Hallo Wolfram,
wie gewünscht überführe ich meinen Issue von github hierher zum weiteren Austausch.
Viele Grüsse, Jörk
Hi Wolfram,
my main window of the visual is quite complex. Behind the cells, small dialogs are included. I like a direct selection of functionality without moving through menu cascades.
Environment:
Backend: Raspberry 4B booting and running from SSD (hosting smartvisu and fhem)
Panel: XORO Megapad 2404 v2 (24 Zoll LCD FHD kapazitives Multitouch IPS Display, Android 5.1, Quad Core Prozessor mit 1.8GHz, GPU:Mali T764, 2GB RAM, 16GB interner Speicher, Dualband-WLAN, Bluetooth, Gigabit-LAN)
Communication via fronthem
Please see my video uploaded to GoogleDrive:
https://drive.google.com/file/d/1Bae...ew?usp=sharing
Reload smartvisu V2.9 incl. Smartvisu cache=enabled + Browser-Cache=enabled:
00:03 - 00:12 : 9s : Page load, Result: All data available, values, window states, etc show current status
00:12 - 00:25 : 13s : css
22s
Initial start smartvisu V3.2 incl. smartvisu cache=enabled - Browser cache enabled
00:51 - 01:09 : 18s : Page load. Result: All data available
01:09 - 01:27 : 18s : css
36s
1st Reload smartvisu V3.2 incl. Smartvisu cache=enabled + Browser-Cache=enabled:
01:37 - 01:50 : 13s : Page load. Result: All data available (-5s due to Browser cache)
01:50 - 02:09 : 19s : css
32s (+10s compared to V2.9)
2nd Reload smartvisu V3.2 incl. Smartvisu cache=enabled + Browser-Cache=enabled:
02:18 - 02:32 : 14s : Page load. Result: All data available
02:32 - 02:55 : 23s : css
37s (+15s compared to V2.9)
Conclusion: SV V3.2 takes 50% more time. Most of it when rendering css.
When running smartvisu on iPhone 11 or 12, it’s much faster - but v3.2 still takes some extra second(s).
Both setups (v2.9 and v3.2) took about additional 3s more before reducing SVG size at XORO panel (test results above after SVG shrink). Resizing the SVGs should be done independent of this case. You really feel the difference.
You’re welcome with any suggestions :-).
Thank you in advance,
Jörk
Viele Grüsse, Jörk
Hi Wolfram,
Environment:
22s
36s
Jörk
