KnxToday features smartvisu home automation system
Hello and thanks!
There is no dedicated keypad in Smartvisu (at least until now). I've made it by myself, using standard Smartvisu widgets.
The alarm panel is "Cytech Comfort Ultra". This Alarm panel has many interfaces.
I've used the KNX interface to send command from Smartvisu to the Alarm panel and vice versa.
Yes, this alarm panel can. It's a KNX home automation controller too, but it scheint in alarm security.
I have no widget.
Use this:
<span data-role="controlgroup" data-type="horizontal">
</span>
to obtain a series of buttons (refer to this page) by scrolling the page all way down.
