SmartVisu SVN Update Fehler: Repository UUID doesn't match expected UUID
    ich bekommen immer wenn ich SmartVisu mit Script "/var/control/bin/update.sh" Update folgenden SVN Fehler.
    svn: warning: W170009: Repository UUID 'b3c28d46-a75b-210e-919a-ce57b7db7bff' doesn't match expected UUID '8723986e-f16c-9483-1a4a-ce57b7db7bff'
    Wie kann ich das lösen ?
    Danke
    Ciao
    Christian
    Updating SmartHome.py
    HEAD is now at c4617f9 DWD fix
    Already up-to-date.
    Restarting SmartHome.py smarthome.py
    Killing smarthome.py
    Updating smartVISU
    Reverted 'temp/offline_berlenz.var'
    Reverted 'temp/offline_fleischer.var'
    Reverted 'temp/offline_alber.eibd.var'
    Reverted 'temp/offline_meister.var'
    Reverted 'temp/offline_gleiss.linknx.var'
    Reverted 'temp/offline_otterstaetter.var'
    Reverted 'temp/offline_docu.var'
    Reverted 'temp/offline_alber.smarthome.py.var'
    Reverted 'temp/offline_gleiss.smarthome.py.var'
    Updating '.':
    Fetching external item into 'vendor/Twig':
    Fetching external item into 'vendor/jquery.cycle2':
    External at revision 97.
    Fetching external item into 'vendor/google.prettify/src':
    External at revision 304.
    Fetching external item into 'vendor/google.prettify/styles':
    At revision 585.
    svn: E205011: Failure occurred processing one or more externals definitions
