be updated
                if value is not None:
                    item(value, 'SiemensOZW', 'refresh')
                if not self.alive:
                    break
        def request(self, request):
            #logging.warning("request function")
            try:
                uri = "http://" + self._ozwhost + "/api/auth/login.json?user=" + self._username + "&pwd=" + self._password
                proc = subprocess.Popen('curl -k -sb -H \"Accept: application/json\" \"' + uri + '\" | jq \'.SessionId\'', stdout=subprocess.PIPE, shell=True)
                (out, err) = proc.communicate()
                out =  str(out,"utf-8")
                outnew = out.replace('\"', '')
                self._sid = outnew.replace('\n', '')
                logger.debug("sid = {0}".format(self._sid))
                if self._sid == '0':
                    logger.warning("SiemensOZW: invalid sid, none received ")
                uri_readpoint = "http://" + self._ozwhost + "/api/menutree/read_datapoint.json?SessionId=" + self._sid + "&Id="
                idnr = request #867
                cmdt = 'curl -k -sb -H \"Accept: application/json\" \"'+  uri_readpoint + str(idnr) + '\" | jq \'.Data.Value\''
                proc = subprocess.Popen(cmdt, stdout=subprocess.PIPE, shell=True)
                (out2, err2) = proc.communicate()
                #print("program output:", out2)
                out2 =  str(out2,"utf-8")
                answer = out2.replace('\"', '') #not all values are float; it could be also: "Ein"
                return answer
            except:
                logger.warning("Unexpected error: SiemensOZW some execution read error")
    Sowie eine kurze Beschreibung:
    # SiemensOZW
    ## Requirements/Description
    Description:
    Connects to read-only Siemens OZW672 over LAN
    Requirements-SW:
    CURL and JQ
    ## Supported Hardware
    www.siemens.com/download?A6V10336376
    I.e. Siemens OZW672 (some configurations needed to access
    - via http (not https)
    - data via LAN
    - Username & data regarding security level (not all data are visible for each profile)
    ## Configuration
    ### plugin.conf
    [ozw]
        class_name = SiemensOZW
        class_path = plugins.ozw
        host = localhost  # ip of ebusd
        cycle = 30       # cycle of each item
        username = 'user'
        password = 'pass'
    ### items.conf
    Items need parameter "ozw_nr"
    [ozw]
      [[temperatur_outside]]
        type = num
        knx_dpt = 5
        knx_send = 15/1/0
        knx_reply = 15/1/0
        ozw_nr = "788"
    Bei mir ist dieses Plug-In lauffähig - elegantes Python sieht jedoch bestimmt anders aus ;-)
    Wer möchte kann gerne unterstützen, bzw. den Code-Schnipsel in GitHub übernehmen.
    Zuletzt geändert von KHome; 25.02.2016, 20:42.
    Hallo Karl,
    das sind mir die liebsten Beiträge. Der erste Post seit 2012 und dann gleich ein Plugin!
    Vielen Dank das Du es mit der Community teilst.
    Bis bald
    Marcus
