Call to undefined method __TwigTemplate_......::getmultiaxis()
    Hi, ich habe gerade meine Visu aktualisiert. Jetzt läd die Heizungs-Page nicht mehrt.
    [Wed Feb 03 17:20:57.480648 2021] [proxy_fcgi:error] [pid 17079:tid 140438073747200] [client 2a01:XXXXXXXXX] AH01071: Got error 'PHP message:
    PHP Fatal error:
    Uncaught Error: Call to undefined method __TwigTemplate_b55f64acd36ce56dfbfc4a6a4e02950115b 8b47d5ace30135185b3fdada8d061::getmultiaxis() in /var/www/html/smartVISU-dev/vendor/Twig/src/Environment.php(497) : eval()'d code:2179\n
    Stack trace:\n
    #0 /var/www/html/smartVISU-dev/vendor/Twig/src/Template.php(702): __TwigTemplate_451bc291d70e887249d4139b74531cf56db 9ccf293f8fc733f796e106d43daec->getheizungsplot()\n
    #1 /var/www/html/smartVISU-dev/vendor/Twig/src/Environment.php(497) : eval()'d code(69): Twig\\Template->getAttribute()\n
    #2 /var/www/html/smartVISU-dev/vendor/Twig/src/Template.php(214): __TwigTemplate_e62460ca26802fcccd78466498d5778ea28 6cd0c668239504318992797f881fb->block_content()\n
    #3 /var/www/html/smartVISU-dev/vendor/Twig/src/Environment.php(497) : eval()'d code(82): Twig\\Template->displayBlock()\n
    #4 /var/www/html/smartVISU-dev/vendor/Twig/src/Template.php(214): __TwigTemplate_3729a38d3997e436a1f0c9456c5957ddcc1 2422bc6a616b5436b6f86f2c5c2c2->block_body()\n
    #5 /var/www/html...', referer: https://xxxxx.xxxxx.xxxxx/smartVISU/index.php
    Das erwähnte Template heizungsplot habe ich mit dem Widget-Assistant geprüft, hier ist es aber nochmal:
    {% macro heizungsplot(gad) %}
            {% import "basic.html" as basic %}
            {% import "plot.html" as plot %}
            {% set uid = uid(page, id) %}
        {{ plot.period(uid~'p3', ['technik.heizung.ha.TempKist','technik.heizung.ha.TempWWist','technik.heizung.ha.TempVListM2'], 'avg', '1h', 'now', 0, 100, '', '', ['#aa0', '#a00', '#00a'], ['line', 'line', 'line']) }}
         {{ plot.multiaxis(id, item, mode, tmin, tmax, ymin, ymax, count, label, color, exposure, axis, zoom, assign, opposite, ycolor) }}
         {{ plot.period   (id, item, mode, tmin, tmax, ymin, ymax, count, label, color, exposure, axis, zoom, assign, opposite, ycolor, ytype, unit, chartoptions) }}
                           1   2     3     4     5     6     7     8      9      10     11        12    13    14      15        16      17     18    19
        {{ plot.period('plot',
                [gad~'.Kessel.TempIst',gad~'.WW.TempIst',gad~'.HK2.TempVList', gad~'.Brenner.Stufe', gad~'.WW.PumpeSpeicher', gad~'.HK1.Pumpe', gad~'.HK2.Pumpe'],
                ['avg','avg','avg','raw','raw','raw','raw'],
                '5d',
                '[10,0]',
                '[85,1]',
                ['Kessel', 'WW', 'HK2-VL', 'Brenner', 'Pumpe WW', 'Pumpe HK1', 'Pumpe HK2'],
                ['#d30000', '#0054d3', '#f9a028', '#d20000', '#0089d2', '#1cd200', '#9000d2'],
                ['areaspline', 'areaspline', 'areaspline', 'stair', 'stair', 'stair', 'stair'],
                ['Zeit', 'Temperatur', 'Zustand'],
                'advanced',
                [1,1,1,2,2,2,2],
                [0,1],
                ['linear','boolean'],
                { tooltip: { shared: true, distance: 30, padding: 5},
                  exporting: { enabled: true }
        <script type="text/javascript">
            $(document).on("collapsiblecreate", 'div[data-role="collapsible"]', function(event, ui) {
                $("#{{ uid(page, 'plot') }}").closest(".block").css("width", "100%");
        </script>
    {% endmacro %}
    Und aufgerufen wird es so:
    <div class="block">
            <div class="set-2" data-role="collapsible-set" data-theme="c" data-content-theme="a" data-mini="true" data-btn-fs="true">
                    <div data-role="collapsible" data-collapsed="false">
                            <h3>Heizungsgrafiken</h3>
                            {{ my_widgets.heizungsplot('technik.heizung.ha') }}
                    </div>
            </div>
    </div>
    Den Cache habe ich auch schon versucht zu löschen, ohne Änderung.
    Hat wer eine Idee an was das liegen kann?
    Ok, ich bin so doof
    Das "auskomentieren" funktioniert so wohl nicht im Template... ist aufgeräumt und geht wieder.
      Auskommentieren funkttioniert tatsächlich nur mit den twig-Kommentarzeichen /** und **/.
      plot.multiaxis ist in v3.0 gelöscht. Das ist der Hauptgrund für den twig-Fehler.
      Wolfram
