help needed
    help needed
    I have not used smarthome for a while, had it running on a Raspberry PI, but for some reason it stopped working.
    I cannot seem to fint the correct log, the problem is with Eibd but the eibd.log is empty...
    where is eibd located, which logs can i check...
    Maybe your SD card is damaged. This is unfortunately a disadvantage of the raspi and one reason for a couple of persons to change hardware.
    You can look if you eibd is running at all with logging in with ssh and then executing "ps ax | grep eibd". The log of smarthome is also very interesting to analyze. You will find it at /usr/local/smarthome/var/log
    Regards,
    Bernd
