DarkBlue Theme problem and uzsu item
    Hello, i think there is a bug with DarkBlue Theme and uzsu item :
    Example i just change theme as you can see "Mar" and "Act" are not colored with DarkBlue theme. I try to delete the cache of my browser of course
    Did you clear the page cache of smartVISU too?
    Martin
      I just try to clear cache (but i don't use the cache on SH) and same problem only with DarkBlue theme
        I didn‘t talk about smarthome (btw.: SmartHomeNG has no cache). I talked about the cache or smartVISU.
        Martin
          If u talk about this :
          yes i have try, all others themes is good, only DarkBlue have problem
            Yes, that‘s what I was talking about. -> Check clear, click save and afterwards reload the page in the browser.
            If that realy doesn‘t help, the author of the uzsu widget has to come to the rescue. But why should a widget fail with only one of the themes...
            Martin
              exactly what i do to clear cache but without effects. it s very strange i know ! have you tried to use uzsu with DarkBlue ?
                Just tried it - doesn't have anything to do with the uzsu widget but with the CSS in general though I couldn't figure out the problem
                Anyhow, you can reproduce it by putting this in your page:
                <div class="ui-btn ui-btn-active">bla</div>
                I actually found a solution, though it's not very logical.
                Add background: #22AADD; in the designs/darkblue.css after line 409
                Zuletzt geändert von Onkelandy; 05.06.2019, 20:50.
                  Nice it's working with your modification ! Thanks a lot
                  For information the modification add a little new bug in the design on activation button :
                    There's a good chance this problems also happens with other widgets. Would be nice if you tested it. Or maybe someone else can come up with a better solution,smai
                      Sur !
                      Same problem with basic.checkbox
                      i don't know if the problem is link but in blind, music and slider the cursor not seem to be in place :
                      Regards
                        Okay, this should be a better solution, just add to the css:
                        /* fix for uzsu problems */
                        div.uzsuTableMain .ui-btn-active {
                          Nice it's better for checkbox ! Thanks a lot
                            The darkblue theme is not made by me, but I think the different looking of active checkboxes is intentionally.
                            The cause can be found on line 101ff:
                            .ui-checkbox .ui-btn.ui-corner-all.ui-btn-inherit.ui-btn-icon-left.ui-checkbox-on {
                                background-color: #22AADD;
                                background-image: inherit;
                            If this snippet is removed, the checkbox looks similar to other themes.
                            What do others think, is this confusing and should be changed?
                            A fix for the slider handle position is committed.
                              I just committed a general fix for the active switch buttons.
