- √ - Smartvisu schaltet nicht
    Hallo, ich kann bei mir kein Licht schalten, hab folgendes in die smartvisu.comf und in die room_living.html geschrieben.
    Kann mir wer sagen wo der Fehler liegt?
    Per Putty kann ich die Gruppenadressen schalten.
    Danke
    [EG]
        [[Vorraum]]
            [[[deckenspot_vorraum]]]
                [[[[OnOff]]]]
                    type = bool
                    knx_dpt = 1
                    visu_acl = rw
                    knx_listen = 1/4/29
                    knx_send = 1/1/29
                    knx_init = 1/1/1
                [[[[Dimm_vorraum]]]]
                    type = num
                    knx_dpt = 5
                    visu_acl = rw
                    knx_listen = 1/3/10
                    knx_send = 1/3/10
                [[[door_vorraum]]]
                       type = bool
        [[Buero]]
            [[[deckenlicht_buero]]]
                [[[[OnOff]]]]
                    type = bool
                    knx_dpt = 1
                    visu_acl = rw
                    knx_listen = 2/1/1
                    knx_send = 2/0/1
                    knx_init = 2/1/1
                 [[[door_buero]]]
                       type = bool
    HTML-Code:
    {% extends "rooms.html" %}
    {% block content %}
        <h1><img class="icon" src='{{ icon0 }}scene_office.png'/>Büro</h1>
        <div class="block">
        <div class="set-2" data-role="collapsible-set" data-theme="c" data-content-theme="a" data-mini="true">
            <div data-role="collapsible" data-collapsed="false" >
                <h3>Licht</h3>
                <table width="90%">
                <tr>
                <td align="left" width="100px">&nbsp; {{ basic.switch('deckenlicht_buero', 'EG.Buero.deckenlicht_buero.OnOff', icon1~'light_light.png', icon0~'light_light.png') }}
                 </td>
                 <td>Deckenlicht</td>
                 </tr>
                 </table>
              </div>
        </div>
        </div>
        <div class="block">
            <div data-role="collapsible" data-collapsed="false">
                <h3>Rollladen</h3>
                {% import "widget_shutter.html" as shutter %}
                <table width="100%"><tr>
                    <td width="50%">{{ shutter.two ('shutter1', 'Tür', 'eg.buero.rollladen.west.fahren', 'eg.buero.rollladen.west.stopp', 'eg.buero.rollladen.west.position', 'eg.buero.rollladen.west.beschatten') }}</td>
                    <tr></table>
            </div>
        </div>
        </div>
             <div class="block">
            <div data-role="collapsible">
              <h3>Status Tür und Fenster</h3>
              {% import "widget_window.html" as window %}
              <p>
                {{ window.two ('window1', 'Tür', 'eg.buero.fenster.west' ) }}
               </p>
            </div>
        </div>
        </div>
    {% endblock %}
    [EG]
    [[Vorraum]]
    [[[[OnOff]]]]
    type = bool
    knx_dpt = 1
    visu_acl = rw
    knx_listen = 1/4/29
    knx_send = 1/1/29
    knx_init = 1/1/1
    {{ basic.switch('S1', '1stFloor.LivingRoom.Spot.OnOff', icon1~'light_floor_lamp.png', icon0~'light_floor_lamp.png') }} Living Room Spot
    Der "Pfad" zum item passt nicht, bei Dir steht zwar was von EG.Vorraum.deckenspot_vorraum.OnOff bei den Items aber nicht im HTML basic.switch.
    Ändere das entsprechend und dann klappt es sicher auch.
    Bernd
      Hab zuerst einen falschen html-code kopiert nun ist er berichtigt.
      Es geht um das Deckenlicht im Büro
      Danke
        https://knx-user-forum.de/smarthome-...rbehebung.html
        Mit freundlichen Grüßen
        Niko Will
