Hi zusammen,
die Installation der v3.3 klappt leider nicht.
Smarthome-NG v1.9.3 schreibt hier Fehler beim Start. Hat evtl. jemand einen Tipp?
2022-12-20 07:16:49 ERROR plugins.smartvisu SmartVisuInstallWidgets v3.3.0: Exception: 'NoneType' object is not iterable > Traceback (most recent call last): > File "/usr/local/smarthome/plugins/smartvisu/__init__.py", line 123, in run > sv_iwdg = SmartVisuInstallWidgets(self) > File "/usr/local/smarthome/plugins/smartvisu/svinstallwidgets.py", line 55, in __init__ > self.install_widgets(self._sh) > File "/usr/local/smarthome/plugins/smartvisu/svinstallwidgets.py", line 99, in install_widgets > self.copy_widgets( plgdir.replace('.', '/') ) > File "/usr/local/smarthome/plugins/smartvisu/svinstallwidgets.py", line 149, in copy_widgets > self.plugin_instance.test_widget_for_deprecated_wi dgets(os.path.join(srcdir, fn)) > File "/usr/local/smarthome/plugins/smartvisu/__init__.py", line 284, in test_widget_for_deprecated_widgets > for widget_name in self.deprecated_widgets: > TypeError: 'NoneType' object is not iterable 2022-12-20 07:16:49 ERROR plugins.smartvisu SmartVisuGenerator: Exception: 'NoneType' object is not iterable > Traceback (most recent call last): > File "/usr/local/smarthome/plugins/smartvisu/__init__.py", line 135, in run > svgen = SmartVisuGenerator(self, self.visu_definition) > File "/usr/local/smarthome/plugins/smartvisu/svgenerator.py", line 70, in __init__ > self.pages() > File "/usr/local/smarthome/plugins/smartvisu/svgenerator.py", line 228, in pages > self.plugin_instance.test_item_for_deprecated_widg ets(item) > File "/usr/local/smarthome/plugins/smartvisu/__init__.py", line 313, in test_item_for_deprecated_widgets > for widget in self.deprecated_widgets: > TypeError: 'NoneType' object is not iterable
