PHP Error
    PHP Error
    ich habe seit heute folgende Fehler, hat jemand eine Idee?
    Warning: parse_ini_file(/var/www/html/config.ini): failed to open stream: Permission denied in /var/www/html/lib/config.php on line 55
    Warning: array_replace(): Argument #2 is not an array in /var/www/html/lib/config.php on line 49
    Warning: array_replace(): Argument #1 is not an array in /var/www/html/lib/config.php on line 92
    Warning: array_replace(): Argument #1 is not an array in /var/www/html/lib/config.php on line 93
    Warning: Invalid argument supplied for foreach() in /var/www/html/lib/includes.php on line 52
    Warning: Use of undefined constant config_timezone - assumed 'config_timezone' (this will throw an Error in a future version of PHP) in /var/www/html/lib/includes.php on line 77
    Warning: Use of undefined constant config_pages - assumed 'config_pages' (this will throw an Error in a future version of PHP) in /var/www/html/index.php on line 24
    Warning: Use of undefined constant config_index - assumed 'config_index' (this will throw an Error in a future version of PHP) in /var/www/html/index.php on line 28
    Warning: Cannot modify header information - headers already sent by (output started at /var/www/html/lib/config.php:55) in /var/www/html/index.php on line 31
    Warning: Use of undefined constant config_cachefolder - assumed 'config_cachefolder' (this will throw an Error in a future version of PHP) in /var/www/html/index.php on line 33
    Warning: Use of undefined constant config_cache - assumed 'config_cache' (this will throw an Error in a future version of PHP) in /var/www/html/index.php on line 33
    Warning: Cannot modify header information - headers already sent by (output started at /var/www/html/lib/config.php:55) in /var/www/html/index.php on line 164
    smartVISU 12:50, 22.12, v2.9 -------------------------------------------------------------------------------- Error loading Page 'config_index' ! Check config.php -> 'config_pages' for correct Pages/Project configuration or try the index page!
    Sieht so aus, als könnte zumindest die config.php (und evtl. auch noch weitere Dateien) aufgrund fehlender Berechtigungen nicht gelesen werden:
    Permission denied in [B]/var/www/html/lib/config.php[/B]
    Mal Benutzer und Gruppe prüfen und ggf. Rechte entsprechend setzen, siehe z.B. in der shNG Komplettanleitung. Ggf. sollte es auch ein chmod -r 755 tun ...
    /tom
      Prüfe unter welchem Benutzer php bei dir läuft. Anschließend gebe diesen als Owner der /var/www/html/config.ini an.
      chmod 755 auf alle Dateien ist meistens keine gute Idee.
      Marcel
