in Anlehnung an das calendar-Plugin folgender Code
jnk.js
jnk.html
beispielhaft eingebunden in index.html
und gefüttert von einem sh.py-Item in dem als String die entsprechenden Daten stehen:
calendar.py
es braucht allerdings auch ein geändertes iCal-Plugin:
Ich werde versuchen, das alles upstream zu bringen.
Gruss,
der Jan.
jnk.js
/** * ----------------------------------------------------------------------------- * @package smartVISU * @author Jan N. Klug * @copyright 2013 * @license GPL <http://www.gnu.de> * ----------------------------------------------------------------------------- */ $(document).delegate('div[data-widget="jnk.calendar"]', { 'update' : function (event, response) { var uid = this.id; var ret; var line = ''; var max = $(this).attr('data-max'); data = $.parseJSON(response); for (var i in data) { if (max>0) { ret = '<img style="background: ' + data[i].color + ';" class="icon" src="' + data[i].icon + '" />'; ret += '<div class="color" style="background: ' + $(this).attr('data-color') +';"></div>'; ret += '<h3>' + data[i].summary + '</h3>'; ret += '<p>' + data[i].start + ' bis ' + data[i].end + ' </p>'; if (data[i].location) { ret += '<span class="ui-li-count">' + data[i].location + '</span>'; } ret = '<a href="' + (data[i].link ? data[i].link : '#') + '">' + ret + '</a>'; line += '<li data-icon="false">' + ret + '</li>'; max --; } else { break; } } $('#' + uid + ' ul').html(line).trigger('prepare').listview('refresh').trigger('redraw'); } });
/** * ----------------------------------------------------------------------------- * @package smartVISU * @author Jan N. Klug * @copyright 2013 * @license GPL <http://www.gnu.de> * ----------------------------------------------------------------------------- */ {% macro calendar(id, title, count, color, gad) %} {% set uid = uid(page, id) %} <div id="{{ uid }}" data-widget="jnk.calendar" data-item="{{gad}}" data-max="{{count}}" data-color="{{color|default('#666666')}}" class="calendarlist"> {% if title %} <h2>{{ title }}</h2> {% endif %} <ul data-role="listview"> </ul> </div> {% endmacro %}
{% import "jnk.html" as jnk %} {{ jnk.calendar('calendarlist1', 'Kalendar', 7, gad='zentral.calendar') }}
calendar.py
#!/usr/bin/env python # import json dayrep = {'Monday' : 'Montag', 'Tuesday' : 'Dienstag', 'Wednesday':'Mittwoch', 'Thursday' : 'Donnerstag', 'Friday' : 'Freitag', 'Saturday' : 'Samstag', 'Sunday':'Sonntag'} events = sh.ical(<URL>', 28) #repack events event2 = [] for day in events: for event in events[day]: start = datetime.datetime.combine(day, event[0]).replace(tzinfo = dateutil.tz.gettz('UTC')).astimezone(sh.now().tzinfo) end = event[2].replace(tzinfo = dateutil.tz.gettz('UTC')).astimezone(sh.now().tzinfo) event2.append({ "timestamp" : time.mktime(start.timetuple()), "start": start.strftime("%A, %d.%m.%y %H:%M"), "summary" : event[1], "end" : end.strftime("%H:%M") if (end.date() == start.date()) else end.strftime("%A, %d.%m.%y %H:%M")}) # replace wrong locale event2.sort(key = lambda e : e["timestamp"]) jsonstr = json.dumps(event2) for i, j in dayrep.iteritems(): jsonstr = jsonstr.replace(i, j) sh.zentral.calendar(jsonstr)
#!/usr/bin/env python # vim: set encoding=utf-8 tabstop=4 softtabstop=4 shiftwidth=4 expandtab ######################################################################### # Copyright 2013 KNX-User-Forum e.V. https://knx-user-forum.de/ ######################################################################### # This file is part of SmartHome.py. http://smarthome.sourceforge.net/ # # SmartHome.py is free software: you can redistribute it and/or modify # it under the terms of the GNU General Public License as published by # the Free Software Foundation, either version 3 of the License, or # (at your option) any later version. # # SmartHome.py is distributed in the hope that it will be useful, # but WITHOUT ANY WARRANTY; without even the implied warranty of # MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the # GNU General Public License for more details. # # You should have received a copy of the GNU General Public License # along with SmartHome.py. If not, see <http://www.gnu.org/licenses/>. ######################################################################### import logging import datetime import dateutil.tz import dateutil.rrule import dateutil.relativedelta logger = logging.getLogger('') class iCal(): DAYS = ("MO", "TU", "WE", "TH", "FR", "SA", "SU") FREQ = ("YEARLY", "MONTHLY", "WEEKLY", "DAILY", "HOURLY", "MINUTELY", "SECONDLY") def __init__(self, smarthome): self._sh = smarthome def run(self): self.alive = True def stop(self): self.alive = False def parse_item(self, item): pass def parse_logic(self, logic): pass def update_item(self, item, caller=None, source=None, dest=None): pass def __call__(self, ics, delta=1, offset=0): if ics.startswith('http'): ical = self._sh.tools.fetch_url(ics) if ical is False: return {} else: try: with open(ics, 'r') as f: ical = f.read() except IOError, e: logger.error('Could not open ics file {0}: {1}'.format(ics, e)) return {} now = self._sh.now() offset = offset - 1 # start at 23:59:59 the day before delta += 1 # extend delta for negetiv offset start = now.replace(hour=23, minute=59, second=59, microsecond=0) + datetime.timedelta(days=offset) end = start + datetime.timedelta(days=delta) events = self._parse_ical(ical, ics) ret = {} for event in events: event = events[event] if 'RRULE' in event: for dt in event['RRULE'].between(start, end, True): if dt not in event['EXDATES']: time = dt.time() date = dt.date() if date not in ret: ret[date] = [[time, event['SUMMARY'], dt]] else: ret[date].append([time, event['SUMMARY'], dt]) else: dt = event['DTSTART'] de = event['DTEND'] if (dt > start and dt < end) or (dt < start and de > start): time = dt.time() date = dt.date() if date not in ret: ret[date] = [[time, event['SUMMARY'], de]] else: ret[date].append([time, event['SUMMARY'], de]) return ret def _parse_date(self, val, dtzinfo, par=''): if par.startswith('TZID='): tmp, par, timezone = par.partition('=') if 'T' in val: # ISO datetime val, sep, off = val.partition('Z') dt = datetime.datetime.strptime(val, "%Y%m%dT%H%M%S") else: # date y = int(val[0:4]) m = int(val[4:6]) d = int(val[6:8]) dt = datetime.datetime(y, m, d) dt = dt.replace(tzinfo=dtzinfo) return dt def _parse_ical(self, ical, ics): events = {} tzinfo = self._sh.tzinfo() for line in ical.splitlines(): if line == 'BEGIN:VEVENT': event = {'EXDATES': []} elif line == 'END:VEVENT': if 'UID' not in event: logger.warning("iCal: problem parsing {0} no UID for event: {1}".format(ics, event)) continue if 'SUMMARY' not in event: logger.warning("iCal: problem parsing {0} no SUMMARY for UID: {1}".format(ics, event['UID'])) continue if 'DTSTART' not in event: logger.warning("iCal: problem parsing {0} no DTSTART for UID: {1}".format(ics, event['UID'])) continue if 'DTEND' not in event: logger.warning("iCal: problem parsing {0} no DTEND for UID: {1}".format(ics, event['UID'])) continue if 'RRULE' in event: event['RRULE'] = self._parse_rrule(event, tzinfo) if event['UID'] in events: if 'RECURRENCE-ID' in event: events[event['UID']]['EXDATES'].append(event['RECURRENCE-ID']) events[event['UID'] + event['DTSTART'].isoformat()] = event else: logger.warning("iCal: problem parsing {0} duplicate UID: {1}".format(ics, event['UID'])) continue else: events[event['UID']] = event del(event) elif 'event' in locals(): key, sep, val = line.partition(':') key, sep, par = key.partition(';') key = key.upper() if key == 'TZID': tzinfo = dateutil.tz.gettz(val) elif key in ['UID', 'SUMMARY', 'SEQUENCE', 'RRULE']: event[key] = val # noqa elif key in ['DTSTART', 'DTEND', 'EXDATE', 'RECURRENCE-ID']: try: date = self._parse_date(val, tzinfo, par) except Exception, e: logger.warning("Problem parsing: {0}: {1}".format(ics, e)) continue if key == 'EXDATE': event['EXDATES'].append(date) # noqa else: event[key] = date # noqa return events def _parse_rrule(self, event, tzinfo): rrule = dict(a.split('=') for a in event['RRULE'].upper().split(';')) args = {} if 'FREQ' not in rrule: return freq = self.FREQ.index(rrule['FREQ']) del(rrule['FREQ']) if 'DTSTART' not in rrule: rrule['DTSTART'] = event['DTSTART'] if 'WKST' in rrule: if rrule['WKST'] in self.DAYS: rrule['WKST'] = self.DAYS.index(rrule['WKST']) else: rrule['WKST'] = int(rrule['WKST']) if 'BYDAY' in rrule: day = rrule['BYDAY'] if day.isalpha(): if day in self.DAYS: day = self.DAYS.index(day) else: n = int(day[0:-2]) day = self.DAYS.index(day[-2:]) day = dateutil.rrule.weekday(day, n) rrule['BYWEEKDAY'] = day del(rrule['BYDAY']) if 'COUNT' in rrule: rrule['COUNT'] = int(rrule['COUNT']) if 'INTERVAL' in rrule: rrule['INTERVAL'] = int(rrule['INTERVAL']) if 'UNTIL' in rrule: try: rrule['UNTIL'] = self._parse_date(rrule['UNTIL'], tzinfo) except Exception, e: logger.warning("Problem parsing UNTIL: {1} --- {0} ".format(event, e)) return for par in rrule: args[par.lower()] = rrule[par] return dateutil.rrule.rrule(freq, **args)
Gruss,
der Jan.
