Hi, I'm trying to play with smartvisu, and sometime it had been worked on HP MicroServer virtual machine, right now I'm trying to deploy it on Raspbian, and the time for generating index.php is 8-10 seconds, which is unacceptable, comparing to .7-.9 s on HP. So the question is, are there any way to improve performance, how long it should take to load first screen on Raspberry? I've tried apache/nginx/lighttpd, so the best performance with nginx, but still very slow... Now it is nginx, php5-fpm, tcp-socket for communication of nginx and fastcgi.
It will take about 10 sec without pagecache and about 1 sec with pagecache, depending on the SD card you use.
GreetingsJoin smartVISU on facebook. Web: smartvisu.de.
Dir gefällt smartVISU? Bitte spenden für die Weiterentwicklung.
The build in pagecache, configurable in "config.php".
