squeezebox widget 3.0 tauglich
    Hallo
    hat jemand das squeezebox-Widget schon überarbeitet und würde es zur Verfügung stellen, ich habe noch eine Version in der die ausgelaufenen widget drin sind wir basic.dual, basic.button,basic.value
    falls es jemand brauchen kann
    Meine
    widget_squeezebox.html
     * @package     smartVISU
     * @author      Martin Gleiß
     * @copyright   2012
     * @license     GPL <http://www.gnu.de>
     * Squeezebox Multimedia Player
     * @param       unique id for this widget
     * @param       the gad/item for play
     * @param       the gad/item for pause
     * @param       the gad/item for stop (optional)
     * @param       the gad/item for playlist forward
     * @param       the gad/item for playlist backward
     * @param       the gad/item for the volume (optional)
     * @param       the gad/item to mute the music (optional)
     * @param       the gad/item for the song title (optional)
     * @param       the gad/item for the song artist (optional)
     * @param       the gad/item for repeat (optional)
     * @param       the gad/item to load the default playlist (optional)
     * @param       the gad/item for the duration (optional)
     * @param       the gad/item for the time/position (optional)
     * @author      Robert Budde
     * derived from "multimedia" by Axel Otterstätter - thanks!
    {% macro control(id, gad_power, gad_play, gad_pause, gad_stop, gad_playlistforward, gad_playlistbackward, gad_vol, gad_mute,
                gad_title, gad_artist, gad_repeat, gad_defaultplaylist, gad_duration, gad_time) %}
        {% import "basic.html" as basic %}
        {% import "widget_my.html" as my %}
        {% set uid = uid(page, id) %}
        <div id="{{ uid }}" class="music">
            {% if gad_vol %}
            <div class="vol">
                <img class="slider-bottomup-scale" src="pages/base/pics/scale_buttomup.png">
                {{ basic.slider(id~'vol', gad_vol, 0, 100, 5, 'bottomup') }}
            </div>
            {% endif %}
            <div class="control">
            {% if gad_power %} {{ basic.stateswitch('', gad_power, '', '','control_standby.svg') }} {% endif %}
            {% if gad_mute %} {{ basic.stateswitch('', gad_mute, '',[0,1],'audio_volume_mute.svg') }} {% endif %}
            {% if gad_repeat %} {{ basic.stateswitch('', gad_repeat, '', '', 'audio_repeat.svg') }} {% endif %}
            {% if gad_defaultplaylist %} {{ basic.stateswitch('', gad_defaultplaylist, '', 1, 'audio_playlist.svg', 'Default Playlist') }} {% endif %}
            </div>
            <div class="title">
              {% if gad_artist %}
              {{ basic.print('', gad_artist) }}
              <br />
              {% endif %}
              {% if gad_title %}
              {{ basic.print('', gad_title) }}
              {% endif %}
            </div>
            <div class="set">
                {% if gad_duration %}
                {% if gad_time %}
                <div class="pos">
                    <div class="scale">&nbsp;</div>
                    {{ my.time_slider(id~'time', gad_time, gad_duration, 1) }}
                </div>
                {% endif %}
                {% endif %}
                <div data-role="controlgroup" data-type="horizontal">
                    {{ basic.stateswitch('', gad_playlistbackward,'', 1 , 'control_arrow_left.svg','backward') }}
                    {{ basic.stateswitch('', gad_play, '', [1,1], 'audio_play.svg') }}
                    {{ basic.stateswitch('', gad_pause, '', '', 'audio_pause.svg') }}
                    {% if gad_stop %} {{ basic.stateswitch('', gad_stop, '', [1,1],'audio_stop.svg') }} {% endif %}
                    {{ basic.stateswitch('', gad_playlistforward, '', 1, 'control_arrow_right.svg', 'forward') }}
               </div>
           </div>
        </div>
    {% endmacro %}
    und die dazugehörige
    widget_my.html (unverändert)
     * A list with selectable item
     * @param       a gad/item for the list
     * @param       a gad/item for the selected item
     * @param       the text to be displayed on top of the list
    {% macro list(id, gad_list, gad_item, txt ) %}
      <ul id="{{ uid(page, id) }}" data-widget="basic.list" data-item="{{ gad_list }}, {{ gad_item }}"
          data-role="listview" data-dividertheme="c">
                  <li data-icon="false"><a href="#">View details</a></li>
                  <li data-icon="false"><a href="#">Edit</a></li>
                  <li data-icon="false"><a href="#">Disable</a></li>
                  <li data-icon="false"><a href="#">Delete</a></li>
              </ul>
    {% endmacro %}
     * Displays a slider-control
     * @param       a gad/item current time (progress)
     * @param       a gad/item total duration (maximum)
     * @param       seconds between two values (optional, default 5s)
     * @param       the orientation ('none', 'vertical', 'bottomup', 'semicircle')
    {% macro time_slider(id, gad_time, gad_duration, step, mode) %}
        <input id="{{ uid(page, id) }}" data-widget="my.time_slider" data-item="{{ gad_time }}, {{ gad_duration }}"
            type="range" value="0" min="0" max="1" disabled="1" step="{{ step|default(5) }}"
            orientation="{{ mode }}" data-highlight="true" />
    {% endmacro %}
      Super. Ist es OK, wenn ich das auf GitHub in smartvisu-newstuff veröffentliche?
        Ich hab ja nur ein paar Änderungen dran gemacht, dafür ja. Die meiste Arbeit hatte Axel Otterstätter
          Hi element
          in den widgets my.list und my.time_slider werden javascript-Funktionen (basic.list und my.time_slider) aufgerufen. Wo ist dieser Code zu finden?
          Kann der Timeslider auch durch das multimedia.timeslider ersetzt werden? Der benötigt allerdings ein item mehr, nämlich für die Info, ob der Titel gerade gespielt wird:
          * Displays a slider to show and control the current time of a media file. Slider continues to run every second even if time value is not updated by item
          * @param {id=} unique id for this widget
          * @param {item(num)} an item providing the current time of a media file
          * @param {item(bool)} an item providing info whether song is playing or not (value has to be true or false)
          * @param {item(num)} an item providing the duration of the same media file
          * @param {value=5} step in % between updates (optional, default 5)
          * @param {text(input,handle,both,none)=input} how should the value be shown; possible options: 'input', 'handle', 'both', 'none' (optional, default 'input')
          {% macro timeslider(id, time, play, duration, step, value_display) %}
          <input {% if not id is empty %} id="{{ uid(page, id) }}"{% endif %} data-widget="multimedia.timeslider" data-item="{{ time }}, {{ duration }}, {{ play }}"
          type="range" value="0" min="0" max="1" disabled="1" step="{{ step|default(5) }}" timer="{{ step|default(5) }}"
          orientation="horizontal" handleinfo="{{ value_display == 'handle' or value_display == 'both' }}" class="{{ value_display|default('input') == 'input' or value_display == 'both' ? '' : 'ui-slider-no-input' }}" data-highlight="true" />
          {% endmacro %}
          Wenn alles vollständig ist und ich die docstrings so ergänzt habe, dass der Templatechecker mit den Widgets klar kommt, dann veröffentliche ich das gerne als Package.
          Wolfram
          P.S.: Du könntest auch einfach mal probieren, ob es reicht, statt der widget_my.html die multimedia.html zu importieren
          {% import "multimedia.html" as multimedia %}
          und dann den timeslider wie folgt aufzurufen:
          {{ multimedia.timeslider(id~'time', gad_time, gad_play, gad_duration, 1) }}
          Zuletzt geändert von wvhn; 09.02.2021, 14:53.
            funktioniert perfekt,
            vorher hat der slider nichts angezeigt (glaube ich), ich hatte den nie genutzt, höre fast nur Internetradio über die squeezebox, habe eine playlist, in der ich vor und zurückspringen kann und einen Taster belegt zum Einschalten und Senderwahl.
            Habe zum Testen auch einzelne Lieder ausprobiert, wird korrekt angezeigt und im Stück springen klappt auch.
            Die widget_my.html ist überflüssig.
            Ich glaube der Richtigkeit halber gehört in den Anfang noch
            "* @param the gad/item for power" an die zweite Stelle.
            Und die ganzen ID's die ich rausgenommen habe, der template checker meckert bei den widgets immer das die bereits vergeben sich.
            Zuletzt geändert von element; 09.02.2021, 19:27.
              VIelen Dank!
              Das Widget ist jetzt hier verfügbar.
              Wolfram
