smartVISU unter Windows
    angeregt durch den Support Thread zum smarthomeNG unter Windows, habe ich meine smartvisu Konfiguration mal unter Windows getestet.
    prinzipiell sieht es gut aus, allerdings erhalte ich Fehlermeldungen.
    im Apache log finde ich dann:
    [Tue Aug 04 13:37:38.668677 2020] [php7:warn] [pid 45228:tid 1320] [client 127.0.0.1:56227] PHP Warning: file_get_contents(): Unable to find the wrapper "https" - did you forget to enable it when you configured PHP? in C:\\Users\\WHeyn\\Documents\\smartvisuw\\lib\\base \\check_update.php on line 20, referer: http://127.0.0.1/edsa-smartvisuw/index.php?page=config
    [Tue Aug 04 13:37:38.668677 2020] [php7:warn] [pid 45228:tid 1320] [client 127.0.0.1:56227] PHP Warning: file_get_contents(https://smartvisu.de/download/check.php?local=2.9.b): failed to open stream: No such file or directory in C:\\Users\\WHeyn\\Documents\\smartvisuw\\lib\\base \\check_update.php on line 20, referer: http://127.0.0.1/edsa-smartvisuw/index.php?page=config
    [Tue Aug 04 13:37:38.668677 2020] [php7:warn] [pid 45228:tid 1320] [client 127.0.0.1:56227] PHP Warning: file(): Unable to find the wrapper "https" - did you forget to enable it when you configured PHP? in C:\\Users\\WHeyn\\Documents\\smartvisuw\\lib\\base \\check_update.php on line 24, referer: http://127.0.0.1/edsa-smartvisuw/index.php?page=config
    [Tue Aug 04 13:37:38.668677 2020] [php7:warn] [pid 45228:tid 1320] [client 127.0.0.1:56227] PHP Warning: file(https://raw.githubusercontent.com/martin-gleiss/smartvisu/master/version-info.php): failed to open stream: No such file or directory in C:\\Users\\WHeyn\\Documents\\smartvisuw\\lib\\base \\check_update.php on line 24, referer: http://127.0.0.1/edsa-smartvisuw/index.php?page=config
    [Tue Aug 04 13:37:38.668677 2020] [php7:warn] [pid 45228:tid 1320] [client 127.0.0.1:56227] PHP Warning: setcookie() expects parameter 3 to be integer, array given in C:\\Users\\WHeyn\\Documents\\smartvisuw\\lib\\base \\check_update.php on line 71, referer: http://127.0.0.1/edsa-smartvisuw/index.php?page=config
    ich habe einfach mein smartvisu Verzeichnis vom Raspi auf den Windows PC herunter geladen und nichts angepasst.
    ich bin auf dem Developer Stand: 2.9.b
    Die ersten 4 Meldungen besagen, dass keine https-Verbindung aufgebaut werden kann. Deshalb funktioniert der Update-Check nicht, weder auf smartvisu.de noch auf github. Schau mal, ob das in PHP7 enabled werden muss.
    Die 5. Meldung deutet auf eine PHP Version <v7.3 hin. Das Cookie-Handling hat sich da wegen Sicherheitsrichtlinien in modernen Browsern geändert und ich hab gleich die aktuelle Methode angewandt.
    Wolfram
    P.S.: Das allles lässt sich auf die einfache Tour abstellen, indem Du in der Config-Seite die Option für den Update-Check deaktivierst. Ich nehme aber an, dass der iCloud-Kalender auch nicht funktioniert, oder?
    Zuletzt geändert von wvhn; 04.08.2020, 18:48.
      nee,
      der iCloud Kalender funktioniert auch nicht.
      das war natürlich der Hauptgrund für meinen Test.
      dann schau ich mal in das PHI.ini
      danke Wil
      bekomme noch eine Meldung von Weather: darksky.net
      "read request failed"
      Zuletzt geändert von whe; 04.08.2020, 19:03.
        $url =  '[MARKIEREN]https[/MARKIEREN]://api.darksky.net/forecast/'.config_weather_key.'/'...
          Weil ich grad die Logs sehe und nur so am Rande, falls es jemand noch nicht mitbekommen hat: Ende von IIS-php > Version 7.4.
          Microsoft knipst für natives php unter dem IIS das Licht aus.
          /tom
