Smartvisu -> Eibd without Smarthome, DomotiGa, etc.
    Hi, I used SmartVisu as backend Smarthome and DomotiGa you to turn control the Eibd demon, but I think you can have a direct connection between SmartVisu and Eibd demon, as you can do (if you can)?
    Why would you want to do that? I can't see any advantage. You need to constantly monitor all activities on the knx to ensure safe operation. Smarthome is delivering this for free. SmartVisu alone will not be able to do that in a reliable way because it is web-based, client-dependent and has no continuous process for imterface management in the background.
      forget it..
